jpspencer(at)cableone.net Guest
Posted: Sun Mar 02, 2008 4:15 pm Post subject: 701 Fuel Caps leaking |
Those with flying 701's
Have you had a problem with your fuel caps leaking and if so what did you do for a fix? I have tried about a half dozen different gaskets and no success. Believe now that the fuel may be getting between the cap and the doubler inside it and then sucking out.
Thanks Joe
n801bh(at)netzero.com Guest
Posted: Sun Mar 02, 2008 6:08 pm Post subject: 701 Fuel Caps leaking |
Joe. On my 801 the fuel caps leaked on the very first flight and stained my Dupont Imron 300 bucks a gallon aircraft paint. I was not a happy boy......... The 701/ 801 wings are a very high lift airfoil and thus has alot of low pressure on top of the wing. If my tanks are 3/4 or more full they would leak through the caps by way of the vent system built into them. Luckily I had made provisions to vent all of my tanks from below the wing where high pressure exists. All I did was to epoxy up the vent holes in the caps and my issue went away. The other simple way is to solder on some forward facing vent tubes onto your caps so they will slightly pressurize your tanks and stop the caps from siphoning out the fuel. I am guessing your problem only happens at full tanks??
Ben Haas
N801BH
www.haaspowerair.com
Thanks Joe
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
www.matronics.com/contribution
_____________________________________________________________
Click now to find a divorce attorney near you!
stepinwolf
Posted: Sun Mar 02, 2008 7:11 pm Post subject: Re: 701 Fuel Caps leaking |
On more then one occasion, I have seen photos of forward facing vent tubes that are part of the gas cap. As the previous post ( Ben ) explains, it serves to increase the inner tank pressure, there by eliminating the fuel leakage or siphoning from the fuel cap.
Would I be correct in assuming that with this type of forward facing vents, there most certainly would be some water ingested into the fuel tanks, were the plane to fly through low level clouds, or some rain showers.
Bob the 701 scratch
_________________ Long wing + vga's, = lo & slo |
Posted: Sun Mar 02, 2008 7:47 pm Post subject: 701 Fuel Caps leaking |
Ben
Thanks for the reply. I brazed on forward facing 3 inch high fuel vent tubes while building the plane. I don't believe that's the problem...am thinking it's maybe more of a problem with the double walled fuel caps supplied by Zenith in the kit...the fuel may be getting between the 2 parts of the cap and then getting sucked out regardless of gasket integrity???You are correct in that it only happens when near full.
Thanks again
Joe
JohnDRead(at)aol.com Guest
Posted: Sun Mar 02, 2008 8:33 pm Post subject: 701 Fuel Caps leaking |
I heard that Zenith will modify the fuel tank caps to add the vent tubes, if you ask nicely.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 3/2/2008 7:09:53 P.M. Mountain Standard Time, n801bh(at)netzero.com writes:
Joe. On my 801 the fuel caps leaked on the very first flight and stained my Dupont Imron 300 bucks a gallon aircraft paint. I was not a happy boy........ The 701/ 801 wings are a very high lift airfoil and thus has alot of low pressure on top of the wing. If my tanks are 3/4 or more full they would leak through the caps by way of the vent system built into them. Luckily I had made provisions to vent all of my tanks from below the wing where high pressure exists. All I did was to epoxy up the vent holes in the caps and my issue went away. The other simple way is to solder on some forward facing vent tubes onto your caps so they will slightly pressurize your tanks and stop the caps from siphoning out the fuel. I am guessing your problem only happens at full tanks??
Ben Haas
N801BH
Thanks Joe
f="http://www.matronics.com/Navigator?Zenith-List">http://www.matronics.com/Navigator?Zenith-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
Posted: Sun Mar 02, 2008 10:09 pm Post subject: 701 Fuel Caps leaking |
I think you are correct in determining that the issue is the area where the double walls are.
Ben Haas
N801BH
Ben
Thanks again
Joe
tronics.com
vgstol(at)bigpond.net.au Guest
Posted: Mon Mar 03, 2008 12:45 am Post subject: 701 Fuel Caps leaking |
That's exactly right Joe. Need to solder or epoxy those little holes inside the cap.
JG
rroberts
Joined: 04 Sep 2006 Posts: 50 Location: Birmingham, AL USA
Posted: Mon Mar 03, 2008 3:35 am Post subject: Re: 701 Fuel Caps leaking |
I'll take two of those modified caps if anyone knows where to get them. ZAC just emailed me back saying they couldn't provide the part??
_________________ Low & Slow
Rick
www.n701rr.com
www.ricksplace.info |
John Bolding
Posted: Mon Mar 03, 2008 4:49 am Post subject: 701 Fuel Caps leaking |
Hi Joe, How's tricks in Miss.?? seal up the cap halves with proseal , had to do that on a Pacer once. John
Posted: Mon Mar 03, 2008 5:03 am Post subject: 701 Fuel Caps leaking |
Of course that vent tube brazed to the top of the cap needs to go through the inner portion of the cap as well, then the original holes in that inner layer are plugged.
Those caps with that original venting system are only suitable for a filler neck that's well above the fuel level, like in a car gas tank. If the fuel sloshes up against the cap, like it will do in a full aircraft tank, they will leak.
The new vent tube only needs to be 1/8" bore, and three inches high is enough to prevent fuel sloshing up and out. Bent so it's facing forward pressurizes it very slightly and prevents it from sucking fuel out. Bend it so that the very front is a bit down and then rain doesn't get in. There's no airflow as such into the tube, just enough to replace fuel volume used and release fuel vapour pressure.
JG
