jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Dec 20, 2007 12:38 pm Post subject: How do you like your FireFly? |
I have been wondering how people have been liking their FireFly Kolbs.
I am particularly interested in the Part 103 ones that are really legal.
I understand that if you have the Rotax 447 equiped version you should be able to keep under the required weight, but how does it perform with that engine?
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Ralph B
Joined: 14 Apr 2007 Posts: 367 Location: Mound Minnesota
Posted: Thu Dec 20, 2007 1:02 pm Post subject: Re: How do you like your FireFly? |
jb92563 wrote: | I have been wondering how people have been liking their FireFly Kolbs.
I understand that if you have the Rotax 447 equiped version you should be able to keep under the required weight, but how does it perform with that engine? |
My Original Firestar is very much like a Firefly except for the weight (319 lbs.) It came with a Rotax 377 engine and performed well. The 447 engine that I have now gives it a little more punch and I can cruise at a lower RPM to make it last longer.
_________________ Ralph B
Kolb Kolbra 912uls
N20386
550 hours |
jb92563
Posted: Thu Dec 20, 2007 3:12 pm Post subject: Re: How do you like your FireFly? |
A FireFly driver (UL's are not aircraft so we drive them not fly....)
said that with the 447 engine it seemed overpowered and he installed a Victor 1+ instead and its much better behaved.
I guess 40HP accounts for the 1,000 fpm climb rate and is more than most people need.
I figure it comes in handy on short fields with tree lines or other obstacles, making it a nice UL-STOL.
I have flown the Lazair(See my ID pic) and with a 400 fpm climb in a High Desert environment (Higher density altitude) the greater power available would be nice....not that you have to use it all.
I will find out with My UltraStar soon enough as I am nearly ready to go flying it.
Still need to engineer the brake solution. I have some 4.5" drum brakes to install somehow.
Also need to install the fuel sender in the fiberglass tank and hook it up to the E1 engine monitor.
Can you believe it, I have an all digital "Glass" panel in my UltraStar ....no analog instruments here...times have changed.
Description: |
Filesize: |
168.93 KB |
Viewed: |
756 Time(s) |
Moni MotorGlider
Do Not Archive |
bransom(at)ucdavis.edu Guest
Posted: Thu Dec 20, 2007 4:37 pm Post subject: How do you like your FireFly? |
Interesting ...I just reweighed my Firestar KXP last wknd and it is
320lbs empty. That is with 447, warp prop, 8" tires, Azusa drum brakes,
no streamline struts, (and 7 rib wings).
-Ben
Ralph B
Original Firestar
N91493 E-AB
21 years flying it
http://forums.matronics.com/viewtopic.php?p=153357#153357
Posted: Thu Dec 20, 2007 5:20 pm Post subject: How do you like your FireFly? |
> A FireFly driver said that with the 447 engine it seemed overpowered and
> Ray
Ray:
Based on that statement, a rubber band might be too much for him.
Much better behaved with a Victor??? Horse manure!
john h - Who finds the 447 powered FF a delight to fly, a scaled down Sling
Shot, a perfect combination of aircraft and engine.
_________________ John Hauck
Titus, Alabama |
rlaird
Posted: Thu Dec 20, 2007 10:12 pm Post subject: How do you like your FireFly? |
I'm a MkIII owner/driver, but I have flown a Firefly with 447... it's performance is terrific, short takeoffs, fast cruise (which, by itself, will break the 103 rule), and a whole lot of fun to fly. Highly recommended!
-- Robert
On Dec 20, 2007 2:38 PM, jb92563 <jb92563(at)yahoo.com (jb92563(at)yahoo.com)> wrote:
[quote] --> Kolb-List message posted by: "jb92563" <jb92563(at)yahoo.com (jb92563(at)yahoo.com)>
Ray
Riverside County, CA
http://forums.matronics.com/viewtopic.php?p=153350#153350
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
Posted: Fri Dec 21, 2007 6:22 am Post subject: How do you like your FireFly? |
> Ray
Ray:
FireFlyers,
The orginal request was made about performance of a Part 103-7 FireFly. And
my answer was given in that context. I don't know how many on the List have
flown a legal ultra light vehicle FireFly or currently own one, but I have
noticed quite a few currently sport N numbers.
