ronlee(at)pcisys.net Guest
Posted: Sat Mar 29, 2008 4:04 pm Post subject: Do AD's really apply? |
Regardless of who is right, it only makes sense to determine
if an AD is relevant to the safe operation of your aircraft. I
complied with the Vans -A Service Bulletin BEFORE it was
announced. I am of the opinion that if you stay on asphalt
or contract then you may determine that the SB is not relevant
to safe operation of your aircraft.
Ron Lee
Posted: Sat Mar 29, 2008 4:26 pm Post subject: Do AD's really apply? |
"contract" should be "concrete"
Sigh
rocketbob(at)gmail.com Guest
Posted: Sat Mar 29, 2008 4:28 pm Post subject: Do AD's really apply? |
George, it still seems that you haven't bothered to read FAR part 39. AD's apply to PRODUCTS, not type certificated aircraft. If your experimental aircraft has a PRODUCT installed that is covered by an AD, sure as the sky is blue and the night is black that you are required to comply with the AD.
I have a good friend who happens to be DAR #1, who's ratings and endorsements span across five pilot certificates. He has testified in 27 court cases or administrative law hearings on behalf of the FAA or against the FAA. He is 27-0 as an expert witness, and travels the world issuing CofA's for transport-category, warbirds, and expermentals. I would have to say he knows his stuff. I asked him if he knew of any enforcement actions related to non-compliance of AD's on experimental aircraft. His response: "Yes, it is quite frequent." More of his response:
"Read FAR 39. ADs are issued against "products" and not airworthiness
certificates. If an "aeronautical product" has been found to be a
hazard and
FAA issues an AD against it you must comply with the AD. It matters
not what type of Certificate of Airworthiness the aircraft has."
Bob Japundza
RV-6 flying F1 under const.
On Sat, Mar 29, 2008 at 5:58 PM, <gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com)> wrote:
[quote] Bob:
If you are a EAA member. Log In and use the search
for two letters AD. The first item will be, "Airworthiness
Directives & Amateur Built Aircraft." Click on that and
read. If you are not a member I'll send it to you.
Bob there is an air of prove it, I dare you; I don't
believe you? I don't like your tone. I am trying to
teach you, but if you are not listening, OK fine have
a nice day. I don't care to fight or convince you.
First its not hypothetical it's a FACT. The EAA
works with the FAA lawyers and are going to
Oklahoma and DC all the time. If you don't believe
them fine. I have not put up any "opinion", it is legal
fact that some how has blown your fuse. I am
OK if you disagree, but you have no facts to support
your opinion or refute.
The prove it part? To prove a negative is like saying
prove dogs can't talk. The only regulation you need to
meet is in the front of your experimental aircraft's log
book and there are no comments about AD's or any
other part of the FAR's except the ones noted.
Bob, prove AD's must be complied with. You can't. I have
read all the regs and talked to the lawyers on this matter,
have you?
Second there is no legal precedence, no lawsuits or
rulings from a judge. If you are foreseeing lawsuits
and violations you better comply with all your AD's
to be conservative.
QUOTE:
THIS AIRCRAFT IS AMATEUR BUILT AND
DOES NOT COMPLY WITH THE FEDERAL
SAFETY REGULATIONS FOR STANDARD
AIRCRAFT
Questions?
Your protest or challenge is prima facie ridiculous. No
proof is needed. Prove it to yourself. Part 23, 39, 43
and so on don't APPLY! Next you will tell me I
need a A&P to work on my RV.
I gave you the references and you should do your own
research and evaluation. I can't do it for you. You will
never believe me. I did the leg work and called the
EAA and read the Regs. If nothing I said makes sense
to you or rings a cord of truth, I'm not going to
convince you. No hard feelings. Fly safe.
The idea of less or no government nanny state hand
holding, especially aviation, blows people away and
they can't deal with it.
There is no mechanism to MAKE amateur built
experimental planes comply with AD's, except urban
legend and a few FAA/DAR's CYA'ing because it
can't hurt and gives them the feeling of job security.
To be fair, I have been in that position and have not
want to sign something off, certification documents,
analysis or a part 121 flight plan.
Now you tell me how AD's work? You can't. There is
no link to experimental. The Gov is busy trying to
change that, as if other things where not more
important.
Individual news letters from individual FSDO's don't
mean squat; often they are wrong and become a
source of controversy. One FSDO in the middle of no
where wrote a news letter and said AD's apply many
many yrs ago and it floats around. It is wrong. This is
where the EAA lawyers talking to the FAA lawyers
come in. This is not a debate or controversy, its a fact.
