andynfultz(at)bellsouth.n Guest
Posted: Sat Jan 19, 2008 1:34 pm Post subject: [avid_flyer] Wind Screen Issues |
What, if anything can be used to remove the dried glue of the protective paper covering on the lexan(?) that was shipped with my kit in 1990? I've tried a product from ACS called UNMASK with no success. I've even tried silicon lubricant and no success. Is there anything that can be used without causing damage? I may just have to replace it. If I do, what exactly do I need to replace it with. I certainly think I'll go with a little thicker material. What I have now is 60 thousands. I'm thinking maybe at least 80 thousands. Some one mentioned a product called PetG from K-Mac Plastics ? ? ? Thanks guys.
Andy F.
peteohms
Posted: Sat Jan 19, 2008 2:10 pm Post subject: [avid_flyer] Wind Screen Issues |
Try Goo Gone of Goof Off. Might work
Pete
_________________ Pete
Leander, TX
Kitfox III, 912ul, Grove |
dave
Posted: Sat Jan 19, 2008 5:11 pm Post subject: Re: [avid_flyer] Wind Screen Issues |
Andy- I would try soap and hot water first. Keep it wet fora period of time ? >> Throw in hot tub overnight ? <<
Or just buy a new sheet. If the backing it hard to get off it is likely you might mark it up trying to get it all off. It is not very expensive.
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
davyken(at)comcast.net Guest
Posted: Sun Jan 20, 2008 4:24 am Post subject: [avid_flyer] Wind Screen Issues |
Hi Andy,
Seems I remember someone suggesting a heat gun on a low setting to soften the glue. If you use the flat sheet of Lexan for the wind screen, you'll want to relieve some of the stress at the bend with a heat gun anyway.
I went with the LP windshield. It adds a little weight but it's a nice option. It fit great and it's thicker than the Lexan.
http://www.lpaero.com/
Ken Davy
N1701S
Classic IV - 912
Time: 01:34:07 PM PST US
Subject: RE: [avid_flyer] Wind Screen Issues
Andy F.
patreilly43(at)hotmail.co Guest
Posted: Sun Jan 20, 2008 8:54 am Post subject: [avid_flyer] Wind Screen Issues |
Ken, What is LP windshield? I need to replace mine. Pat Reilly Mod3 Rebuild Rockford, IL
[quote] From: davyken(at)comcast.net
Subject: Kitfox-List: RE: [avid_flyer] Wind Screen Issues
Date: Sun, 20 Jan 2008 12:16:53 +0000
Hi Andy,
Ken Davy
N1701S
Classic IV - 912
Andy F.
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
p://forums.matronics.com
| [b]
SkySteve
Joined: 16 Dec 2007 Posts: 94 Location: Huntsville, UT
Posted: Sun Jan 20, 2008 8:59 am Post subject: Re: [avid_flyer] Wind Screen Issues |
Here is the address for LP Plastics
_________________ Steve Wilson
Huntsville, UT
Kitfox Model 1- 85DD
912A / 3 Blade Warp Drive
Convertible Nosewheel & Tailwheel
Float Flyr
Posted: Sun Jan 20, 2008 12:49 pm Post subject: [avid_flyer] Wind Screen Issues |
Anybody try WD40??? It penetrates cold, won't damage plastic and you can
use it to clean the glass at the same time.
I had some old plexiglass pieces my father had since the mid sixties... WD40
did the trick on removing the paper.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
jdmcbean(at)kitfoxaircraf Guest
Posted: Sun Jan 20, 2008 2:22 pm Post subject: [avid_flyer] Wind Screen Issues |
We are also a LP distributor...
Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"It's not how Fast... It's how Fun!"
