Lynn Matteson
Posted: Sun Mar 30, 2008 8:30 am Post subject: Bing carbs |
Has anybody found the need to change the diaphragm in their Bing
carbs? I just started to have a mid-range fuel problem, and I'm
wondering if it could be the problem. The history is that I changed
the needle jet from 2.76 to 2.78, and the rpm's around 1500-2000
became sluggish and it would die. This is during a ground run-up.
Going back to the 2.76 jet didn't help, and it probably shouldn't
have. If I pull the "choke" on, it helps to get through this "mid-
range crisis" and will rev up to 2750, the normal static WOT for me
in these atmospheric conditions.
So it seems like it is lean, and in want of more fuel as shown by the
better performance by applying choke, but nothing else has changed to
cause it to become lean, or am I overlooking something?
Lynn Matteson
flying w/480+ hrs/down for annual
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
akflyer
Posted: Sun Mar 30, 2008 10:45 am Post subject: Re: Bing carbs |
Make sure the jets do not have any blockage. if you go up or down on the jetting and it does not change, that would point towards a blockage in the circuit. A fine piece of wire may do it for you.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Lynn Matteson
Posted: Sun Mar 30, 2008 11:46 am Post subject: Bing carbs |
Thanks Leonard, but I'm pretty confident there's no blockage or dirt
in the jets that I just changed. In all the carbs I've dealt with,
I've never seen a carb as clean as this carb...nothing but pretty
blue 100LL in the bowl. All jets are clean clear through. The
perplexing thing is that the engine was running fine, but I wanted to
get the EGT's down a few degrees, so I went up to the next size
needle jet, and it balked at running in the mid-range, so I went back
to the original jet, and it still balked. Obviously I screwed
something up in the mid-range transition area of the carb, but this
thing is so wonderfully simple that it's hard to see what could have
gone wrong. I can't wait until Bing opens it's phone lines tomorrow
so I can get some suggestions.
Lynn Matteson
DO NOT ARCHIVE
Leonard Perry
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
95% complete
http://forums.matronics.com/viewtopic.php?p=173706#173706
N369LM |
samscycles(at)juno.com Guest
Posted: Sun Mar 30, 2008 12:58 pm Post subject: Bing carbs |
Make sure you don't have a vacume leak near the carb fittings. You can spray some carb cleaner around the fittings and listen for a change in engine if the fittings are leaking.
_____________________________________________________________
Save thousands on a Veterinary Program - Click here.
patreilly43(at)hotmail.co Guest
Posted: Sun Mar 30, 2008 1:54 pm Post subject: Bing carbs |
Lynn, Someone already mentioned it, But are you sure you aren't leaking air in around the carb boots. Also, you mentioned "diaphram" I have never been in a bing carb, at least not since I fooled with BSA's 100 years ago, but an early Honda interceptor gave me fits because I was't gluing the diaphrams down in the carbs that I had cleaned and was distorting them when screwing the carb top back on. I don't know, maybe?
Pat Reilly
Quote: | From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: Re: Bing carbs
Date: Sun, 30 Mar 2008 15:39:29 -0400
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
> --> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
> DO NOT ARCHIVE
> Leonard Perry
> Soldotna AK
> Avid "C" / Mk IV
> 582 IVO IFA
> Full Lotus 1260
> 95% complete
kitfoxpilot(at)msn.com Guest
Posted: Sun Mar 30, 2008 4:36 pm Post subject: Bing carbs |
Quote: | To: kitfox-list(at)matronics.com; jabiruengines(at)yahoogroups.com
Subject: Bing carbs
Date: Sun, 30 Mar 2008 12:26:43 -0400
Lynn Matteson
flying===============
Hi Lynn, Ray Gignac here and I just had both of my carbs cleaned and overhauled at Lockwood, and the diaphram was not replaced! if it is not cracked torn or dryrot it's ok. I did have a few bad O-rings!!