Anyone can take an experimental and boost the empty weigh by adding more
engine or whatever, but it takes some effort to stay within the Part 103-7
bounds. If you have or have built a FireFly with less than 15 inch chord
ailerons and it is close to 254 pounds empty with a Rotax 447 mounted, it is
overpowered. All the comparisons you want to make to Kolbras and other
forms of Kolb heavy metal will not alter that fact. Check out AC 103-7
Appendix 1, 2, 3 & 4.
It is good that by the end of the year there will be no fat ultra light
vehicles as they will change into undocumented experimentals and illegals.
It was good to hear from Pat that they are offering the FireFly in UK with a
27 hp engine. It seems to fly very well.
The List seems to be dominated by the thought that more power is better.
But with the addition of power comes increased weight, wing loading and
stall speeds, increased dynamic loading of the air frame, which means things
start cracking. These must be bulked up and so more weight is added. If
you want to do this, it is your right, but cut us guys who want to remain
Part 103-7 legal a little slack.
Jack B. Hart FF004
Winchester, IN
ulflyer(at)verizon.net Guest
Posted: Fri Dec 21, 2007 7:35 am Post subject: How do you like your FireFly? |
Used to have a FireFly for a number of years. I assure you it is not under powered with a 447. It's like a little sports car version of the Kolbs, small and quick. It flies very well, gets off great. My partner and I were not exactly light weights, both in the 250# plus area. It is not for a real tall person, my partner was 5-10". If your much over that you head can start hitting the wing root cover. Fun little airplane that doesn't take up a lot of hangar space. Were were fat and built it knowing we would be. We had the larger dia, wheel barrow wheels, (didn't like the 5", worked the gear pretty hard on rough turf). Also had brakes and a very well equipped instrument panel plus the full enclosure, VLS chute. We had the expansion go-kart type brakes, if doing over I would adapt it over to band brakes, they work better and weigh a lot less. Had flown it with the short wind screen and the full enclosure, much nicer flying with that. The wind flying it seems to be much worst than I remember a motor cycle being. I do feel it is a little more challenging airplane to fly, liked that but probably not the best plane for a person just learning to flying or those with minimal flight time. Heard that the new owner changed to different tires/wheels and it improved its ground handling. (It had the thin Chinns tires on it as came on the wheels from Kolb.) Since both of us were old tail wheel pilots, we didn't have any problems with it. Do a search on guy morgan on the list regarding his changing the tires/wheels. It was fun to fly, but could only carry 5 gallons of fuel as configured. We found we could stuff a couple 2-1/2 gal. jerry cans in around the existing tank. Before we sold it we were looking into ways of increasing fuel capacity to give range to make it to and from other area airports especially with any major head wind. We flew it in fairly windy conditions but again we were experienced pilots and had hundreds of hours of tail wheel time under our belt.
jerb
At 12:10 AM 12/21/2007, you wrote:
[quote]I'm a MkIII owner/driver, but I have flown a Firefly with 447... it's performance is terrific, short takeoffs, fast cruise (which, by itself, will break the 103 rule), and a whole lot of fun to fly. Highly recommended!
-- Robert
Ray
MKIIIX040
Joined: 31 Mar 2006 Posts: 123 Location: Millinocket, Maine
Posted: Fri Dec 21, 2007 7:42 am Post subject: How do you like your FireFly? |
I think your right Jack but don't be too hard on John.
I think he probably went out west to meet up with Mat.
They blew all the contribution money in Vegas and are now little burnt out
On cocaine and hookers.
Vic
Having fun in Maine
_________________ MKIIIX040
912UL |
Steve Boetto
Posted: Fri Dec 21, 2007 7:44 am Post subject: How do you like your FireFly? |
I can only speak in regard to a Firefly on floats with a 447.
Take Off on Glassy water------- 150 ft
Climb at Sea Level ----- At least 900 fpm
Handling ----- quick and nimble
See AOL's top rated recipes and easy ways to stay in shape for winter.
Description: |
Filesize: |
26.88 KB |
Viewed: |
639 Time(s) |
indyaviator(at)gmail.com Guest
Posted: Fri Dec 21, 2007 8:01 am Post subject: How do you like your FireFly? |
The legal status of a "fat ultralight" does not change at all. They are no more illegal on Feb 1st than they are now. People that are making money on the SP transitions like to imply otherwise. I guess we will see.
