Fox5flyer Guest
Posted: Sat Apr 05, 2008 6:15 am Post subject: Short field take off : was 6" extension |
Good post Larry. I agree. These discussion are just like the landing and
slipping discussions where it normally ends up to technique that feels good
to the particular flyer. Very often, it's the way a person was first taught
and it becomes cast in stone. I have a relatively short farm strip, about
900 Kitfox hours, and countless takeoff/landings, so the vast majority of
mine are short field technique. Sure, I could flatten out my prop and get
the airplane off the ground in 100 feet and have something to brag about,
but that's about all it is, bragging rights. I've tried every combination
possible and I always come back to the same thing that works best in my
situation. I use half flaps, full forward stick, tail up, pick up some
speed, then tail down to get the wheels off the ground and into ground
effect as soon as possible so I can quickly accelerate. The quicker the
wheels are off the ground and the airplane is level in ground effect, the
quicker it will accelerate to climb speed. I don't even look at the
airspeed as it all goes by feel. I've found that I use up a tad more runway
this way, but not very much--possibly 50 feet. The pros to this are
visibility and safety. I have the long aluminum gear so my S5 sits very
nose high and getting the tail up right away allows me to see if a deer is
running out in front of me or any other thing I hadn't seen. If I had a
nose dragger, obviously I'd do it somewhat differently. All this talk about
who can get their airplane off the ground the quickest is "groundless" chest
beating and doesn't really prove anything. The most important thing IMO, is
to use a technique that allows one to make a safe takeoff in a reasonable
distance with enough airspeed to make a climb well above stall speed.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 355+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
taildragon(at)msn.com Guest
Posted: Sat Apr 05, 2008 7:00 am Post subject: Short field take off : was 6" extension |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Good points. Sometimes it is necessary to combine several techniques. You all remember being taught short field techniques over a 50 ft obstacle where extending your ground roll (with tail up for low drag) builds momentum to be converted to altitude while climbing at Vx. But if your situation is a short field surrounded by tall trees and is muddy/wet or snowy or just tall grass, then you first need to clear the ground asap, accelerate in ground effect and then climb at Vx to clear the trees.
We have such a field here, and to add to the fun, we can use only one end of the field for takeoffs and landings, regardless of wind direction.
rjdaugh
Posted: Sat Apr 05, 2008 7:12 am Post subject: Short field take off : was 6" extension |
Thanks all for some good discussion. I am in agreement with Deke for the
reason he mentions - watch for deer.
Larry said: "In theory, a tail up roll would lessen the amount of induced
drag created by the wings as the angle of attack would be less, thereby
accelerate quicker."
In support of Larry's point on this is that with the drag proportional to
the air speed, there is negligible drag at the low speed in the start of the
takeoff run. It is only at the last second before takeoff that it becomes
significant and I know I can't run the stick fast enough (and I doubt that
the tail moves up or down fast enough) to take advantage of the situation.
Randy
Randy Daughenbaugh, N10NH
Black Hills of South Dakota, - Near Mount Rushmore
Home Strip, Grass Room in Hangar for visitors
Series 5/7 (7 Firewall Forward) 912S, Warp Drive Taper Tip
Gross Weight 1320 lbs, Flying since November 2004
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Lynn Matteson
Posted: Sat Apr 05, 2008 12:47 pm Post subject: Short field take off : was 6" extension |
I wonder if these "get off quick" guys ever go anyplace with these
planes, or just practice takeoffs? Maybe I'm just jealous, but I'd
rather go someplace than just brag about my short takeoffs. To each
his/her own, I guess.
Lynn
On Apr 5, 2008, at 10:10 AM, fox5flyer wrote:
Quote: | Sure, I could flatten out my prop and get the airplane off the
ground in 100 feet and have something to brag about, but that's
(snip)
Quote: | All this talk about who can get their airplane off the ground the
quickest is "groundless" chest beating and doesn't really prove
anything.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Sat Apr 05, 2008 3:09 pm Post subject: Short field take off : was 6" extension |
Oops, I just reread my message and saw that I might have ruffled some
feathers, especially "Rotax Dealer". If you're pitched to get off the
ground in 100 feet, then you're pitched to cruise at 65 mph!
Deke
Fox5flyer Guest
Posted: Sat Apr 05, 2008 3:13 pm Post subject: Short field take off : was 6" extension |
My sincere apologies. That was not meant to go to the list.
Again, my apologies, especially to Dave. Too quick to hit the "send"
button.
