vgstol(at)bigpond.net.au Guest
Posted: Tue Apr 01, 2008 6:23 pm Post subject: CH701 Door Warning |
[b]Reporting on an incident that could have had serious consequences...<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The CH701 was flying straight and level at 70 kts on a cross-country flight.
While reaching for a water bottle, the pilot accidentally snagged the left-hand inner door handle, releasing the door. The door instantly slammed up against the bottom of the wing, with such impact that the outer handle punched a hole through the wing skin. The pilot grabbed and held the door with one hand, and slowed the aircraft. But the front hinge had broken with the initial impact, causing the door to skew somewhat across the wind. The resulting force was so strong that the pilot couldn’t pull the door in again, even at 50kts. Eventually he had to let it go. When it went, it hit the horizontal stabilizer, causing considerable damage to the leading edge, breaking the left forward mounting bracket (7.H.2.6), and bending the right forward bracket. So the horiz stab was then somewhat skew to the fuselage.
The aircraft was still flyable, but with considerable drag and a left yaw bias. The pilot continued on to an airfield and made a successful landing.
For photographs and analysis have a look at
http://www.stolspeed.com/701-door-warning/
JG[/b]
n801bh(at)netzero.com Guest
Posted: Tue Apr 01, 2008 8:30 pm Post subject: CH701 Door Warning |
And this warning comes from the guy who swears by VG's. Funny this 701 was cruising at only 70 knots.....
JG[/b]
">http://www.matronics.com/Navigator?Zenith-List
tronics.com
www.matronics.com/contribution
_____________________________________________________________
Proven Hair Replacement Options. Click here.
Posted: Wed Apr 02, 2008 12:35 am Post subject: CH701 Door Warning |
There's now a follow-up on the door incident page at
[url=]http://www.stolspeed.com/701-door-warning/[/url]
JG
zodierocket(at)hsfx.ca Guest
Posted: Wed Apr 02, 2008 3:23 am Post subject: CH701 Door Warning |
Part I don’t understand is that I have opened the doors in flight several times and they have never flown up, they hover about 4 inches away from closed. Must be that laminar flow from the VG’s that ahs sucked all the air to the top of the wing. OK bad joke , but honestly I have never deemed them as a worry.
Mark Townsend Alma, Ontario
Zodiac 601XL C-GOXL, CH701
www.ch601.org / www.ch701.com/ www.Osprey2.com
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed Apr 02, 2008 7:33 am Post subject: Re: CH701 Door Warning |
Yup, and getting very good fuel economy while doing it!
[quote="n801bh(at)netzero.com"]And this warning comes from the guy who swears by VG's. Funny this 701 was cruising at only 70 knots.....
[b]Reporting on an incident that could have had serious consequences...<xml>
While reaching for a water bottle, the pilot accidentally snagged the left-hand inner door handle, releasing the door. The door instantly slammed up against the bottom of the wing, with such impact that the outer handle punched a hole through the wing skin.� The pilot grabbed and held the door with one hand, and slowed the aircraft. But the front hinge had broken with the initial impact, causing the door to skew somewhat across the wind. The resulting force was so strong that the pilot couldn�t pull the door in again, even at 50kts. Eventually he had to let it go. When it went, it hit the horizontal stabilizer, causing considerable damage to the leading edge, breaking the left forward mounting bracket (7.H.2.6), and bending the right forward bracket. So the horiz stab was then somewhat skew to the fuselage.
JG[/b]
tronics.com
[quote][b][/quot
_________________ “Always do what you are afraid to do.�
R.W. Emerson (1803-1882)
Dorothy McCune |
ruruny(at)aol.com Guest
Posted: Wed Apr 02, 2008 10:20 am Post subject: CH701 Door Warning |
Actually I have had a concern about this since my demo ride at the factory years ago.
We never opened the doors in flight, but while taxiing out we left them unlatched.
When Roger pushed in the throttle more the doors opened more. My door is attached with a
piano hinge the length of the top of the door, not a front or rear hinge.
I've always figured they would fly open as has happened in this incident. I thought about a safety pin
installed on the plate attached to the fuselage. Close latch, insert pin behind latch into plate.
Or just a blind A5 rivet in that same hole where the pin would go to make a detent.
How can a door on one plane fly up and another it not. The shape of the door is curved outward at the base of the
window, creating an airfoil which would cause it to fly open.
It would be a cool test in a wind tunnel. Thanks for the report on this.
Brian Unruh
http://www.701builder.com Get the MapQuest Toolbar, Maps, Traffic, Directions & More!
Posted: Wed Apr 02, 2008 6:45 pm Post subject: CH701 Door Warning |
I’m more than a bit concerned about the flippant and dismissive initial comments that could tend to deflect the attention of other aircraft owners and builders from a potential situation they should consider seriously.
None of us have deemed these doors a worry, but this incident shows the potential otherwise! It was a very close call to a real disaster, and not due to any fault in the aircraft involved or actions of the pilot – it could happen to any of us with similar construction doors.
At this point I must emphasize that I am very careful in all my work to not make any claims that aren’t backed by experience and preferably repeatable testing. If I state an opinion that’s just based on speculation or theory or hearsay, I always try to preface the statement to clarify that basis.
Many of us would have tried flying the door partially open, and found them to seem stable in the airstream. Further examination of the remains of the door, and speculation as to how such violent forces could develop that would rip the door in two, are very sobering because it demonstrates that the potential is always there for everyone.