Bryan Dever
Posted: Fri Dec 21, 2007 8:02 am Post subject: How do you like your FireFly? |
Jack and guys and girls,
Very well stated, Jack. I think you deserve quite a bit of credit for trying to maintain a legal Part 103 ultralight. It is no easy task, I'm sure, balancing necessary performance and safety requirements within such stringent perameters.
Although this isn't the direction I'm headed with my current Kolb, as I stated a few days back, there may be a Firefly in my future...someday. It is comforting to know that a particular aircraft is available, with excellent performance and handling, and still remain inside the guidelines of the regulations.
It doesn't take years and years to build a Firefly, does it? Just curious............
Mike Welch in SW Chilly Utah, w/ no snow, working on tailfeather fabric today, in my heated shop, listening to Rush.
Jack B. Hart FF004
Winchester, IN
The best games are on Xbox 360. Click here for a special offer on an Xbox 360 Console.
http://www.xbox.com/en-US/hardware/wheretobuy/
dhkey(at)msn.com Guest
Posted: Fri Dec 21, 2007 2:46 pm Post subject: How do you like your FireFly? |
good choice of music, you'll probably be done before they tour again.
[quote] From: mdnanwelch7(at)hotmail.com
Subject: RE: Re: How do you like your FireFly?
Date: Fri, 21 Dec 2007 08:00:36 -0800
--> Kolb-List message posted by: Mike Welch <mdnanwelch7(at)hotmail.com>
> FireFlyers,
> Jack B. Hart FF004
> Winchester, IN
Posted: Fri Dec 21, 2007 5:04 pm Post subject: How do you like your FireFly? |
Thanks Dave, but I was referring to Limbaugh. 8>)
I finished the Poly Fiber fabric on the MkIII fuselage and got one coat of Poly Spray. Essentially today all I had to do is all the "touch up" work, like edges, and misc. reinforcements. I did a fantastic job on the Poly Fiber, if I do say so myself. That, or it's just easy, whichever. Anyway, the fuselage looks just plain awesome....
I heard once I ain't braggin' if it's true.
Mike Welch....headed to Missouri on Monday to sight-see/vacation.
Date: Fri, 21 Dec 2007 16:46:03 -0600
> FireFlyers,
> Jack B. Hart FF004
> Winchester, IN
Share life as it happens with the new Windows Live.
http://www.windowslive.com/share.html?ocid=TXT_TAGHM_Wave2_sharelife_122007
JetPilot
Posted: Fri Dec 21, 2007 6:11 pm Post subject: Re: How do you like your FireFly? |
I think the Firefly would be a really fun plane to own, although I would not even consider making it 103 legal. Building it as an experimental and putting an N number on it is not hard at all. One could end up with a much better and durable plane by adding a couple more pounds.
As far as engine, I would put a 503 on it, much more reliable an better than the 447. As far as some that say its overpowered, those are guys that have small engines and try to convince themselves that they made the correct choice by having a small, sub standard engine... Nothing says you need to fly around at high power all the time, but lots of power is a really great thing to have when you need it. More power is also safer, will get you out of trouble when you need it, you will get off the ground quicker, and on takeoff you will also be a lot higher at the end of runway.. If the engine quits on takeoff, you will have several hundred feet more altitude then they poor guy with the small, very light engine.
I have flown with a lot of Learjet pilots over the years, and every one of them loved the 45 degree climb-outs, and quick takeoffs. I have NEVER heard anyone say that any plane they actually flew had to much power. The only people I ever hear talk about some planes "having to much power" are pilots of doggy, sluggish airplanes that are trying to convince themselves that a lack of power is a good thing.
Mike
MK-III Xtra 912-S And loving the steep climbs
Kolb MK-III Xtra, 912-S |
Posted: Fri Dec 21, 2007 8:57 pm Post subject: How do you like your FireFly? |
Mike,
Do you have any stick time in a FireFly, I have and there is plenty
of power there with a 447.
Our 447 worked fine and mine on my Hawk so far has performed
well. While I will agree the 503 is a good engine, (especially like
oil injection no premix - less stale fuel to deal with) it would just
add more weight to the airframe. Got to remember the FireFly is a
light airplane compared to a FireStar and you need to consider the
specified gross weight limit of the airframe.