Ray
In a rush? Get real-time answers with Windows Live Messenger. [quote][b]
Lynn Matteson
Posted: Sun Mar 30, 2008 5:11 pm Post subject: Bing carbs |
Well, the boot looks good at this time. And the fact that this
problem just started when I swapped jets makes one think that's the
area to be looking for the cure. The diaphragm is not glued in my
carb, and this is the first time I've been into the carb this far. I
will get the lowdown on the carb tomorrow, I hope, when I talk to the
techs at Bing. I'm not sure, but it seems like a test of some sort
could be performed on the diaphragm without the spring in place,
letting you know whether or not the diaphragm was able to hold air
without leaking. Just for the record, there is a spring that holds
the diaphragm and the sliding piston in its lowest position. It seems
to me that if this spring was removed temporarily, a test could be
made to show the "health" of the diaphragm. It seems like I read
somewhere that the diaphragms need to be glued in, but not sure.
I'm hoping to buy the DVD that Bing sells on overhauling the CV
carbs. I only hope it's better than the aircraft carb tuning and
parts manual I bought....dark pictures with arrows that point into
the picture, supposedly showing a particular part, but the arrow gets
lost in the dark picture, so you don't know where it's pointing. And
it was mostly geared toward ultralight carbs...very little on the CV
carbs.
I see that Bing offers a service of correcting distortion in certain
parts, so this must be a common problem.
Lynn Matteson
On Mar 30, 2008, at 5:49 PM, patrick reilly wrote:
Quote: | Lynn, Someone already mentioned it, But are you sure you aren't
Pat Reilly
> Subject: Re: Re: Bing carbs
wanted to
back
> Lynn Matteson
> Kitfox IV Speedster w/Jabiru 2200
> > DO NOT ARCHIVE
> > Leonard Perry
> > Soldotna AK
> > Avid "C" / Mk IV
> > 582 IVO IFA
> > Full Lotus 1260
> > 95% complete
> > Read this topic online here:
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
N369LM |
kerrjohna(at)comcast.net Guest
Posted: Sun Mar 30, 2008 6:17 pm Post subject: Bing carbs |
Lynn, did you disassemble the carb from the top or just change the main jet from the bowl?
If from the top is is critical that the diaphra be oriented properly with the index nub properly seated in the appropriate indentation.
Applying the enrichener for improvement does speak to being lean for some reason.
Sorry not to be more helpful
John Kerr
912ul, rotek 3600 with 40mm Bing
-------------- Original message ----------------------
carbs.
Lynn Matteson
> do not archive
> Pat Reilly
> wanted to
> back
> > Lynn Matteson
> > > DO NOT ARCHIVE
> > > Leonard Perry
> > > Soldotna AK
> > > Avid "C" / Mk IV
> > > 582 IVO IFA
> > > Full Lotus 1260
> > > 95% complete
> contribution_-
Lynn Matteson
Posted: Sun Mar 30, 2008 6:44 pm Post subject: Bing carbs |
Hi Ray-
Jeez, you must have bucks to burn, getting Lockwood to do the work. : )
I'm probably not going to find any fault with my diaphragm, but in
the "Bing Carburetors Aircraft Tuning and Parts Manual", on the page
where they talk about "recommendations and tips on CV carbs" the
first thing they say is "You should replace the diaphragm in your CV
carb every two years regardless of hours." This may be to sell some
parts, but it may be good advice. My diaphragm looks perfect, but if
there were invisible pinholes, now would be good time to change it,
even at $60 a pop! At this point, I'm willing to throw good money
after a cure for my carb woes. It just takes too much effort to get
at my carb to remove it, and I'd like to know it's right when it goes
back in.
The timing couldn't have been worse for this problem to come up,
wanting to leave later this week for Sun 'n' Fun. : (
Lynn Matteson
On Mar 30, 2008, at 8:33 PM, RAY Gignac wrote:
> carbs?
> Lynn Matteson
Quote: | Hi Lynn, Ray Gignac here and I just had both of my carbs cleaned
rings!!
Ray
N369LM |
Lynn Matteson
Posted: Sun Mar 30, 2008 7:04 pm Post subject: Bing carbs |
Hi John-
After this problem came up, I pulled the carb off the engine and went
into the top to see what shape the diaphragm was in...it looks great.
It wasn't the main jet that I changed, but the needle jet. This is
the "cruise jet" more or less. It's the one that sits just above the
main jet on what they call the Mixing Tube (a/k/a Jet Stock), and
it's the one that the needle slides in and out of, changing the mid-
range mixture. I had read earlier that there was a tab that must be
oriented correctly into the indentation, and of course it was. If
this were to be assembled out of line, I'd think that a vacuum leak
would exist, and running the engine might not happen...not well anyway.