Some understanding of aerodynamics, some understanding of structures, and common sense analysis leads me to the following speculations:
A practical demonstration would be to remember what it’s like to hold your hand outside the car window at road speed. Keeping it flat and parallel to the airstream it just floats, but increase the angle of attack just a little bit and it zooms up. Now imagine trying that experiment while holding a small flat plate at a speed of 80mph! The aerodynamics of a flat plate are such that at zero AoA the lift is zero, but a small increase in AoA generates an enormous lift instantly. Now extend that vision to a flat plat of the area of the door at 80mph and the lift would be enormous.
Now imagine taking a hammer and hitting the bottom of your wing as hard as you can – probably get a big ugly dent. The impact from this incident drove the outside door handle right through the wing skin! The door itself has very little mass, so the velocity must have been extremely high to generate enough momentum to cause that puncture!
The photo in the website below shows the remains of the door. It turns out that the front hinge didn’t break – the door frame broke at the front of the front hinge, and below the gas strut attach point on the rear, and tore the 2mm thick polycarb diagonally across.
I think that break just below the strut attach point is a key clue. The function of the gas strut is like a shock absorber, considerably slowing the movement of the door both up and down. These lightweight doors are very flexible, particularly in torsion. If a swirl of the slipstream got under the leading edge, forcing it up suddenly, the damping effect of the strut would cause the door to flex and increase the angle of attack considerably, thus increasing the lift force enormously. This is now an unstable situation where increasing flex of the door leads to increasing lift force which leads to increasing flex which leads to even more lift force........ This scenario would account for the evidence as I see it.
Going from a stable situation of the door just floating there, to a dramatic and violent episode can happen instantly, and without any warning! Please keep this scenario in mind whenever you consider having a door open to the slipstream!! It’s not a fault in the design of the 701 door, it’s just a fact of life, and also applicable to any other doors of similar design.
This morning I received feedback from someone who built a 701 about 7 years ago, and says that he remembers hearing of a very similar incident about that time, where the door ripped off and damaged the horiz stab, resulting in a crash landing that very much damaged the aircraft......
Does anyone else remember that incident??
There are now more photographs, and analysis of possible fixes and preventative measures at
graeme(at)coletoolcentre. Guest
Posted: Wed Apr 02, 2008 8:34 pm Post subject: CH701 Door Warning |
Thanks for the warning I for one took it in the manner it needed to be taken.
I could see the situation happening and am now aware of another thing to watch for.
Both my catches are quite firm but will make sure my passengers are aware don't touch door lock in flight.
Graeme Cns
david_a_g_johnson(at)btin Guest
Posted: Thu Apr 03, 2008 1:07 am Post subject: CH701 Door Warning |
It seems to me that this could be more of a problem with the optional bulged doors, which must form a pretty good airfoil trying to pull the door open.
Dave Johnson
601XL (so I don't really know what I'm talking about!)
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Apr 03, 2008 1:59 pm Post subject: Re: CH701 Door Warning |
Brian,
I've thought about this too.
And I appreciate Mr. JG bringing it to our attention.
Folks, as far as I know, Mr. JG is NOT trying to sell us a "fix" for this problem. I am looking at ways to lessen the potential for an in-flight door departure.
Tommy Walker in Alabama
N8701 44.8 Hours
Phase I Finished!
[quote="ruruny(at)aol.com"]Actually I have had a concern about this since my demo ride at the factory years ago.
Brian Unruh
_________________ Tommy Walker
N25A - Anniston, AL |
cgbrt(at)mondenet.com Guest
Posted: Sun Apr 06, 2008 4:06 am Post subject: CH701 Door Warning |
ricklach
Joined: 20 Jun 2006 Posts: 127 Location: Kernville, Calif.
Posted: Sun Apr 06, 2008 7:31 am Post subject: Re: CH701 Door Warning |
Hi John (JG),
I would like to thank you for your continuing effort to innovate changes in a proven design for the thrill and safety of flying, and then sharing the results with us. I’ve always thought the door assembly was a little light but never thought about the possible results of a mishap like Hans went through. I like your new latch solution. Could you please post some more photos on your web sight.
It’s always interesting to read your post.
Rick
Posted: Sun Apr 06, 2008 12:12 pm Post subject: CH701 Door Warning |
Gday Carl,
No this was the old style door. An early model.
They were very flexible. In the re-build Hans used .060 instead of .025 for the corner gussets, and that made a much stiffer and better feeling door.
Basically I think any door has this potential if the airflow catches it just wrong, then everything will change instantly.
Tailwinds always,
JG
Posted: Sun Apr 06, 2008 12:53 pm Post subject: CH701 Door Warning |
Thanks for your supportive comments Rick.
Those heavier gussets in the corners really made a big difference in the stiffness of the door. That was an early model door, and they are a little bit different from the later model in Hans own aircraft. In the early model there was a gusseted corner at the bottom of the trailing edge, whereas the later model has the tubing sweeping around a radius corner in one piece. That gusseted corner is the source of much of that flexibility.
The main part of that latch is pretty standard, but the sliding rod to the trailing edge is a new idea borrowed from a Rans S7. We still have to get it to work on the aircraft, which is a 6 hour drive away. I'll post more photos when it's fully installed.
Tailwinds always,
JG
