wadegreaves
Posted: Fri Feb 29, 2008 9:57 pm Post subject: Painting PVC Struts |
Any input on the best way to paint the PVC strut covers?
Will polytone adhere or do I need to prime it up with epoxy primer?
Thanks!
Lynn Matteson
Posted: Fri Feb 29, 2008 10:22 pm Post subject: Painting PVC Struts |
I covered mine with fabric and painted with Poly-tone. If you don't
cover with fabric, you should use Polyfiber enamel, if you stay in
the Polyfiber line of products. Poly-tone should not be used over
plastic/PVC.
Lynn Matteson
flying w/475+ hrs
On Mar 1, 2008, at 12:57 AM, wadegreaves wrote:
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Glenn Horne
Posted: Sat Mar 01, 2008 5:38 am Post subject: Painting PVC Struts |
Sand, apply some Bulldog on it, prime and paint.
Kitfox Model II
PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Sat Mar 01, 2008 7:26 am Post subject: Painting PVC Struts |
You really don't want to paint the PVC struts without covering them first
with fabric.
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
patreilly43(at)hotmail.co Guest
Posted: Sat Mar 01, 2008 7:42 am Post subject: Painting PVC Struts |
Lynn, What about priming PVC with a 2 part epoxy primer before painting with polytone?
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: Painting PVC Struts
Date: Sat, 1 Mar 2008 01:18:07 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
plastic/PVC.
Lynn Matteson
flying w/475+ hrs
> --> Kitfox-List message posted by: "wadegreaves"
> <reinagreaves(at)comcast.net>
> Thanks!
> http://forums.matronics.com/viewtopic.php?p=167061#167061
Posted: Sat Mar 01, 2008 7:49 am Post subject: Painting PVC Struts |
Lynn, How did you attach fabric to PVC? All of the Poly Fibre products Tak, Brush & Tone are MEK based. Wouldn't any of those attack the PVC?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
Subject: Re: Painting PVC Struts
plastic/PVC.
Lynn Matteson
flying w/475+ hrs
> Thanks!
clint_bazzill(at)hotmail. Guest
Posted: Sat Mar 01, 2008 7:54 am Post subject: Painting PVC Struts |
Why. A big waste of time. Clint
[quote] From: pmorel(at)bellsouth.net
Date: Sat, 1 Mar 2008 09:52:01 -0500
--> Kitfox-List message posted by: "Paul Morel" <pmorel(at)bellsouth.net>
with fabric.
Posted: Sat Mar 01, 2008 8:14 am Post subject: Painting PVC Struts |
The best way to paint PVC and fiberglass is to use 2 part epoxy chromate primer and while it is still wet paint the polytone paint. It works great, 1300 hours to prove it. Clint
[quote] From: patreilly43(at)hotmail.com
Subject: RE: Painting PVC Struts
Date: Sat, 1 Mar 2008 15:22:28 +0000
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass EC_body.hmmessage {font-size:10pt;font-family:Tahoma;} Lynn, What about priming PVC with a 2 part epoxy primer before painting with polytone?
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
plastic/PVC.
Lynn Matteson
flying w/475+ hrs
> Thanks!
arget=_blank>http://www.matronics.com/Navigator?Kitfox-List
| [b]
Lynn Matteson
Posted: Sat Mar 01, 2008 8:22 am Post subject: Painting PVC Struts |
They say Polytone just isn't to be used on a hard surface, but there
is a way to do it, as told to me by Jim Miller the Poly rep in
Columbus, Ohio. You prime with Poly's 2-part epoxy primer, and when
still tacky, shoot with your Poly-tone color. I had to do this when I
installed my flaperon hinges onto the wings. Once the hinges are
treated this way, you can rivet them on, and then shoot the whole
wing with the Poly-tone finish color.
So in your case, I'd shoot with the Polyfiber 2-part epoxy primer,
and while still tacky, shoot with the polytone, but I'd be sure and
use all Polyfiber products if going this route.
But I'd much rather cover with fabric and go the Polyfiber route all
the way. I even covered the strut fairing with fabric, where the
tubes come together.
Call me anal, but I'd rather read the instructions and follow them,
as they probably know best. Yeah, they probably make some sales this
way, but the method is proven.
Lynn Matteson
flying w/475+ hrs
On Mar 1, 2008, at 10:22 AM, patrick reilly wrote:
| Quote: | Lynn, What about priming PVC with a 2 part epoxy primer before
Do not archieve
Pat Reilly
Mod 3 Rebuild
Rockford, IL
> To: kitfox-list(at)matronics.com
> plastic/PVC.
