ihab.awad(at)gmail.com Guest
Posted: Thu Apr 03, 2008 12:39 pm Post subject: Zinc Chromate |
On Thu, Apr 3, 2008 at 2:16 PM, James E. Lanier <jim.lanier(at)charter.net> wrote:
http://www.google.com/search?hl=en&q=%22primer+wars%22
Ihab A.B. Awad, Palo Alto, CA
Posted: Thu Apr 03, 2008 12:53 pm Post subject: Zinc Chromate |
Hi James,
With Zinc Chromate inside the wing, you'll notice with some paints that
the yellow will bleed thru your primer. Not too much to cover with color
but problematic with semi-solid paints. During the wash, etch, prime, I
had a lot of difficulty with the yellow stain penetrating the white primer.
Perhaps that wouldn't be a problem if the Zinc Chromate was white too.
If not, I'd suggest you do a test coat under what you intend to prime with
outside the skins or find an epoxy prime that would coat and protect
your aluminum to avoid the hassle.
For most of 6061 alloys, you only need to prime the surfaces that make
contact with each other and light spray areas that could collect moisture.
Don't forget to drill the small drain holes in boxed surfaces, or your
wash-etch will never dry well, i.e., stabilizer etc.
James E. Lanier wrote:
Zn-Cr
First, does everyone do this on their kits? Do you only apply it only
to the contact surfaces, or the entire inner surfaces? I am looking
for pros and cons.
Jim
Posted: Thu Apr 03, 2008 1:02 pm Post subject: Zinc Chromate |
Being the now expert painter that I am.... I strongly suggest that if you
use zinc chromate primer that you seal it with a paint compatible product.
I didnt! I had bleed through and it took four coats to finally get it
stopped from bleeding. On the metal to metal joints the chromate works fine
but if you plan on painting for looks use an epoxy primmer.. AND be
absolutely sure its compatible with your finish coats....
SW
Steves Aircraft Painting Service.............NOT !
jim.lanier(at)charter.net Guest
Posted: Thu Apr 03, 2008 1:33 pm Post subject: Zinc Chromate |
Thanks. Just to make sure we are on the same page..I intend to use this
inside the wings, rudder, horizontal stab and not on the exterior
surface. What I am asking is whether or not to cover the entire interior
surfaces or just at the contact points.(.ie rib to skin)
Jim
you use zinc chromate primer that you seal it with a paint compatible
product. I didnt! I had bleed through and it took four coats to
finally get it stopped from bleeding. On the metal to metal joints
the chromate works fine but if you plan on painting for looks use an
epoxy primmer.. AND be absolutely sure its compatible with your
finish coats....
SW
tigerrick(at)mindspring.c Guest
Posted: Thu Apr 03, 2008 2:30 pm Post subject: Zinc Chromate |
Hi, Jim.
The way the quick build kits come is as you describe, with chromate ONLY between the metal mating surfaces.
Of course, you can chromate the whole interior, but the weight of the layers will add up. Some kit manufacturers do chromate other than contact areas, but this is generally limited to inaccessable areas on airplanes that carry a load.
My strategy was to just fog the unpainted areas of the interior of the fuselage, and the wings and stabilizers, with ACF-50 for corrosion protection (and repeated every year at inspection).
Since empty weight is so precious on LSA aircraft, I went for a partial exterior paint job as well.
Just my $0.02.
Rick Lindstrom
601 XL N42KP
agibeaut
Posted: Thu Apr 03, 2008 3:04 pm Post subject: Zinc Chromate |
I started the kit with Zn-Cr which was applied to only one surface. I did not like the potential health related issues and after reading dozens of opinions on this and other sites decided to switch to Self Etching Primer in a rattle can that I buy from NAPA Auto. I tested the stuff for resilience, and it is pretty good, and have used it throughout. I'm done with the tail, wings, and rear fuselage on my 701 and I have not regretted it. Just my opinion.
--- On Thu, 4/3/08, James E. Lanier <jim.lanier(at)charter.net> wrote:
| Quote: | From: James E. Lanier <jim.lanier(at)charter.net>
Subject: Zinc Chromate
To: "Zenith-List Digest List" <zenith-list-digest(at)matronics.com>
Date: Thursday, April 3, 2008, 4:16 PM
Lanier" <jim.lanier(at)charter.net>
Zn-Cr
apply it only to
looking for
pros and cons.
Jim
You rock. That's why Blockbuster's offering you one month of Blockbuster Total Access, No Cost.
http://tc.deals.yahoo.com/tc/blockbuster/text5.com
zenith-list(at)steensland Guest
Posted: Thu Apr 03, 2008 3:37 pm Post subject: Zinc Chromate |
Wicks is pushing Zinc Oxide now, so I got a few rattle cans of that to
try. I too worry about the longevity of my lungs breathing Zn-Cr so I'll
try this.
I have also heard good things about self-etching primer as well (albeit
a little more expensive than Zn oxide).
Art Gibeaut wrote:
> Zn-Cr
> apply it only to
> looking for
> pros and cons.
> Jim
Lee Steensland
601XL/Corvair (7637L reserved) Kit/Scratch builder 0.0% complete!
messydeer
Joined: 13 Feb 2006 Posts: 214 Location: Bellingham, WA
Posted: Fri Apr 04, 2008 7:19 am Post subject: Re: Zinc Chromate |
The bleeding issue is with zn chromate on the exterior, right? I've used it on all interior surfaces so far (wings, tail feathers). The spray cans sure leave dust all over the shop, too.
_________________ Dan |
Posted: Fri Apr 04, 2008 10:21 am Post subject: Zinc Chromate |
No Dan,
The zinc chromate inside a wing will wick out between edges and discolor
your primer and final color if the finish coat isn't solid cover. Even the
wash-etch prior to prime will have a yellow stain flowing from the wing
during a rinse. I the case of an etch that needs to be primed within 8
hours,
it's unlikely that the inside of the wing will be dry enough to keep the
zinc chromate from seeping out into your primer. Best advice, try a sample
of your paint over zinc chromate before actually doing it.
messydeer wrote:
Dan
messydeer
Posted: Fri Apr 04, 2008 11:20 am Post subject: Re: Zinc Chromate |
Thanks, Larry
I've used the green zn chromate both from Tempo and Orr-Lac. I suppose that would do the same? I'm planning on trying a polishing job first and if that doesn't look good enough (which may be caused by dings yet undung), I'd paint.
There are a few areas where I ran out of the zn chromate and used a couple spray cans of SEM Promax 61103 Gray Primer. It only says 'general purpose enamel for metal,...' and was what the autobody store recommended.
So it looks like I should read through this topic a bit more in detail. I chose zn chromate for it's corrosion resistance, price, and ease of application (rattle cans).
Cheers!
