Larry Hursh
Joined: 16 Feb 2008 Posts: 125 Location: Edwardsburg, MI (near Elkhart, IN)
Posted: Fri Apr 04, 2008 9:14 am Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
From what I can understand after talking with Wick's Aircraft, the zinc chromate IS being phased out for exactly what you said: health reasons. What is replacing it is zinc oxide. I've ordered 4 cans of it. I'll soon find out more about it. Here is their website if your interested: http://www.wicksaircraft.com/catalog/product_detail.php/pid=10643~subid=3911/index.html
Wicks does NOT charge any Haz Mat charges for shipping ORD but it can not ship via air. It has to go ground only. The cost is $8.18 a can. They offer it in the standard drab green and now also in yellow.
Hope this helps you.
Larry Hursh
CH601XL (Building from Kits - Just beginning)
(N601LL Reserved)
SkyriderSBN(at)Yahoo.com (SkyriderSBN(at)Yahoo.com)
Keep your eyes skyward - always!
_________________ Larry Hursh (N650LM Reserved)
"One rivet at a time......one day at a time.."
CH650 (Converted from CH601XL)
1/2 done with fuselage
will be Corvair Powered |
Tim Juhl
Joined: 21 Mar 2006 Posts: 488 Location: "Thumb" of Michigan
Posted: Fri Apr 04, 2008 11:30 am Post subject: Re: Zinc Chromate (Phasing out - going to Zinc Oxide) |
I bought 4 cans of Zinc Oxide from aircraft spruce (not all at the same time.) For some reason I was never able to use a full can before it got plugged up beyond recovery. I gave up and use SEM self etching primer on internal mating parts.
In general I would say that primers containing zinc would offer better corrosion protection but then again 6061 is pretty corrosion resistant by itself.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring! |
Larry Hursh
Posted: Fri Apr 04, 2008 12:03 pm Post subject: Re: Zinc Chromate (Phasing out - going to Zinc Oxide) |
Hey Tim,
It sounds like you might not be clearing the nozzle after each time you use it. Over time, the nozzle will plug up so badly, nothing will come out of it. To clear it, turn the can upside down and spray it until it comes out with only air. Do that each time you use it and you should be able to use the entire can next time. This works with any spray cans of paint you are trying to use too.
Posted: Fri Apr 04, 2008 12:10 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
I also bought some rattle cans of Zinc Oxide from Spruce. I shook the heck
out of them to mix them but both clogged on the first squirt. Nothing I
could do cleared them. Now I just buy the quart cans. Mix it one-to-one with
the reducer:
PTI ZINC OXD PRIMER GRN QT 09-00962 $46.80
PTI 1022X66 REDUCER QT 09-00956 $14.60
www.aircraftspruce.com/catalog/cspages/ptispecialtypaint.php
-- Craig
Kevin Bonds
Joined: 09 Jan 2006 Posts: 171 Location: Nashville, Tn
I have this problem with the tempo Zinc Oxide I use (valve plugging up).
I have to take the valve off sometimes and re-seat it. Just basically
pull it off and put it back on. It seems that they plug up if you press
too hard on the valve. I just barely squeeze until paint comes out. It
is very annoying at times though.
Kevin Bonds
Tim Juhl wrote:
_________________ KevinBonds
Nashville, TN
Plans-building Zenith CH601XL w/Corvair Power
http://home.comcast.net/~kevinbonds |
Kevin Bonds
Posted: Fri Apr 04, 2008 12:25 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
Larry
No, this dosen't seem to help or have anything to do with the cause.
These cans are defective or something. They will plug up on first use
within a couple of minutes. Very finicky.
Kevin Bonds
skyridersbn wrote:
Hey Tim,
Nashville, TN
bobefx(at)yahoo.com Guest
Posted: Fri Apr 04, 2008 1:05 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
Do you shake the cans for at least 2 minutes? It takes a lot to mix the can. If it is cold, get it to at least 72deg F and then shake it for all its worth until you feel your arm is going to fall off and than go for another minute beyond that, and it may still stick if a small poetical has not dissolved and mixed from the shaking. The ball has to move all over the can, shake, swirl, move it in all directions fast.
Larry Hursh
Posted: Fri Apr 04, 2008 1:14 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
Hey Kevin,
If I have the same trouble with the ones I just recieved, I will be calling Wicks for a full refund. At least I know there are quart cans and reducer available for it now.
If they give me trouble - their outta here!
Larry Hursh
(N601LL Reserved)
Kevin Bonds
Posted: Fri Apr 04, 2008 1:45 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
Thanks Bob,
But, yes I do shake the crap out of them. I've used a lot of rattle can
paint and never had this kind of trouble. I do get by though, as I said,
I just pull the nozzle off, and put it back on. They don't seem to clog,
so much as they just become jammed when pressed to hard.
Kevin Bonds
Bob Sturgis wrote:
| Quote: | Do you shake the cans for at least 2 minutes? It takes a lot to mix
Nashville, TN
ihab.awad(at)gmail.com Guest
On Fri, Apr 4, 2008 at 1:57 PM, Bob Sturgis <bobefx(at)yahoo.com> wrote:
| Quote: | shake it for all its worth until you feel your arm is going to fall off ...
Some have apparently tried to come up with a low-buck mechanical solution --
http://newsgroups.derkeiler.com/Archive/Rec/rec.crafts.metalworking/2006-07/msg00714.html
http://smg.photobucket.com/albums/0903/ghart3/?action=view¤t=shaker.jpg
Ihab
Ihab A.B. Awad, Palo Alto, CA
rtdin
Joined: 16 Mar 2008 Posts: 46 Location: Florida panhandle
Posted: Fri Apr 04, 2008 2:03 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
I won't miss zinc chromate. I'm scared to death of it. I discussed my fears with a friend who is both an A&P and owns a paint dealership. He advised that I use Zinc Phosphate. He sells it to the local Naval Air Station (NAS Whiting field) where they have a few hundred T-34C and TH-57 aircraft to maintain. The Navy likes it because it won't kill you or the environment. I use it with a touchup HVLP gun. I still have most of a gallon can and reducer left. I'm no paint expert, but it goes on like any other primer. I also like Cortec and get it from ZAC.
Bob Dingley
601XL Do not archive
*************http://travel.aol.com/travel-guide/united-states?ncid=aoltrv00030000000016) [quote][b]
Tim Juhl
Posted: Fri Apr 04, 2008 2:26 pm Post subject: Re: Zinc Chromate (Phasing out - going to Zinc Oxide) |
I've tried all sorts of things to prevent nozzle plugging including removing the nozzle and soaking it in thinner between uses. Nothing helps.
Sometimes it appears the clog is elsewhere in the mechanism. AC spruce replaced a couple of cans for free but they clogged too.
CFII
Champ L16A flying
Posted: Fri Apr 04, 2008 3:13 pm Post subject: Zinc Chromate (Phasing out - going to Zinc Oxide) |
You must shake the can even while you are painting. If the can is not thoroughly mixed it will clog down inside the can. shake, shake, shake that is all that works. Turn the can over when you stop for more than a second or two turn the can upside down and spray out the remaining in the tube or it will clog.