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
> flying w/475+ hrs
primer?
> > Thanks!
> > Read this topic online here:
http://www.matronics.com/Navigator?Kitfox-List_-
============================================================ _-
forums.matronics.com_-
contribution_-
N369LM |
Lynn Matteson
Posted: Sat Mar 01, 2008 8:23 am Post subject: Painting PVC Struts |
Nope, no attack. Apparently the polytak dries so quickly that it
doesn't dissolve the PVC...worked for me. And once the fabric is on,
and covered with 'brush, nothing seeps through the fabric to get to
the PVC. You might try dipping a little piece of PVC into the 'tak
and see, but in actual application, the PVC isn't subjected to the
really wet 'tak for very long.
Lynn Matteson
flying w/475+ hrs
On Mar 1, 2008, at 10:26 AM, patrick reilly wrote:
| Quote: | Lynn, How did you attach fabric to PVC? All of the Poly Fibre
attack the PVC?
Pat Reilly
Mod 3 Rebuild
Rockford, IL
> plastic/PVC.
> Lynn Matteson
> flying w/475+ hrs
primer?
> > Thanks!
contribution_-
N369LM |
JohnA
Posted: Sat Mar 01, 2008 11:22 am Post subject: Painting PVC Struts |
A number of years ago when I built a Challenger II, I painted all the
metal, fiberglass, and PVC parts just that way. Shoot 2-part epoxy
primer and then the polytone while the epoxy was still tacky.
You have to then be patient, because the epoxy seems to take a long time
(more than a week) to fully set up. During the setup, the polytone is
very soft and subject to scratching. The results were well worth the
effort though. The polytone bonded nicely with the epoxy and resulted
in a very durable finish that exactly matched the fabric. I never had
any flaking or other problems with the polytone lifting off the epoxy.
I'll be using that method when I start on my Kitfox.
John Alexander
Woodland, CA
Lynn Matteson wrote:
treated this way, you can rivet them on, and then shoot the whole wing
So in your case, I'd shoot with the Polyfiber 2-part epoxy primer, and
while still tacky, shoot with the polytone, but I'd be sure and use
the way. I even covered the strut fairing with fabric, where the tubes
come together.
Call me anal, but I'd rather read the instructions and follow them, as
they probably know best. Yeah, they probably make some sales this way,
Lynn Matteson
flying w/475+ hrs
> Do not archieve
> Pat Reilly
> Mod 3 Rebuild
> Rockford, IL
> > plastic/PVC.
> > Lynn Matteson
> > flying w/475+ hrs
> > > Thanks!
_________________ John Alexander
Woodland, CA |
Lynn Matteson
Posted: Sat Mar 01, 2008 12:55 pm Post subject: Painting PVC Struts |
Good idea, John. It kills me to have to soak the epoxy primer for 7
days at 70°, but that's what they recommend, and I followed it to the
letter. Good thing I was painting mostly in the summer, but I moved
the painted stuff into the smaller, warmer shop for the long heat
soak period in the cooler months.
By the way, John, I lived for almost 22 years in Davis, Dixon and
Esparto, CA, all near Woodland, leaving in 2001. I learned to fly RC
models at the Woodland/Davis field...on Pole Line Rd/ Rd 101, was it?
Lynn Matteson
flying w/475+ hrs
On Mar 1, 2008, at 1:56 PM, John Alexander wrote:
<alexandj(at)preachain.org>
the metal, fiberglass, and PVC parts just that way. Shoot 2-part
epoxy primer and then the polytone while the epoxy was still tacky.
time (more than a week) to fully set up. During the setup, the
polytone is very soft and subject to scratching. The results were
well worth the effort though. The polytone bonded nicely with the
epoxy and resulted in a very durable finish that exactly matched
the fabric. I never had any flaking or other problems with the
John Alexander
Woodland, CA
N369LM |
wadegreaves
Posted: Sat Mar 01, 2008 9:39 pm Post subject: Re: Painting PVC Struts |
Thanks for the input! I think I'll try scuffing it, nailing it with 2 part, then spritzing it with polytone. The drying time will force me to work on other things!!!
S7 coming along. All covered and painted (I know, I know, there are always things that need to be painted still...) and it looks great. Used Brian Sorensen's Bearhawk's secret green recipe (from cover of Sport Aviation a few months back) and put on the quasi-military markings. Have my father's old P-3 squadron insignia on the tail (Neptune's Trident). It looks "NASTY"....Lotsa fun!.
Thanks again!