As for building it to meet the 254# limit, I'm confident it can be
done - no extras. I know what ours weighed and what contributed to
the weight. Go with 5" inch wheels, band brakes if any, wood prop,
bare bone instruments (non-sensitive altimeter) - air speed, and toss
up between analog EGT/CHT gauges or Grand Rapids Technologies EIS,
and if you must, the open wind screen rather than the full
enclosure. (I would still take the EIS, it's a wonderful piece of
equipment.) As for climb out at our weight (both plane and our full
figures) we still normally pushed in excess of 1000 F/S on climb
out. We had an electric Variometer like used in gliders - was very
sensitive and accurate.
jerb
more pounds.
Mike
you could have !!!
http://forums.matronics.com/viewtopic.php?p=153612#153612
Steve Boetto
Posted: Sat Dec 22, 2007 5:03 am Post subject: How do you like your FireFly? |
In a message dated 12/21/2007 11:58:44 P.M. Eastern Standard Time, ulflyer(at)verizon.net writes:
Quote: | The only people I ever hear talk about some planes
Quote: | "having to much power" are pilots of doggy, sluggish airplanes that
Mike
Mike, the Firefly is a VERY Mission Specific aircraft, It was designed from the tires up to :
Be Part 103
Use a 447
Be exciting to fly
It is one of the few aircraft that meet that goal. (probably the only one)
The Part 103 allowance
Aircraft 254
Floats 60
BRS 24
____________
Total 338
Mine weighs 337
A 447 vs a 503 is not an issue of too much power, it is one of too much vibrating mass.
There is "Firefly" designed to use a 503 and be registered EAB. It is called a Firestar II.
If you get a chance one day fly up to Bartow Airport and I will pick you up, It's about 3 miles. I can strap you into a Firefly with a 447 and a 60# handicap of floats.
"It's not the size of the dog in the fight, It's the size of the fight in the dog." Mark Twain
(My apologies to Bob N. if I got that wrong)
Steve B
Firefly 007/Floats
Description: |
Filesize: |
21.09 KB |
Viewed: |
601 Time(s) |
JetPilot
Posted: Sat Dec 22, 2007 5:25 pm Post subject: Re: How do you like your FireFly? |
Unfortunately, I can only have one Kolb... Being that my wife likes to fly, the MK-III Xtra was the logical choice for me, although I would like to try them all
I also fly a 103 trike with a 447, its a nice setup, but some guys put 503's on them and say its a great upgrade ! As far as I am concerned, for flying around the local area, the smaller the plane, the more fun it is
Mike
jim
Posted: Sun Dec 23, 2007 10:46 pm Post subject: Re: How do you like your FireFly? |
I have a Firefly with a 503. I haven't flown one with a 447, but my airplane always wants to pitch up and fly left (left wing very heavy). This is because of the extra weight and torque of the 503. The trim tab on the left aileron is already full up.
I expected the 503 to climb out at 1500 fpm but it's more like 1000 fpm from my home field (2500 msl).
If I were to buy or build another Firefly, I would definitely use the 447. I think the only thing I would miss on the 503 is the oil injection.
To be 103 legal in the Firefly, you are limited to 2-bladed wood prop,small wheels, no brakes, no or limited gages, 1 coat of paint, short windscreen.
I have the short windscreen. It is very wind. I actually think it would be better to take it off completely. The short windshield seems to put all the turbulent air right at head.
Mine has the gap seal removed (between wings). I am 6-01 and if it were there, I think my head wouldn't fit in the airplane.
Mine performs very well in turbulence and handles winds well. Ailerons are heavy in cruise, but fine during approach.
Jim
N. Idaho
_________________ Jim
N. Idaho |
Posted: Mon Dec 24, 2007 8:19 am Post subject: How do you like your FireFly? |
> Jim
Jim:
Don't think the 503 is causing your out of trim problem. If anything, the
increased thrust of the 503 would cause a nose down pitch.
Probably have too much incidence right wing, or not enough in the left wing.
Ailerons can be dropped a tad to correct the nose up pitch trim.
Call Kolb and get a new adjustable universal for the drag strut attachment.
Then you can adjust incidence to correct your roll problem.
Titus, Alabama |
