vozzen
Posted: Tue Jan 15, 2008 8:16 pm Post subject: OT-- Solar panel overvoltage |
Sorry to drift off topic, but chalk it up to Remote Hangar Power-Supply Project.
I've got a couple solar (PV) panels, each rated 48 watt, 3 amp (at) 16 volts, 18-19 volts open circuit. Problem is that I bought an inverter that has a 15.5 high-voltage cutoff, so no worky for 110a/c.
My question(s):
If I got a "Solar Charge Controller", designed to limit charge into batteries, could I use it to supply the inverter ??
And how about a 12-v. resistive load, or pump/fan motors, (no inverter) that would pull down the voltage at max draw ?? ... assuming the charge controller could handle the current.
Any other ideas for regulating 16 v down to a usable 13-14 (for 6 A.)
Thanks in advance for any advice.
--Richard V., 601xl in a cold shop in KC
rjquillin
Posted: Tue Jan 15, 2008 9:12 pm Post subject: OT-- Solar panel overvoltage |
My question(s):
Why not just dump them into a battery and the inverter in parallel?
Ron Q.
echristley(at)nc.rr.com Guest
Posted: Wed Jan 16, 2008 5:51 am Post subject: OT-- Solar panel overvoltage |
Ron Quillin wrote:
Quote: |
<rjquillin(at)gmail.com>
> My question(s):
Ron Q.
My thought exactly. This will have the added advantage of allowing you
to draw more than 6amps on the rare occasion that you need it.
vozzen
Posted: Wed Jan 16, 2008 5:54 am Post subject: Re: OT-- Solar panel overvoltage |
I really wanted to see what was possible without a battery...
--RJV
Posted: Wed Jan 16, 2008 6:53 am Post subject: OT-- Solar panel overvoltage |
--RJV
You can operate without a battery. Anything is possible, if you throw
enough money at it. But the utility you will get from a couple of
batteries will be by far the biggest bang for the buck. Not only will
they let you have an occasional large power draw that the panels
wouldn't support, but they will let you have limited power at night or
when it's cloudy. If you're rotating cheap batteries as Bob suggests,
then you should be able to rotate the 2yr old battery into a "solar
panel support" position. A spare lawn tractor battery would suffice
until it's time to rotate one in from the airplane. The batteries
should last a LONG time, being constantly charged and only occasionally
drained, so you can keep adding capacity by hooking more up in series as
they rotate out of the plane.
Again, it's possible to solve the problem with some creative
electronics. You could chop the panel's DC to create AC, then run that
through a regulator, then rectify it back to DC. Or you could put a
large capacitor and enough Zener diodes to handle 6amps across the
panel's output. What you'll end up with is some electronics to
maintain, without the added benefits of the stored capacity. You'll
spend a lot more than the $30 battery will cost, even if you kit and
build it yourself.
nuckolls.bob(at)cox.net Guest
Posted: Wed Jan 16, 2008 7:18 pm Post subject: OT-- Solar panel overvoltage |
Project.
My question(s):
Kinda, sorta . . . Solar panels have a significant source
impedance. Hence the drop from 19 volts no load to 16 volts
at a 3A load. DeltaV of 3 volts divided by DeltaI of 3A
yields a source impedance on the order of 1 ohm. Two panels
in parallel would drop this to 1/2 ohm for the array.
16 volts would smoke most 12/14v accessories and some
accessories would draw less than 6A which boosts the
voltage still more.
The most "stable" application of solar power is to combine
the array with a battery maintainer designed to integrate
the array with a rechargeable battery. This allows you to
store energy even if you're not using it for the moment
(until battery is charged). It also allows you to tax the
system with loads much larger than 6A albeit intermittently.
A Google search for "solar battery charger" yielded
a bucket full of hits . . . a few are cited below.
http://tinyurl.com/ybh9wz
http://tinyurl.com/246w34
http://tinyurl.com/2c3orf
Suggest you team the solar panels with a regulating
charger, the largest battery you're willing to
acquire and maintain. NOW you have an energy source
that will run a pretty hefty inverter and permit
you to run a variety of loads rain or shine.
( -Thomas Paine 1776- )
vozzen
Posted: Thu Jan 17, 2008 9:02 am Post subject: Re: OT-- Solar panel overvoltage |
Yep, those are the charge controllers I'd looked at, and I understand the role of the battery.
I had tested a direct-driven 12v. boat bilge pump (1.5A) in a water-garden-fish-pond, but found the 16-18v roasted the pump (it did work for a whole summer). Other thought was for an attic exhaust fan-- but without controller, will have same problem.
Will head down to local H.F. Chinese outlet store, get a controller, and go from there.
Thanks, Bob, and others, for suggestions.
--RJV