Deke
dave
Posted: Sun Apr 06, 2008 1:33 am Post subject: Re: Short field take off : was 6 |
Deke,
First off my Kitfox that is off in 100 feet or less will cruise at 92 mph with the 21 " King fox tires. That is TAS not IAS. I have a WARP ground adjustable on it now and those are the numbers. Plain and simple it works and works well. Engine has 420 hours on it and never been apart yet. According to popular belief that 2 stroke should have flown apart hundreds of hours ago. ? Heck man on Amphib floats I cruise at 85 MPH with a stinking 582 --
PS if you Kitfox will get off the ground in 100 feet ?> I would like to see that on Video, --See the difference between me and others is that is put my camera where my mouth is.Some like it -- others do not . But At least I can verify what I say with a video.
Quote: | Oops, I just reread my message and saw that I might have ruffled some
Deke
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
shinco(at)bright.net Guest
Posted: Sun Apr 06, 2008 4:52 am Post subject: Short field take off : was 6" extension |
dave wrote:
Quote: |
Deke,
> Deke
Rotax Dealer, Ontario Canada
Flying Videos and Kitfox Info
http://www.cfisher.com/
http://forums.matronics.com/viewtopic.php?p=175045#175045
GOOD going DAVE,,may be they should see your Videos as I have...and they
would belive too.what the little 582 can do..DAVE keep up the good
work...STEVE SHINABERY N554KF KF2 with a nother little 582 rotax
dave
Posted: Mon Apr 07, 2008 5:47 pm Post subject: Re: Short field take off : was 6 |
Thanks for the Kind words Steve .
Float Flyr
Posted: Thu Apr 10, 2008 4:31 pm Post subject: Short field take off : was 6" extension |
Lynn:
I can show you a couple of very small ponds. I'm just hoping that when I
get the 912 in it will be able to get out as quickly as the 582.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
dave
Posted: Thu Apr 10, 2008 5:48 pm Post subject: Re: Short field take off : was 6 |
Deke, I would like you to video this on your Kitfox 5 with Suberu. You got the CAP prop so lets see it . ?
situation.
Deke Morisse
Mikado Michigan
I can spout it out and prove it , Can you ?
Guy Buchanan
Posted: Thu Apr 10, 2008 8:31 pm Post subject: Short field take off : was 6" extension |
At 06:48 PM 4/10/2008, you wrote:
Quote: | I can spout it out and prove it , Can you ?
Dang Dave. I was hoping that because you didn't reply you'd let it
slide. Please drop it. With all due respect, pissing matches are not allowed.
Guy Buchanan, Kitfox List Moderator
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
dave
Posted: Fri Apr 11, 2008 4:59 pm Post subject: Re: Short field take off : was 6 |
Guy, I am only adding to the comments that were made from Deke.
I get numerous mails sent to me laughing at the way you guys handle this forum.
Why not start a poll or vote on moderators without an attitude ?
See the way I see it only the self appointed moderators can post criticism ?
Correct me if I am wrong, but you don't see me talking about my 27 years of aviation and how many hundreds of kitfox hours i have to puff out my chest. If I did I would be talking thousand of hours ,ratings, endorsements etc......... - I post stuff to help others not steal the limelight from certain people . Just ask John Mc bean if I promote Kitfox flying or not ? I guarantee you that I am an attribute to his business as we all are.
Hell, I fly a Kitfox the way it was designed to fly , I can guarantee you that I and not the only one that flys them this way either. I can also guarantee you that many should learn to fly their airplane better just so they can enjoy them to the MAX.
Why not we all try to get along eh ? You were the one who was taking 700 feet to take off if I recalll? I did the videos in the first place to show you that you must have had something wring with your plane or flying to make such long take offs.
LarryM
Posted: Fri Apr 11, 2008 6:18 pm Post subject: Re: Short field take off : was 6 |
Guy and all,
With all due respect, I agree with Dave. Let this forum post results. I appreciate Dave and others who may agree or disagree with my perspective. Gosh - how would we ever learn, grow, or have any revelations if we were only exposed to our own opinion expressed by others. Dave can obviously prove what he claims. You can see it. If you don't want to fly that way - fine don't. Many of us do. I personally want to fly the airplane to the limit the designer intended. When I find something that works/helps - I post it. Hence this thread to start off with. Perhaps others will benefit from my experience. As a bonus, I find that not only do I learn from what I discovered, but also form this list especially when people take issue with what I report or thought that I knew. Most recently was again this thread. I thought that the fastest way off the ground is 3 point full flap. I know it is for me and assumed it was for all. But through the thread I learned that others can do it with the tail up. Made me go back and try harder, read more, learn and come to my own conclusions - I can take off shorter with my airplane in the said configuration. Granted I don't have to force that down your throat, but the acceptance or not by the group or individual doesn't make the findings less true.
