cdewey6969(at)yahoo.com Guest
Posted: Sat Feb 02, 2008 4:26 pm Post subject: Lightning marketing |
HOW CAN WE BETTER GET THE WORD OUT ON THE LIGHTNING?
THE AUTOMATIVE INDUSTRY IS GEARING TOWARD SMALLER,
MORE FUEL-EFFICIENT VEHICLES. THE GENERAL AV INDUSTRY
NEEDS MORE LIGHTNINGS AND LESS CESSNA AND CIRRUS GAS
HOGS!
--- nick otterback <vettin74(at)yahoo.com> wrote:
| Quote: | The pharse, in this case most likley is describing
the install of the firewall to the flange on the
fuselage and in this case is correct to state of the
correct length. A fiberglass surface although made
up of the same layers of glass may not be the same
thickness every time, therefore to give a certain
bolt length would be hinderent against safty if a -4
were to be used but a -5 was needed you most likley
would not have any threads showing on your bolt and
this would be not so good. Determining bolt length
in metal however is easy. The other possibility is
that it may be in an early section of the manual
that our "staff" has not gotten to revising yet and
will as time permits. We do appericate the input of
lacking hardware and do our best to update the kit
when notified. If the kit is lacking let us know of
your need and we can get these out most of the time
in the same day. We have revised parts in the kit to
make fit and finish better, the cahnges have
apparently not
filtered to the manual or the hardware kit and can
be easily rectified. The decoder ring for the hidden
phrases is available from you local dealer..it is an
option.
Nick Otterback
Arion Aircraft
Sales Email Account <sales(at)billandruth.net> wrote:
Hi all you hard working Lightning builders (and
flyers!),
I have determined that there is at least one special
code phrase that is quite prevalent in the builders
"manual." That phrase goes like this:
"...and insert an AN3 (or 4 or 5) of appropriate
length."
It has taken me a while to figure what this special
code phrase really means but, now I have translated
that innocent phrase into its true meaning, which
is:
"...and insert an AN3 (or 4 or 5) that is not in the
hardware that came with your kit."
Perhaps you have found other special code phrases of
your own in the Lightning manual and have figured
out their true meaning as well. If so, please pass
them on so others can benefit and maybe get a
chuckle or two also.
Bill in Tucson, kit #49 currently installing
elevator push-pull tube and hoping to start on the
canopy tomorrow.
Be a better friend, newshound, and know-it-all with
Yahoo! Mobile. Try it now.
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
