Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sun Jan 13, 2008 5:17 pm Post subject: Aileron Trim Tab Length for 601XL |
I am about to close up my ailerons. My next step will be to install the
electric aileron trim tab kit. I have a couple of questions for those who
are already flying with the trim tab option.
1. The 535-mm length of the trim tab seems pretty long to me. I'm
wondering whether that long tab gives too much trim authority. My question
to those already flying with the trim tab is, "how much of the available
servo travel do you use in practice? Is it only +/-1 or 2 marks on the
10-mark trim indicator, or do you sometimes go all the way to, say, +/-4 or
even 5 marks?"
2. Dwg. 6-ATO-1 shows the tab on the left aileron. However, I think I
remember a recent post suggesting that the predominant trim requirement is
to correct a "heavy" left wing. IIRC, the same post suggested that applying
trim downward on the right aileron would be more effective than the
equivalent upward trim on the left aileron. That makes sense to me,
assuming that the predominant requirement is to raise the left wing. My
second question for trim tab users is, "Do you most often trim to raise the
left wing?"
Thanks for sharing your experience.
If anyone else has an opinion whether a trim tab into the high pressure
flow under the wing would actually create less drag than the equivalent
trim from a tab raised into the low pressure flow on top of the opposite
wing, that would be of interest.
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 slow build kit - Tail is finished; working on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
amyvega2005(at)earthlink. Guest
Posted: Mon Jan 14, 2008 5:46 am Post subject: Aileron Trim Tab Length for 601XL |
Terry
the trim tab rod can never be long enough.
the speed envelope of the plane almost requires two different trim setting, fine for high speed and braod for low approach. you will find the trim tab is very effective in cruise, 130+mph , just a touch will do ya, to on landing, you will need everything it has, especially if flying solo. the plane trims out perfect with two pewople aboard.
Juan
daveaustin2(at)primus.ca Guest
Posted: Mon Jan 14, 2008 6:50 am Post subject: Aileron Trim Tab Length for 601XL |
Re the trim tab:
Last thursday I flew my 601HDS with electric trim. Got up to altitude and
touched the elevator trim switch for cruise. It went to full down trim with
my finger off the switch. Hit the switch to get up trim and it went all the
way to full up. The spring in the switch seems to have failed.
I believe the reason I can still tell this tale is that I made my trim tab a
bit smaller than the drawings because I had heard it was very sensitive. I
was able to counter the full trim in both directions by pulling/pushing on
the stick and had time to let the trim run to neutral and then turn off the
trim power switch.
Think about it.
Dave Austin 601HDS - 912, Spitfire Mk VIII
gboothe5(at)comcast.net Guest
Posted: Mon Jan 14, 2008 7:03 am Post subject: Aileron Trim Tab Length for 601XL |
Now there's a topic that should last all week! Glad you made it back to tell
the tale, Dave!
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
Do not Archive
cookwithgas
Posted: Mon Jan 14, 2008 7:36 am Post subject: Aileron Trim Tab Length for 601XL |
Scott,
You'd better be really sure you can overcome a runaway trim situation (that
I just encountered) with a trim flap that big..
Did Zenith OK that?
wjones(at)brazoriainet.co Guest
Posted: Mon Jan 14, 2008 7:45 am Post subject: Aileron Trim Tab Length for 601XL |
Hi Dave ,did it require lots of force to overpower the trim runaway .
Wade Jones South Texas
601XL plans building
Cont. 0200
cookwithgas
Posted: Mon Jan 14, 2008 7:55 am Post subject: Re: Aileron Trim Tab Length for 601XL |
| daveaustin2(at)primus.ca wrote: | Scott,
I just encountered) with a trim flap that big.. |
Dave - I can overcome it with my BRS. Let's hope it won't come to that. Before the next flight I'll talk to the test pilot about doing a test to see what the consequences are with full trim in both directions.
Thanks for the warning!
Scott.
barcusc(at)comcast.net Guest
Posted: Mon Jan 14, 2008 8:16 am Post subject: Aileron Trim Tab Length for 601XL |
Dave,
I also bought the larger trim tab from Zenith after I saw it on their
certified version of the 601, I have read comments by others that had the
same problem as Scott.
I printed out their latest prints of assemblies with part numbers and it
shows the larger trim tab instead of the small one.
Clyde Barcus
601 XL
Hendersonville, TN
Posted: Mon Jan 14, 2008 8:35 am Post subject: Aileron Trim Tab Length for 601XL |
Scott and all,
i practiced run away trim problem, and the procedure I came up with is :
Trim problem at cruise-
1- pull back throttle to manauvering speed
2- stick in direction needed to maintain controlled flight.
3- land
Trim problem below cruise speed, same as above.
If practiced, the plane is easy to fly out of trim. Just gets old quick.
Juan
tonyplane(at)bellsouth.ne Guest
Posted: Mon Jan 14, 2008 9:18 am Post subject: Aileron Trim Tab Length for 601XL |
| Quote: | Terry,
I use very little if any aileron trim, both sides around neutral, during flight - maybe I lucked out in rigging, or maybe because I corrected the below condition I reported on the list on November 11, 2004. I do not know if current drawings have corrected this condition.
Most of my elevator trim is slightly nose up (1 - 2 "marks") during normal cruise flight.with just me aboard.
