E. Clegg
Posted: Sat Dec 29, 2007 7:38 am Post subject: Another wet compas problem |
Hi All,
I placed a wet compass in my panel on the upper left side. With the canopy
open-RV8- it reads approx correct. As I close the canopy this compass starts
rotating to the right and when completely clsd the compass is Off 50
degrees.
It would appear that the canopy frame is magnetized. If this is so how would
one go about the fix for this.
Ed Clegg
Posted: Sun Dec 30, 2007 8:29 am Post subject: Another wet compas problem |
ed clegg wrote:
Hi All,
degrees.
Ed Clegg
Try to find a TV repair technician who will loan you his degaussing
tool. It's basically a big coil of wire with an AC cord & switch. It
generates a constantly changing magnetic field, due to the AC current
flowing through it. You power it up and bring it slowly closer to the
object you want to demagnetize. Move it slowly around the object holding
it as close as possible. Then slowly move it away, as you continue to
move it around the object. Don't turn it off until it's several feet
away from anything you want to avoid magnetizing.
earl_schroeder(at)juno.co Guest
Posted: Sun Dec 30, 2007 10:34 am Post subject: Another wet compas problem |
If memory serves, using the old type gun looking soldering irons used to work also..
Earl
-- Charlie England <ceengland(at)bellsouth.net> wrote:
ed clegg wrote:
Hi All,
degrees.
Ed Clegg
_____________________________________________________________
Orchard Bank MasterCard
Get your credit on track with an Orchard Bank MasterCard
http://thirdpartyoffers.juno.com/TGL2121/fc/JKFkuJi7EpInP9rnnLhp0IcKeEmZw4zLN7YtmWRa4QXfFPMotTRHol/