I've also heard of gluing this diaphragm in place, but this wasn't
done on my carb that I could detect anyway. I'll get Bing's take on
this practice, unless somebody can tell me otherwise.
Right now I've got the carb sitting in front of a picture of Dale
Earnhardt, hoping that the Intimidator's glare will whip the carb
into shape. : )
What have you got the Rotec in, John? A Kitfox? I met Joe Meyeres
from Olathe, KS at last year's Oshkosh, and he has a 7 cyl Rotec in a
'fox. I just googled his site:
www.rotecradialengines.com/customers/joemeyeres.htm
Lynn Matteson
indentation.
for some reason.
John Kerr
> carbs.
> Lynn Matteson
>> do not archive
>> Pat Reilly
>>> dirt
>> wanted to
>> back
>>> have
>>> Lynn Matteson
>>>> DO NOT ARCHIVE
>>>> Leonard Perry
>>>> Soldotna AK
>>>> Avid "C" / Mk IV
>>>> 582 IVO IFA
>>>> Full Lotus 1260
>>>> 95% complete
>> contribution_-
N369LM |
Catz631(at)aol.com Guest
Posted: Mon Mar 31, 2008 4:56 am Post subject: Bing carbs |
Lynn,
I attended the Lockwood school in Jan. We tore a carb completely apart and reassembled it as part of the school. The diaphragm is normally replaced do to time on the rubber part.(unless damaged of course) I replaced my diaphragms when I returned home from the school. The old ones appeared fine so I really doubt they needed it. I remember from the class that it is really easy to get the cast rubber protrusion on the diaphragm out of alignment with the corresponding slot in the carb casting. You have to hold it in the slot with your thumb while you assemble the two halves. The diaphragm is NOT glued down in any fashion.
I don't know if this relates to your problem but you might check, if you have to disassemble them. I know I replaced the needles (again do the time on the rubber tips) and ended up going back to the originals because of fuel spitting out of the intakes.(springs too strong on the new needles I think)
Please let us know what the problem was when you find it!
Thanks,Dick Maddux
Fox4-1200
Rotax 912UL
Pensacola,Fl
Create a Home Theater Like the Pros. Watch the video on AOL Home.
Posted: Mon Mar 31, 2008 5:43 am Post subject: Bing carbs |
Bad news, I called Bing about our Bing 64's, they said they will not work on the carbs used in aircraft, but will sell the parts to do your self.
Ray
Date: Sun, 30 Mar 2008 21:07:26 -0400
carbs.
Lynn Matteson
> do not archive
> Pat Reilly
> wanted to
> back
> > Lynn Matteson
> > > DO NOT ARCHIVE
> > > Leonard Perry
> > > Soldotna AK
> > > Avid "C" / Mk IV
> > > 582 IVO IFA
> > > Full Lotus 1260
> > > 95% complete
> ========== _-
> contribution_-
&g==
How well do you know your celebrity gossip? Talk celebrity smackdowns here.
Lynn Matteson
Posted: Mon Mar 31, 2008 6:24 am Post subject: Bing carbs |
I'll let you know, Dick. Right now I'm replacing fuel lines firewall
forward, and checking fuel flow before and after.
Yes, I see how that diaphragm could get out of the slot. I've had the
carb home here while I watched the race yesterday, just tinkering
with it and reading the Big manual. I'm gonna gt real well acquainted
with it before this problem is over. I'm also gonna try one of my old
float needles, just to try something else.
Lynn Matteson
Thanks,Dick Maddux
Fox4-1200
Rotax 912UL
Pensacola,Fl
www.matronics.com/Navigator?Kitfox-List _-
www.matronics.com/contribution _-
N369LM |
Lynn Matteson
Posted: Mon Mar 31, 2008 6:28 am Post subject: Bing carbs |
The Jabiru uses a CV carb, a 40mm, and sells the manual for aircraft
carbs, so they must know that they are being used. Or is it just the
64's that should not be used? No matter, they are sold to Jabiru as
an aircraft carb, and Rotax uses them as well...maybe not the 40mm,
but a CV carb just the same. Of course, the lawyers will deny that
they approve any part for aircraft use.
