lik_2_fly(at)hotmail.com Guest
Posted: Tue Feb 26, 2008 4:21 pm Post subject: Inflight cameras |
Hi,
Wondering if anyone has any experiance with in flight video camera's. Having trouble finding reasonably high quality camera's as well as recorders that can take mutliple camera's without the quality degrading.
Or do people just run individual video camera's for each remote head?
Does anyone know what type of camera's are used in redbull air races?
cheers
Chris
Find it at www.seek.com.au Your Future Starts Here. Dream it? Then be it! [quote][b]
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
BUCSDDS(at)aol.com Guest
Posted: Tue Feb 26, 2008 5:29 pm Post subject: Inflight cameras |
If you should receive any response would you mind sharing?
Marwin Goff
DSM
Varieze O-200
515-360-0778
bucsdds(at)aol.com
In a message dated 2/26/2008 6:24:17 P.M. Central Standard Time, lik_2_fly(at)hotmail.com writes:
| Quote: | Hi,
cheers
Chris
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
Posted: Wed Feb 27, 2008 3:17 am Post subject: Inflight cameras |
I am also interested in what you find
Carlos Trigo
RV-9A
Portugal
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of BUCSDDS(at)aol.com
Sent: quarta-feira, 27 de Fevereiro de 2008 1:26
To: avionics-list(at)matronics.com
Subject: Re: Avionics-List: Inflight cameras
Marwin Goff
DSM
Varieze O-200
515-360-0778
bucsdds(at)aol.com
Hi,
cheers
Chris |
| Quote: | | http://www.matronics.com/Navigator?Avionics-List | 0123456789
n395v
Float Flyr
Posted: Wed Feb 27, 2008 6:14 am Post subject: Inflight cameras |
I think most of the guys just use one small video camera in the plane or mounted outside. With multiple cameras you can edit the pieces together on you r computer. Bringing a whole switching suite aloft in a two seat plane isn’t really an option.
I would recommend using a 1A skylight filter for video aloft to kill some of the excess blue you usually get. It will also make the ground look a lot sharper.. White light balancing can do a lot to correct colour but to do the job right you still have to go back to either a 1A or a UV lens filter.
When placed on a sheet of white paper the 1A will appear to have a very slight yellow tint.. The UV will look slightly salmon colour. Neither filter will affect your exposure.
I also advise you to go to a camera specialty shop to buy your equipment. They probably won’t look at you as if you had two heads when you ask about filters to fit the camera you are about to purchase. They will also be able to advise you on the care and operation of your camera and generally if warranty is required they will help there too. BTW most camera stores are very competitive with big box outfits like Wallyco.
Noel
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of Carlos Trigo
Sent: Wednesday, February 27, 2008 7:43 AM
Subject: RE: Inflight cameras
Carlos Trigo
RV-9A
Portugal
Subject: Re: Inflight cameras
Marwin Goff
DSM
Varieze O-200
515-360-0778
bucsdds(at)aol.com
Hi,
cheers
Chris |
| Quote: | | http://www.matronics.com/contribution | 0123456789012345
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
gary(at)liming.org Guest
Posted: Wed Feb 27, 2008 9:19 am Post subject: Inflight cameras |
I have four permanent mounts on my airplane - a camera looking
straight aft (which comes in handy as a "rear view mirror") and makes
very dramatic departure footage in the STOL plane, and one on each
wing on a ground adjustable swivel. I usually have the right wingcam
pointed straight ahead (or sometimes, straight down) and the other
one I have pointed at the cabin. I also have a rear cabin camera
pointed at the panel, also looking out the windshield, and another
one (lower res) that is wireless that can be duct taped anywhere
outside on the airframe for recording tufts, etc. All of the these
go into a shielded 5 position switch box that has two outputs, one to
a monitor built into the door of my mapbox, and the other to jacks to
the video camera. The audio portion of the video camera is fed by
the intercom's output of the pilot's headphones, so anything I hear
in my headphones is recorded. All devices are 12 volts.
