lbmathias(at)verizon.net Guest
Posted: Mon Dec 24, 2007 11:21 am Post subject: Automatic Flaps |
Hi Lightning Lovers,
I have a mystery to see if you can help explain; when I use 10 degrees flaps for takeoff in the Lightning, they raise automatically during the takeoff. I have never had to retract the flaps after takeoff. Any ideas? Anyone else noticed the same phenomenon?
Merry Christmas, Linda
[img]http://promos.hotbar.com/promos/promodll.dll?GetPromo&El=&SG=&RAND=7043&partner=spamblockerutility&/p.gif[/img]
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
EAFerguson(at)AOL.COM Guest
Posted: Mon Dec 24, 2007 3:01 pm Post subject: Automatic Flaps |
Linda,
Sounds like the old hand resting on top of the stick trick to me. However, in my case the flaps always go down, not up. But I'm left handed.
Earl Ferguson
N17EF
See AOL's top rated recipes and easy ways to stay in shape for winter.
N1BZRich(at)AOL.COM Guest
Posted: Mon Dec 24, 2007 4:31 pm Post subject: Automatic Flaps |
In a message dated 12/24/2007 6:02:53 P.M. Eastern Standard Time, EAFerguson(at)aol.com writes:
| Quote: | | Sounds like the old hand resting on top of the stick trick to me. |
Nope, Earl, that's not it, because it happens when I fly her airplane as well. But, tell me, what weird position are you in to have your hand resting on top of the stick? Is that some new world record setting trick?
Happy Holidays,
Buz
Posted: Mon Dec 24, 2007 5:32 pm Post subject: Automatic Flaps |
[quote] Earl,
That is definitely not it; the hand never rests on top of the stick. They are really retracting without pilot intervention.
Linda
vettin74(at)yahoo.com Guest
Posted: Sat Dec 29, 2007 2:27 pm Post subject: Automatic Flaps |
Linda,
Look for Movement in the inboard flap bracket. On the earlier kits, about 30 and earlier the counter sunk structrual screw that holds the bracket on was a bit long, so the manufacture of the flap used an extra washer, unfortunately this caused the braket to loosen over time and cause the flap to move about a 1/2" or so but no problem in flight. Discovered this on our Demo. The plane was out of trim all of a sudden. We also after about 20 degress flaps noticed a roll as flaps deployed. One flap would stay up a bit as the other went down causing a roll. We have since fixed the this on the kits long ago but not before ours or yours, and have flown the demo and all of our problems have gone away. The plane flys straight flaps up or down as it should.....
nick
JOSEPH MATHIAS LINDA MATHIAS <lbmathias(at)verizon.net> wrote:
[quote] Hi Lightning Lovers,
Be a better friend, newshound, and [quote][b]
155LT
Joined: 14 Sep 2006 Posts: 24 Location: Crossville TN
Posted: Sat Dec 29, 2007 2:41 pm Post subject: Automatic Flaps |
Ok Nick. How did you fix it? And what again am I looking for?
John Davis
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of nick otterback
Sent: Saturday, December 29, 2007 4:26 PM
To: lightning-list(at)matronics.com
Subject: Re: Lightning-List: Automatic Flaps
Linda,
nick
Be a better friend, newshound, and | Quote: | | http://www.matronics.com/contribution | 012345678901234
Posted: Sun Dec 30, 2007 2:52 pm Post subject: Automatic Flaps |
[quote] Nick,
That may well be the problem; my right flap is down about 5 degrees sitting on the ground. At times it looks about 10 degrees but I can bring it back up to 5 degrees by lifing the flap manually. I also have a roll to the right when stalling with flaps; how do I fix it?
Happy New Year, Linda
Posted: Mon Dec 31, 2007 2:02 pm Post subject: Automatic Flaps |
Linda,
When i get back to TN i will email you the fix..
nick
[quote] [quote] Nick,