If some get offended, then like much in life - oh well. Don't read the thread or post, or read it knowing that you may disagree. Please don't sensor member opinions. Just attack the spam stuff. I do think that when one posts - one should be able to substantiate their claim. But we also need the freedom to post. One of the responsibilities of being a member of this great group or any other in life is the freedom to be offended without crying for blood. We all have different thresholds and have to respect that.
I think that I am starting to ramble on now. Thank you for allowing me to try to express myself. I hope that I was able to communicate my perspective with offense or/and rambling.
Go Fly!
larry
MichaelGibbs(at)cox.net Guest
Posted: Fri Apr 11, 2008 8:57 pm Post subject: Short field take off : was 6" extension |
Dave sez:
No, you were telling Deke to put up or shut up. Deke told you how
his airplane performs and you demanded that he post a video to prove
it to you. That's the way juveniles behave. If you don't believe
him, that's your prerogative.
Quote: | I get numerous mails sent to me laughing at the way you guys handle
this forum. Why not start a poll or vote on moderators without an
attitude ?
Excuse us if we don't care. This forum is run for the benefit of the
subscribers and that requires that every member behave like an adult.
It's not a popularity contest. If you want to start your own list
you'd be free to choose the moderators in any way that you wish.
Quote: | See the way I see it only the self appointed moderators can post criticism ?
Anyone can post criticism as long as it is respectful of others. Guy
felt you crossed the line and I agree with him.
Guy and I were not self-appointed, we were selected by the out-going
moderators and we will choose our successors. We were not chosen to
be likeable nor were we chosen to run a democracy--we were chosen to
run the list and keep it healthy. Based on the number of subscribers
we get every week, it seems to be working.
Quote: | ...you don't see me talking about my 27 years of aviation and how
Credentials are not what is relevant here, it is behavior.
Quote: | Why not we all try to get along eh ?
Good idea. Treat Deke and all others on the list with respect and
we'll get along just fine. Be a smart ass and we have no room for
you.
Mike G.
kitfox(at)ida.net Guest
Posted: Fri Apr 11, 2008 10:19 pm Post subject: Short field take off : was 6" extension |
I tried to post some creative crit., Got ripped from one person. This list
will die if we do not stop the nitpicking. Some of you people are a bad
thing. Yes, get over it. You fly, you do not know everything, quite trying
to prove to us short timers that you are aviatiors of the experimential
nature, You are not. Just help us get these stupid kits in the air that
everyone we buy parts from lies to us about. In the end, WE JUST WANT TO
FLY.
Albert
Posted: Fri Apr 11, 2008 10:43 pm Post subject: Short field take off : was 6" extension |
Thank you Albert, I hope you feel better. Now, let's get back to
talking about Kitfoxes.
Mike G.
Quote: |
I tried to post some creative crit...Got ripped...This list will
die...Just help us get these stupid kits in the air...everyone we
buy parts from lies to us about...
dave
Posted: Sat Apr 12, 2008 2:47 am Post subject: Re: Short field take off : was 6 |
Quote: | That's the way juveniles behave. If you don't believe
him, that's your prerogative. |
You are so Right with that statement Mike. I think you should take action for your actions as well.
I am not the one doing the offending here. I hope I can be more of an inspiration for builders and other fliers , well I know I am. I also think that some like you should help others rather that try to do a critique on them. I have posted this before and it still the same.
Deke had this statement "Oops, I just reread my message and saw that I might have ruffled some
Deke
And that is So untrue. That would be a totally Misleading statement for a new builder or flier and I set the record straight. So he admitted to ruffling feathers but not you the moderator are trying to point the blame my way ? OH PALLLLLLLLLLEZZZZZZZZZZZZZZZZZZ ..............
Lynn Matteson
Posted: Sat Apr 12, 2008 4:48 am Post subject: Short field take off : was 6" extension |
As I recall, this offering was made a while ago, the offending person
or persons started a new group, and he/they left this group...damned
of I can remember who that was. Whatever happened to those guys and
that group...oh well, this one's where the real Kitfox'ers are.
Lynn Matteson
flying w/487+ hrs/down for annual
On Apr 12, 2008, at 12:53 AM, Michael Gibbs wrote:
Quote: | If you want to start your own list you'd be free to choose the
Mike G.
N369LM |
dave
Posted: Sat Apr 12, 2008 5:00 am Post subject: Re: Short field take off : was 6 |
Lynn Matteson
That was John perry and brother. there are 3 on that forum . I seen the one video that one of them made on full lotus, looks like at least of one of them flys and makes a Kitfox do what it was designed for , fly and fly well. I forget site -- avid fox flyers .com ? i think
