Jaybannist(at)cs.com Guest
Posted: Wed Feb 06, 2008 1:13 pm Post subject: Horiz Stab Connection |
I am in the process of final assembly of my 601XL. This morning, I installed the horizontal stabilizer. I have all four bolts in place and the nuts on the two rear bolts. The two forward bolts go through the vertical mounting angles on the stab. The inboard leg of that angle blocks direct access to the bolt ends where the nuts must go. The hole between the fuselage skin and the mounting bracket is too small to get access to the nut. Any helpful hints on getting those nuts installed?
Jay in Dallas 601XL N2630J "Lil Bruiser"
GLJSOJ1
Joined: 18 Aug 2007 Posts: 82 Location: Chesapeake, Virginia
Posted: Wed Feb 06, 2008 1:58 pm Post subject: Re: Horiz Stab Connection |
Hi Jay
I mounted my stab bolts from the inside, I put them in with a socket and a long extension, which is slender enough to slip between the stab and fuselage sides from the opposite side. Then put the washer and nut on the outside. This way I was able to get the bolt in and well as monitor the nut with a easy visual inspection. I usually get the wife to help me so there are two sets of eyes.
_________________ 601XL N676L FLYING PHASE I
CHESAPEAKE VA |
Posted: Wed Feb 06, 2008 2:19 pm Post subject: Horiz Stab Connection |
use a magnetic pen and a drop of RTV to hold the bolt. I preferred the nut out ward scen so that I can monitor on inspection.
bryanmmartin
Posted: Wed Feb 06, 2008 2:23 pm Post subject: Horiz Stab Connection |
I also installed the bolts with the heads on the inside so the nuts
could be installed on the outside. It makes it easier to torque and
inspect the nuts. I did the same thing with the rear wing bolts.
On Feb 6, 2008, at 4:10 PM, Jaybannist(at)cs.com wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