Believe what you want, I am OK with that.
I'm not saying you should disregard any or all AD's
out of hand. However if the Ref EAA article is not
good enough for you (I assume you are a member)
and talk to legal they will tell you all the references
and reasons. You apparently don't have trust in my
comments. That is OK, you should research it. Make
yourself happy, all the best.
George
>From: "Bob J." <rocketbob(at)gmail.com (rocketbob(at)gmail.com)>
>Subject: Re: Re: Do AD's really apply?
>Cite the FAR that says AD's only apply to type
| Quote: | certificated aircraft. No references to EAA's site, no
personal opinion, just show us where it says
experimentals are exempt from AD's. Lets see how
>well your argument hypothetically would hold up in
| Quote: | Regards,
Bob Japundza
">Blockbuster Total Access for one month at no cost. [b]
hooverra(at)verizon.net Guest
Posted: Sat Mar 29, 2008 5:18 pm Post subject: Do AD's really apply? |
FAA Form 8130-6, Application for U.S. Airworthiness Certificate Includes the following certification in section III B Certification Basis. In the EAA’s guidance for this form they recommend that the current “AD revision number” be included as well as the compliance block checked. This adds further evidence that AD’s need to complied with (not that any more was required) just another data point.
AIRWORTHINESS DIRECTIVES (Check if all applicable AD's are compiled with and give the number of the last AD SUPPLEMENT available in the biweekly series as of the date of application)
Ralph & Laura Hoover
RV7A N527LR (reserved and registration application filed)
Ready for transport to the airport for final assembly.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bob J.
Sent: Saturday, March 29, 2008 7:25 PM
To: rv-list(at)matronics.com
hazard and
Bob Japundza
Bob:
have you?
to be conservative.
AIRCRAFT
Questions?
important.
George
>court.
>Regards,
>Bob Japundza
0123456789012
cjensen(at)dts9000.com Guest
Posted: Sun Mar 30, 2008 12:18 am Post subject: Do AD's really apply? |
Would somebody please give gmcjet his meds..
Chuck
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sun Mar 30, 2008 4:07 am Post subject: Do AD's really apply? |
Question to the DO advocates
Have been monitoring this discussion and I think I'm becoming a believer. However, I have an AB experimental plane that I built 20 years ago. The only "aeronautical product" in it. that I can think of, is the airspeed indicator and the altimeter. How does compliance to ADs apply to this airplane or make it safer?
I do want to know if there is a flaw in a product. But, isn't it up to me, and my responsibility, to decide if I want the product in my airplane, with or without the flaw, just like it was when I put the product in the airplane when I originally built it? I have high compression pistons in the O-360 (Lycoming rebuilt by AeroSport Power) in my RV-6A. I don't think Lycoming approves of that. Is there an AD that says I can't have the high compression pistons? Isn't that why I got a 40 hour Phase I when the data plate says it is a Lycoming O-360?
Is the engine the 'product' or are the pistons the 'product'?
Trying to understand this AD thing.
Dale Ensing
RV-6A N118DE
[quote]"Read FAR 39. ADs are issued against "products" and not airworthiness
hazard and FAA issues an AD against it you must comply with the AD. It matters
Bob Japundza
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
khorton01(at)rogers.com Guest
Posted: Sun Mar 30, 2008 5:10 am Post subject: Do AD's really apply? |
You need to read the applicability statement of each AD to see exactly
what it applies to. An AD could, in theory, be written against
specific part number high compression pistons, produced in a certain
range of dates, because it was discovered that an error was make
during manufacturing that could lead to piston failure.
Kevin Horton
On 30-Mar-08, at 08:03 , Dale Ensing wrote:
| Quote: | Question to the DO advocates
Dale Ensing
RV-6A N118DE
It matters
Bob Japundza
robertrv607(at)yahoo.com Guest
Posted: Sun Mar 30, 2008 5:29 am Post subject: Do AD's really apply? |
--- RALPH HOOVER <hooverra(at)verizon.net> wrote:
| Quote: | I HAVE SEEN THIS FOR A LONG TIME, PEOOPLE ASK A
QUESTION, ONLY BECAUSE THEY WANT TO ARGUE WITH YOU,
THEY REALLY DO NOT WANT AN ANSWER....
PEOPOLE DO WHA THEY WANT TO DO.... NOT WHAT THEY
SHOULD DO....
EVERY TIME VAN'S PUBLISH, A ADVISORY,? A.D?
