Posted: Sat Mar 22, 2008 7:30 am Post subject: Aileron counterweights |
Kolb guys,
Do any of you guys have any insight on how I should make aileron counterweights?
I'm at the point where I need to install them, now. My wings are completely finished,
and ready for fabric. I'd like to do the counterweights next, and my manual doesn't
address this subject, as I recall.
Specifically, what is the main objective, when making the ailerons balanced (other
than the obvious!!)? Like...do you balance them WITHOUT the push-rod hooked up?
Or, are they balanced in flying configuration, with the push-rods hooked up?
Hints, pointers, and especially photos, would be greatly appreciated.
Mike Welch
MkIII
Watch “Cause Effect,” a show about real people makce=text_watchcause' target='_new'>Learn more. [quote][b]
planecrazzzy Guest
Posted: Sat Mar 22, 2008 10:12 am Post subject: Re: Aileron counterweights |
I balanced mine without being connected to the plane....
But later , I extended them about an inch and a half more....
Because when I'd be folding up....The aileron would "hang"
Maybe because of the "angle of the wing" compared to when I balanced
them the first time , the wing was flat...( Level )
ALSO, I adjusted the counter weight "AFTER" fabric and paint.....
Put the "tube" on now....But the balance rod LATER...
Gotta Fly...
Mike & "Jaz" in MN
Snowed in.....Workin on my Buttercup...
[quote="mdnanwelch7(at)hotmail.co"]Kolb guys,
Mike Welch
MkIII
Watch �Cause Effect,� a show about real people makce=text_watchcause' target='_new'>Learn more.
61.17 KB |
513 Time(s) |
59.98 KB |
521 Time(s) |
59.92 KB |
510 Time(s) |
JetPilot
Posted: Sat Mar 22, 2008 1:38 pm Post subject: Re: Aileron counterweights |
Mike,
Here is a good article on how to balance control surfaces.
http://www.fly-imaa.org/imaa/hfarticles/howto/v6-1-36.html
Also attached are some pictures of the aileron counter balances on my plane, as well as a MK III classic. If you need more detailed pictures of how they are attached into the aileron tubes, let me know and I will take some. After reading some reports of minor flutter in the Rudder of some Kolbs, I also counter balanced the rudder in much the same way as ailerons.
227.4 KB |
515 Time(s) |
238.32 KB |
509 Time(s) |
83.47 KB |
541 Time(s) |
Kolb MK-III Xtra, 912-S |
ElleryWeld(at)aol.com Guest
Posted: Sat Mar 22, 2008 2:17 pm Post subject: Aileron counterweights |
just like on Large aircraft I would think, Un hook all linkage and make the aileron balance on the hindgepoint
Ellery in Maine
In a message dated 3/22/2008 10:30:38 A.M. Eastern Standard Time, mdnanwelch7(at)hotmail.com writes:
Kolb guys,
Mike Welch
MkIII
Watch “Cause Effect,” a show about real people makce=text_watchcause' target='_new'>Learn more. | Quote: |
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Create a Home Theater Like the Pros. Watch the video on AOL Home.
