dlm46007(at)cox.net Guest
Posted: Sun Jan 27, 2008 1:50 pm Post subject: Emailing: P1010075, P1010076, P1010067, P1010068, P1010069, |
Another milestone. wings mounted for the final time. The F-1099 brackets are
called for about half blinds and half solids. The main over wing are called
blind but should be solid. That is the area where everyone will be stepping
to get aboard. All wing bolts in and torqued in about an hour. NAS close
tolerance bolts really tight left and easier on the right. Used LPS-2 for
lubrication the holes. Also the forward most top hole each side gets a solid
AN4704-5. The top bracket stops short of that hole but it is punched in the
skin anyway. It easily clears the tank attach spar.
Your message is ready to be sent with the following file or link
P1010075
P1010076
P1010067
P1010068
P1010069
P1010070
P1010071
P1010072
P1010073
P1010074
74.01 KB |
402 Time(s) |
69.23 KB |
405 Time(s) |
67.79 KB |
407 Time(s) |
57.29 KB |
407 Time(s) |
76.58 KB |
433 Time(s) |
74.82 KB |
410 Time(s) |
77.46 KB |
417 Time(s) |
81.43 KB |
411 Time(s) |
57.8 KB |
397 Time(s) |
59 KB |
412 Time(s) |
