lgold(at)quantum-associat Guest
Posted: Mon Feb 18, 2008 10:18 am Post subject: Black crud in gascolator |
At 8 hours TT and now again at 15 hours, I noticed a lot of small non-magnetic black particle specks in fuel drained from the gascolator and tank drains on my new 701. These particles settle to the bottom of the drained fuel and stop coming out after draining about 6 ounces. My 701 has only one gascolator that is placed in the fuel line on the engine side of the firewall just downstream of two fuel filters (one for each wing tank).
I don't understand how the gascolator could get dirty downstream of the filters and don't know where the specs are coming from. I cleaned everything with a vacuum cleaner and with compressed air pressure before connecting the lines. The black specs are non-metallic and I don't think they are aluminum. My fuel lines are Aeroquip, stainless steel clad, top-of-the-line, and the fuel filters are 10 micron stainless screens that are about 1' in diameter. So far there has been no decrease in fuel flow or engine power. Has anyone else had this problem and there something I should be doing about it besides checking the fuel filters?
Thanks for the help,
Les
Gig Giacona
Posted: Mon Feb 18, 2008 11:10 am Post subject: Re: Black crud in gascolator |
Have you looked at the filters? Where are you getting your gas?
601XL Under Construction
Posted: Mon Feb 18, 2008 12:26 pm Post subject: Black crud in gascolator |
W.R.,
I will look at the filters this week but there is no noticeable blockage in
the lines. I use the best gas I can find in the area, 91 octane Chevron and
I filter all gas as I put it in the tanks. The crud is not coming from the
gas station.
Les
[quote] --
bryanmmartin
Posted: Mon Feb 18, 2008 6:02 pm Post subject: Black crud in gascolator |
Does the fuel have alcohol in it? Are your fuel lines alcohol proof?
On Feb 18, 2008, at 1:15 PM, Les Goldner wrote:
Quote: | At 8 hours TT and now again at 15 hours, I noticed a lot of small non-magnetic black particle specks in fuel drained from the gascolator and tank drains on my new 701. These particles settle to the bottom of the drained fuel and stop coming out after draining about 6 ounces. My 701 has only one gascolator that is placed in the fuel line on the engine side of the firewall just downstream of two fuel filters (one for each wing tank).
Les
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
billmileski
Posted: Mon Feb 18, 2008 6:07 pm Post subject: Re: Black crud in gascolator |
Les,
Double-check the Aeroquip specs to see if it is recommended for autofuel (and its alcohol, toluene, etc.). I found that some of the aviation fuel line prohibits autofuel, might be worth checking. That would mean the black specs are decomposing fuel line material, but I don't know if that makes any sense. Good luck,
Bill Mileski
Ledyard, CT
701 912S 116hrs
Posted: Tue Feb 19, 2008 9:40 am Post subject: Black crud in gascolator |
Bryan,
Since I used the most expensive unlimited shelf life fuel line sold by Spruce, I just assumes it was alcohol proof. But now you have me wondering. I put a call in to Aeroquip's tech staff to find out if the line is alcohol proof... no answer yet!
Les
[quote] From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Bryan Martin
Sent: Monday, February 18, 2008 5:59 PM
Subject: Re: Black crud in gascolator
Les
Bryan Martin
N61BM, CH 601 XL,
do not archive.
Quote: |
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| [b]
Gig Giacona
Posted: Tue Feb 19, 2008 11:49 am Post subject: Re: Black crud in gascolator |
You might want to try here and look up the hose you used.
http://hydraulics.eaton.com/products/fluid_conveyance_aeroquip.htm
lgold(at)quantum-associat wrote: | Bryan,
Les |
