vettin74(at)yahoo.com Guest
Posted: Tue Feb 12, 2008 7:06 am Post subject: ALE-0030 rear elevator bell-crank |
To builders....
Any one has recieved the new rear bell crank ALE-0030 do not use it for final install
The center arm is offset 10 degrees to the rear instead of 10 degrees to the front as called for in the manual. The center horn should tilt forward and away from the direction the the 3 hole end horn. The end horn is triangle shaped if the triangle points back the horn should tilt forward.....I just want to make the discription very clear here....i believe and so does the weld shop that the few wich have been delivered are incorrect, we have a list and they do to of the kits recieveing them. The weld shop is making news one stodya and will have the correct ones out ASAP, so hold on to the ones you have and use it for apnecil holder or something it is of no use...the wle dshop does not wan them back for refit and we do not want to send refits to other customers....If you ahve used this bell-crank to fit the elevators together that is fine the tir-horn ends are correct and this can be used for fitting. If you have cut your push pull tube based on this bell crank it will simply be too long and can be shortend....
Nick Otterback
Arion Aircraft LLC
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