Tony Graziano
601XL/Jab3300; N493TG with 340 enjoyable flight hrs
Match: #129 Message: #30649 From: <tgrazian(at)bellsouth.net> Subject: Elevator Fairlead at B5, Heavy Left Wing, Engine supportfirewall atttach
Date: Nov 11, 2004
2. My spouse asked why the sticks had a left leaning tendency. The lower elevator
cable is on the centerline of 6B16-2. The upper is displaced to the right
of the centerline on 6B5-2 - this creates a built in bias to lean the stick
to the left (left wing down)- unless corrected."
Time: 05:17:26 PM PST US
From: Terry Phillips <ttp44(at)rkymtn.net (ttp44(at)rkymtn.net)>
Subject: Aileron Trim Tab Length for 601XL
even 5 marks?"
| [quote][b]
Terry Phillips
Posted: Mon Jan 14, 2008 10:02 am Post subject: Aileron Trim Tab Length for 601XL |
Thanks, Scott and Juan.
It turns out my elevator is already done, with the full-width ZAC trim tab.
What I am interested in now is the electric aileron trim. The control rod
length must be whatever it takes to allow the tab to move +/-25°, according
to 6-ATO-1. The aileron trim is designed to level the wings, hands off, not
to trim the pitch.
If I understand Juan correctly, he needs a lot more aileron trim at
approach speed, and the problem is primarily low left wing when flying
solo. That suggests to me that, the earlier post I recall, that suggests it
would be more effective to put the aileron trim tab on the right wing is
probably correct. At a high angle of attack on approach, it seems
reasonable that the aileron would respond much better to the high pressure
flow under the right wing than to the low pressure flow above the left wing.
Has anyone else flown an XL with the electric aileron trim option? If so,
what percent of the aileron trim travel has been used? Are you mostly
raising the left wing?
Terry
At 07:16 AM 1/14/2008 -0800, you wrote:
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
Posted: Mon Jan 14, 2008 10:57 am Post subject: Aileron Trim Tab Length for 601XL |
Terry,
the forces on low appraoch are both on elevator as well as Aileron. With someone else in the plane, the forces are negliable. the plane trims better with two aboard. I calm days or at altitude, the plane trims out with both tabs set for one pilot. I set the aileron for one guy at runup.
Juan
Posted: Mon Jan 14, 2008 11:38 am Post subject: Aileron Trim Tab Length for 601XL |
Wade,
I'd say about 30 lbs.. Enough to get my attention real quick.
Terry Phillips
Posted: Mon Jan 14, 2008 1:16 pm Post subject: Aileron Trim Tab Length for 601XL |
Juan
When you set the aileron for one pilot, I presume you set it by the number
of marks on the R.A. Allen indicator. How many marks are required in your
A/C with yourself as pilot?
Terry
At 01:54 PM 1/14/2008 -0500, you wrote:
| Quote: | Terry,
Juan
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Corvallis, MT
ttp44<at>rkymtn.net
Posted: Mon Jan 14, 2008 1:50 pm Post subject: Aileron Trim Tab Length for 601XL |
Posted: Mon Jan 14, 2008 1:56 pm Post subject: Aileron Trim Tab Length for 601XL |
when I was still building, I was planning to make the trim on both sides of the elevator, with very limited travel initially. I was planning to use the AeroConversions manual trim control. http://www.sonexaircraft.com/orders/trimfaq.html.
There is no reason why tight linkages and low inital throw limits will not work. The only down side I could figure was a slight increase in empty weight at a long mopment arm...
Clyde Barcus <barcusc(at)comcast.net> wrote:
[quote]--> Zenith-List message posted by: "Clyde Barcus"
Dave,
I printed out their Be a better friend, newshound, and [quote][b]
Posted: Mon Jan 14, 2008 1:59 pm Post subject: Aileron Trim Tab Length for 601XL |
actual I don't. the trim setting is so dynamic, it is relative to speed/ rpm/wieght, that as long as the trim is set at zero, when installed, you will constantly be changing it relative to weight, rpm, speed etc. just set to zero pitch when installed. then fly the plane at various rpm settings during the fly off. I know for example that when I have full fuel in right wing, and no passengers, the trim is set at .05 inched above neutral. When I have m y dad in the plane and equal fuel, it set the plane for zero aileron trim and zero elevtr trim at take off. once level I trim for levl flight. it is so dynamic, and the plane is so light, just setting and forgetting is not in the 601's cards. once trimmed though, it is hands off for the duration of flight so long as the weights are neutral, or I keep the gas level even.
Sweet flying plane!!
Juan
planejim(at)bellsouth.net Guest
Posted: Mon Jan 14, 2008 2:12 pm Post subject: Aileron Trim Tab Length for 601XL |
Hey Listers,
Eleven yeras ago when I was flying off the 40 hours on my 601HD I purposly
flew the airplane with the elevator tab at the extreme positions in cruise
to be sure I could over ride it in case of a runaway actuator for the very
reason that Dave experienced. I did it by moving the trim a little at a time
until I had it at full travel in each direction.
I can see where it would scare the sh-- out of you if you weren't ready for
it. That sucker is very effective at cruise, but just nice in the pattern.
Fly careful!
Jim Hoak 601 HD 571 hours.
| Quote: | Re the trim tab:
with my finger off the switch. Hit the switch to get up trim and it went
all the way to full up. The spring in the switch seems to have failed.
a bit smaller than the drawings because I had heard it was very sensitive.
I was able to counter the full trim in both directions by pulling/pushing
on the stick and had time to let the trim run to neutral and then turn off
the trim power switch.
Think about it.
