dlm46007(at)cox.net Guest
Posted: Sat Mar 22, 2008 1:04 pm Post subject: weight |
Just weighed N46007 and the result is 1630. arm was 109. [quote][b]
LarryRosen
Posted: Sat Mar 22, 2008 2:04 pm Post subject: weight |
Dave, nice job
would you add some details.
Wheel fairings
paint
interior
engine choice
prop choice
etc.
Also you should submit this info to the RV weight and balance database
<http://www.rvproject.com/wab/>
Larry
David McNeill wrote:
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Sat Mar 22, 2008 4:19 pm Post subject: weight |
Wheel pants and fairings included, no paint yet but will weigh again after
paint (Matterhorn white Jetglo and Maroon trim.
Engine is IO540D4A5 from Vans, Hartzell blended prop
Seats are ultra leather on the astronaut couch green. Four point inertial
belts: two are back of the Boeing style and two are flight deck rotary
buckles.
Dual Chelton displays, SL30, G327, Digiflite VSGV (switch able between
Chelton, GRT or stand alone). GRT EIS 6000, PM6000 intercom. GRT Sport EFIS
with moving map for backup and the primary XM weather display.
apilot2(at)gmail.com Guest
Posted: Sat Mar 22, 2008 4:47 pm Post subject: weight |
Any thoughts as to the wide range of c.g.s shown on
<http://www.rvproject.com/wab/> and where yours came out?
buckles.
Posted: Sat Mar 22, 2008 5:15 pm Post subject: weight |
The only explanation I have is that the front seats were aft; secondly some
are using different datum. I would expect that the empty weight and arm
would come out near the forward limit which is 107.84 to my understanding;
aft limit is 116.24 using the datum in the instructions; hence my empty arm
is 109.13. The forward seats are adjustable forward by at least six inches.
robin1(at)mrmoisture.com Guest
Posted: Sat Mar 22, 2008 7:57 pm Post subject: weight |
Way to go David!
Do you have any photos of your seatbelt arrangement? I have to make a
belt choice real soon.
Since you are at it a Panel shout would be cool too.
Robin
Posted: Sat Mar 22, 2008 8:20 pm Post subject: weight |
Will send a couple of pics tomorrow, the computer that contains the current
ones is on its way to be repaired.
