Posted: Tue Mar 04, 2008 12:29 pm Post subject: 601 HDS where to position the pitot and aileron trim |
Hi Peter,
The things I considered for the trim tab were, is it easy to repair or
resize. The one I have is very effective, so
it's hardly noticed when you begin flying and or have people walking the
plane. Simple.
The pitot was mounted on a disk and attached just forward of the spar,
first spar hole outside the leading edge tanks.
http://www.macsmachine.com/images/wing/pilelerouting/full/Pitot-number-2-(2).gif
http://www.macsmachine.com/images/wing/pilelerouting/full/pitot-&-electrical-standoff.gif
Seems steady enough and is easily inspected. Added access port Tees
within the wing joint for checking the
transponder and altimeter.
Peter Barthold wrote:
Hello fellow Listers
I'm about to finish the left outer wing panel of my HDS.
Does any of the gents here know where to position my pitot tube?
I intended to place it just outboard of rib #7 behind the main spar. Does that sound reasonable?
Same question with the aileron trim tab. I intend to place it between rib #8 and#9. Is there any advantage/disadvantage between a recessed style Trim tab and a board (like on Larry Mc's website) ?
Thanks and greetings from Germany
Peter
HDS TD
Tail complete, Wings in Progress
www.petersprojekt42.de
http://forums.matronics.com/viewtopic.php?p=167666#167666