Lynn Matteson
On Mar 31, 2008, at 9:37 AM, RAY Gignac wrote:
Quote: | Bad news, I called Bing about our Bing 64's, they said they will
do your self.
Ray
the
seems
gets
> carbs.
> Lynn Matteson
carbs
> > do not archive
> > Pat Reilly
or dirt
with,
pretty
> > wanted to
> > back
but this
could have
tomorrow
> > > Lynn Matteson
or down
towards a
you.
> > > > DO NOT ARCHIVE
> > > > Leonard Perry
> > > > Soldotna AK
> > > > Avid "C" / Mk IV
> > > > 582 IVO IFA
> > > > Full Lotus 1260
> > > > 95% complete
> > ========== _-
> > contribution_-
&g==
smackdowns here._-
contribution_-
N369LM |
avidfox
Posted: Mon Mar 31, 2008 7:11 am Post subject: Re: Bing carbs |
Lynn,
Question: Is the carb you use the same as on a 64 used on the Rotax 912UL? I have not researched this.
If so, you could install one, or both, of mine for trouble shooting purposes. I don't anticipate flying much for a while....got some jobs to do.
About 80 hrs TT and working fine.
It would require a drive to Howell (OZW) airport, but you're a travlin' man.
Steve
84KF (at) OZW
Posted: Mon Mar 31, 2008 7:24 am Post subject: Bing carbs |
mid range has been the most challenging part of tuning the bings for me. have you tried raising the needle/lowering the circlip?
installing the R3600 in a Hatz Classic. almost done with the rough plumbing and wiring so I can drop the engine and cover the fuselage. I figure it will take about a year to finish up.
[quote]-------------- Original message --------------
[quote] --> Kitfox-List message posted by: Lynn Matteson
Hi John-
this were to be assembled out of line, I'd think that a vacuum leak [b]> would exist, and running the engine might not happen...not well anyway.
into shape. : )
Lynn Matteson
< BR>> ; > --> Kitfox-List message posted by: kerrjohna(at)comcast.net
> indentation.
> for some reason.
> John Kerr
> From: Lynn Matteson
& gt;> ; problem just started when I swapped jets makes one think that's the
>> somewhere that the diaphragms need to be glued in , but not sure.
>> carbs.
>> Lynn Matteson
>>> do not archive
>>> Pat Reilly
>>>> To: kit fox-li st(at)matronics.com
>>>> dirt
>>> wanted to
>>> back
>> >&g t; something up in the mid-range transition area of the carb, but this
>>>> have
>>>> Lynn Matteson
>>>>> Make sure the jets do not have any blockage. if you go u p or d own
>>>>> DO NOT ARCHIVE
>>>>> Leonard Perry
>>>>> Soldotna AK
>>>>> Avid "C" / Mk IV
>>>>> 582 IVO IFA
>>>>> Full Lotus 1260
>>>>> 95% complete
&g y List
Lynn Matteson
Posted: Mon Mar 31, 2008 9:51 am Post subject: Bing carbs |
For some reason the Jabiru mods to the carb include using a
"proprietary" needle, using just one groove. Later Service Bulletins
have you installing a 2-groove needle which is fatter at the top (low
range and idle) and a larger needle jet, to control EGT's a little
better.
I'm thinkin' positive that I will reinstall carb, light it up and
it'll be ready to fly! Perhaps God has different ideas though,
because it's foggier than hell here today. : )
Lynn Matteson
On Mar 31, 2008, at 11:20 AM, kerrjohna(at)comcast.net wrote:
Quote: | mid range has been the most challenging part of tuning the bings
> Hi John-
went
great.
leak > would exist, and running the engine might not happen...not
well anyway.
> into shape. : )
in a
> Lynn Matteson
> < BR>> ; >
> > indentation.
> > for some reason.
> > John Kerr
> > From: Lynn Matteson
that's the
far. I
to the
sort
air
holds
It seems
could be
into
arrow gets
pointing. And
the CV
> >> carbs.
certain
> >> Lynn Matteson
since I
carbs
carb
> >>> do not archive
> >>> Pat Reilly
> >>>> dirt
with,
pretty
> >>> wanted to
went
> >>> back
carb, but this
> >>>> have
tomorrow
> >>>> Lynn Matteson
or d own
towards a
you.