The cameras are 480 line Sony super HAD 1/3 inch sensor cams that
allow for different focal length lenses. They look pretty good for
standard res tv, and make for some clear images. Anything less looks
pretty bad - I am waiting for some 720 or even 1080 cams to be
cheaply available - then I might upgrade the cameras.
I usually just hook up the camera to the system and turn it on as
part of preflight - select which camera I want to record, and then
forget about it until landing. One exception is if I want to see who
is behind me on the taxi way if its a busy day. I have learned to
always have the recorder on, though, because you simply don't know
what might come up - the one time you don't use it is the time you
wish you had. If the flight is unremarkable, I just rewind the DV
for the next flight.
Gary Liming
steve(at)huttmail.com Guest
Posted: Wed Feb 27, 2008 9:20 am Post subject: Inflight Cameras |
I’ve no experience of using these, but they are built specifically for this sort of task…..
See here: http://www.sport-cam.co.uk/activities.asp
These folks are in the UK but I’d be very surprised if there’s no equivalent available in the US.
Take a look at the Quad Splitter and the 30GB Digital Recorder in the Recording Devices section.
Steve
hdwysong(at)gmail.com Guest
Posted: Wed Feb 27, 2008 10:39 am Post subject: Inflight cameras |
| Quote: | Hi, Wondering if anyone has any experiance with in flight video camera's. H
See info on cameras, recorder selection, and some great flying videos here:
http://www.thedukes.org/rv/tailcam.html
As you noted, pulling multiple feeds into one recorder will degrade
the quality since you're "sharing" a fixed amount of recorder
resolution between the cameras. We dedicate one recorder per camera
or use a video switcher between multiple cameras and a single
recorder.
D
GrummanDude
Posted: Wed Feb 27, 2008 8:27 pm Post subject: Inflight cameras |
Would it be possible to provide a list of the parts, where they can be purchased, and how much. I am about to do some flight testing and was wondering about cameras.
_________________ Gary
AuCountry Aviation
Home of Team Grumman |
GrummanDude
Posted: Wed Feb 27, 2008 8:36 pm Post subject: Inflight Cameras |
The setup page says I need a camcorder. Doesn't the DVR do the same thing?
AuCountry Aviation
Posted: Thu Feb 28, 2008 2:46 am Post subject: Inflight Cameras |
Yes, that’s my understanding too.
Just use one camera (with mount) plus cable and DVR. Add Splitter and extra cameras/cables if required.
Steve
Subject:
Re: Inflight Cameras
teamgrumman(at)aol.com ([email]teamgrumman(at)aol.com?subject=Re:%20Inflight%20Cameras&replyto=8CA47DA38E31AF0-13C-2FC3(at)webmail-nf16.sim.aol.com[/email])
Date:
Wed Feb 27 - 8:36 PM [quote]The setup page says I need a camcorder. Doesn't the DVR do the same thing? [b]--
Float Flyr
Posted: Thu Feb 28, 2008 8:15 am Post subject: Inflight Cameras |
Yes it does... but... be careful of DVRs that may be out there with HDDs. Those drives are designed to work on the ground and you may have problems with them at altitude. There is no known problems with either tape, DVD or memory sticks.
Same thing goes for I-Pods with the HDD.
Noel
From: owner-avionics-list-server(at)matronics.com [mailto:owner-avionics-list-server(at)matronics.com] On Behalf Of teamgrumman(at)aol.com
Sent: Thursday, February 28, 2008 1:04 AM
Subject: Re: Inflight Cameras
Kitfox III-A
jetboy
Posted: Fri Feb 29, 2008 1:39 pm Post subject: Re: Inflight cameras |
There's good information on ways to do it here
http://www.reflight.com/pdrs.html
_________________ Ralph - CH701 / 2200a |