YOU SEE THESE PEOPLE, START THE ARGUMENT...
LETS IGNORE THEM....I WILL COMPLY WITH EVERY ONE,
PERIOD.
BERT
Certification Basis. In the EAA's
current "AD revision number"
This adds further
evidence that AD's need to complied with (not that
filed)
assembly.
_____
Behalf Of Bob J.
ratings and
not airworthiness
found to be a
hazard and
AD. It matters
aircraft has."
Bob Japundza
<gmcjetpilot(at)yahoo.com> wrote:
Bob:
"Airworthiness
and
have
legal
saying
to
log
have
matter,
have you?
to be conservative.
AIRCRAFT
Questions?
No
43
will
sense
security.
not
=== message truncated ===
Like movies? Here's a limited-time offer: Blockbuster Total Access for one month at no cost.
http://tc.deals.yahoo.com/tc/blockbuster/text4.com
jsflyrv(at)verizon.net Guest
Posted: Sun Mar 30, 2008 7:59 am Post subject: Do AD's really apply? |
Here is a link that covers this all very well and explains why an AD
does or does not apply to experimental aircraft.
It is a bit lengthy but read it all through for explanations.
http://starduster.aircraftspruce.com/wwwboard/messages/25960.html
Jerry
bert murillo wrote:
SHOULD DO....
PERIOD.
BERT
>This adds further
>filed)
>assembly.
> _____
>Behalf Of Bob J.
>ratings and
>not airworthiness
>found to be a
>hazard and
>AD. It matters
>aircraft has."
>Regards,
>Bob Japundza
>Bob:
>"Airworthiness
>and
>have
>legal
>saying
>to
>log
>have
>matter,
>have you?
>to be conservative.
>QUOTE:
>AIRCRAFT
>Questions?
>No
>43
>will
>sense
>security.
>not
n616tb(at)btsapps.com Guest
Posted: Sun Mar 30, 2008 9:22 am Post subject: Do AD's really apply? |
What a great article! Thanks Jerry!
[quote] --
Posted: Sun Mar 30, 2008 11:10 am Post subject: Do AD's really apply? |
On 30-Mar-08, at 11:54 , Jerry Springer wrote:
The 1998 legal opinion that is described in that article relies
heavily on the words "type design" that were present in FAR 39.1 back
when that opinion was written. Unfortunately, the FAA amended FAR
39.1 in 2002, removing the words "type design", so the whole basis of
that legal opinion became invalid.
Kevin Horton
rickpegser(at)yahoo.com Guest
Posted: Sun Mar 30, 2008 9:37 pm Post subject: Do AD's really apply? |
Guys:
leave it up to me to stir up a hornets nest. I had hoped to inform others in the field what we are seeing with log books from the experimental side of the industry. but for some reason this has expanded into a pissing match.
as per "das fed" Ad's do apply to all experimental aircraft but the failure to comply with an ad is not enforceable due to the fact that the repairman are not required to have an up to date ad list .
this does not apply to a+p's or i/a that are doing conditional inspections as we are required to have an up to date ad information. and are supposed to have been trained in ad research.
airframe:
now why is there no vans rv-9 ad's, because vans has never built a aircraft, they are all joe smith model vans rv-9, and since there is only one aircraft out there and since the ad probably means that that one is now only good for beer cans, it would make no sense to issue an ad for a "type" joe smith rv-9. so this solves the problem with airframe ad's. but vans has the service bulletins with respect to the parts that you used to assemble your aircraft. If the guy that built the part for your airplane tells you that it is screwed and you don't replace it shame on you.
engine:
most rv are flying with some kind of type certified based engine. while these engine might still be certified or not, they are most probably built using mostly certified parts. when these parts have problem ad's are issued for them and they apply to your engine if you have them installed.
appliance's:
this the one that gets more i/a's in trouble then anyother type of ad. Let say you decide to use a lighting rheostat out of a piper, that lighting rheostat has a problem and likes to catch fire. but there is an ad for the piper and the ad lists all other installations then this ad applies to you as well, even if it does not you would be a fool not to change it.. Radios and stc's make it tough for the i/a to find all the ad's applicable to the aircraft. so understand when you first go to a new i/a with a highly modified aircraft, it will cost you for us to confirm the status of your ad complience. And there is a chance that we will miss one. We are human too.
rick m
">No Cost - Get a month of Blockbuster Total Access now. Sweet deal for Yahoo! users and friends. [quote][b]
aerokinetic(at)sbcglobal. Guest