> >>>>> DO NOT ARCHIVE
> >>>>> Leonard Perry
> >>>>> Soldotna AK
> >>>>> Avid "C" / Mk IV
> >>>>> 582 IVO IFA
> >>>>> Full Lotus 1260
> >>>>> 95% complete
&g y List _-
N369LM |
Lynn Matteson
Posted: Mon Mar 31, 2008 10:03 am Post subject: Bing carbs |
Thanks for the offer, Steve, but I think the 64 is a different breed.
My carb ( a 94 CV) is the constant depression (does this describe the
way people feel who work on the damn things?) carb, also known as a
CV...don't ask me why, and the person I talked to at Bing didn't know
the connection. Suffice it to say that constant velocity and constant
depression mean the same thing to Bing. I got some good feedback from
Bing, including the diagnosis that my diaphragm is probably ok, and
there is no test, as I had hoped, to tell whether or not it was good
other than a visual, and that it did not "flop all over the place."
So I'm putting it back together, changing some fuel lines, and if all
goes well I'll report what I did.
Lynn Matteson
On Mar 31, 2008, at 11:11 AM, avidfox wrote:
Quote: |
Lynn,
jobs to do.
travlin' man.
Steve
84KF (at) OZW
http://forums.matronics.com/viewtopic.php?p=173888#173888
N369LM |
Posted: Mon Mar 31, 2008 12:07 pm Post subject: Bing carbs |
Lynn, There wasn't any glue on the Honda Interceptor carb diaphrams from the factoy either. But, I gave up took the bike to a dealer, and he said all he did was lightly rubber cement the diaphram to the carb body to avoid distorition of the diaphram when screwing the carb top back on. I don't know if that is what is happening. Maybe?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Sun, 30 Mar 2008 23:01:23 -0400
Hi John-
into shape. : )
Lynn Matteson
> indentation.
> for some reason.
> John Kerr
> From: Lynn Matteson <lynnmatt(at)jps.net>
>> carbs.
>> Lynn Matteson
>>> do not archive
>>> Pat Reilly
>>>> dirt
>>> wanted to
>>> back
>>>> have
>>>> Lynn Matteson
>>>>> DO NOT ARCHIVE
>>>>> Leonard Perry
>>>>> Soldotna AK
>>>>> Avid "C" / Mk IV
>>>>> 582 IVO IFA
>>>>> Full Lotus 1260
>>>>> 95% complete
>>> ========== _-
>>> contribution_-
&g======================
Lynn Matteson
Posted: Mon Mar 31, 2008 1:12 pm Post subject: Bing carbs |
Success! Or a least 99% certain of success. I haven't flown it yet,
but it looks promising. I ran it up after the fix, and it was a
marked improvement....I tried to force the throttle open quicker than
normal and it hesitated a bit but took the bait. It no longer just
quits. I was pushing it a bit quicker than normal, which was not a
fair test, but it was taking it.
Now for the cure....it seemed to be between two things....low float
level, maybe the wrong float needle. I had changed the float needle
and seat back in Dec., and had told Bing to send me the correct
needle for the 2.5 mm seat, and they sent me the light-springed
version. They are available in light, medium and heavy springs. The
light one worked right up until last week when I changed to the 2.78
mm needle jet, and that's where all this nonsense began. When I
changed back to the 2.76 mm needle jet, it still quit during mid-
range, so something had to be wrong other than the needle jets. Then
I started to change things. I changed float level and that didn't
help. What finally worked was going back to the medium spring on the
float needle, and setting the float level absolutely parallel to the
carb base...I had it much too low, but in my defense, I was setting
it by opening the fuel flow, and raising the float to shut off the
flow and noting the position of the float...this was with the carb on
the plane. Today, with the carb off the plane and inverted, I set the
float to be parallel to the base with the medium-spring needle, and
that's what worked. The real proof will come tomorrow, if the weather
is good enough for a flight.
Thanks for all the input, guys and gals. Like it says in the manual,
try one thing at a time or you won't know what cured the problem. If
I could accept that philosophy, I might make a better mechanic, after
being one for all these years. : )
Lynn Matteson
N369LM |
