gaman(at)att.net Guest
Posted: Fri Apr 11, 2008 11:54 am Post subject: Firestar project |
Bill,
Best of luck making your goal.A noble challenge.
Posted: Fri Apr 11, 2008 12:55 pm Post subject: Firestar Project |
Gary- My Firestar appears to be the old "KX" version. It is a single seat, plastic dash, and very, very sparsely built. For example, even the throttle control lever is light- built from tubing in a "T" shape. I am certain that the fuselage tube was built shorter than normal, as the replacement wings- not yet identified, but light- extend past the tail when folded. The wing "sockets" for folding go past the fuse tube end. The original wingspan was 25'4". With the replacements, the wingspan is 27'6". There is no apparent serial number. I am giving only the "wet" weight, as I still have a full tank of 5 gallons. I will weigh again when I drain it.
I think the original KX was designed lighter than today's version, never mind the wings being 5 rib. Possibly lighter or smaller or thinner wall tubing? After I transport it, I will be able to compare side by side with Ed Harvey's in Palmer, Mass.
Also keep in mind- I am very inexperienced, and this is the first Kolb I have ever worked on. My observations are ONLY valid for this aircraft. I can say with confidence that the Kolb's must be a very solidly designed plane. You should see my collection of bent LG legs that came with it, and no other apparent damage. Besides scuff marks on the nose cone, and we all know what that's from.
Bill Sullivan
FS/KX/447
rowedenny
Posted: Fri Apr 11, 2008 12:56 pm Post subject: Firestar project |
| Quote: | Bill,
I have been following your progress. Having met 103-7 the weight and fuel
capacity restrictions, how are you going to meet the drag and power
restrictions to ensure that it does not fly too fast?
Jack B. Hart FF004
Winchester, IN
Jack,
I would think with the longer wing, Bills Firestar will meet the math
requirments of 103. Also, a Firestar fuselage is probably a little wider
than a Fireflys?
With a 447 and also meeting the weight and fuel limits, who would bother
with the equations?
Denny Rowe
Posted: Fri Apr 11, 2008 1:54 pm Post subject: Firestar project |
Re: The Firestar with a 503. According to the Lockwood book, the 503 weighs about 12 1/2 pounds more than a 447. It's hard to be exact, but that is due to engine weight, 2 carbs, and exhaust differences. I don't know about differences in the gearbox.
Denny- I can't measure the fuselage width right now- looks like rain, but I will post it first chance for anyone who cares to measure something. Also the main tube length.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
ElleryWeld(at)aol.com Guest
Posted: Sat Apr 12, 2008 6:44 am Post subject: Firestar project |
a 66" tenn Wood prop weighs 5.7 Lbs
Ellery in Maine
In a message dated 4/11/2008 5:54:46 P.M. Eastern Daylight Time, williamtsullivan(at)att.net writes:
| Quote: | Re: The Firestar with a 503. According to the Lockwood book, the 503 weighs about 12 1/2 pounds more than a 447. It's hard to be exact, but that is due to engine weight, 2 carbs, and exhaust differences. I don't know about differences in the gearbox.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
It's Tax Time! Get tips, forms and advice on AOL Money & Finance.
Posted: Sat Apr 12, 2008 6:56 am Post subject: Firestar project |
also the tail boom tube on my old firestar was 13 feet long
Ellery in Maine
In a message dated 4/12/2008 10:45:02 A.M. Eastern Daylight Time, ElleryWeld(at)aol.com writes:
| Quote: | Bill
Ellery in Maine
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
Dana
Posted: Sat Apr 12, 2008 12:52 pm Post subject: Firestar project |
Bill, FWIW, my clear vinyl gap seal (.040" thick material from
McMaster-Carr) weighs 2.2 lbs.
Discovered my personal comfort limits in the Ultrastar today. You know the
old saying, "It's better to be on the ground wishing you were in the air,
than in the air wishing you were on the ground"... I can safely say that an
80° crosswind at 12G18 (it didn't seem that bad when I took off) is TOO
WINDY. Got down without breaking anything but they guys watching must have
enjoyed the show! Good thing I had help folding it up again.
-Dana
I do not feel obliged to believe that the same God who endowed us with
sense, reason and intellect has intended us to forgo their use. -- Galileo
Galilei
Posted: Sat Apr 12, 2008 3:21 pm Post subject: Firestar project |
Anybody with an original Firestar, a KX version, or a Firefly want to grab their overall length for me? The TNK website no longer gives length. My Firestar KX measured out at 19' even, with a tail boom OAL of 12'. Ellery's FS was 13'.
I'm still trying to identify this thing, and it gets more confusing each time I try. It is starting to look like an FS/KX built light for 103.
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
a58r(at)verizon.net Guest
Posted: Sat Apr 12, 2008 4:06 pm Post subject: Firestar project |
second time!
know the old saying, "It's better to be on the ground wishing you
were in the air, than in the air wishing you were on the ground"... I
can safely say that an 80° crosswind at 12G18 (it didn't seem that
bad when I took off) is TOO WINDY. Got down without breaking
anything but they guys watching must have enjoyed the show! Good
-Dana
via bob n
Dana
Posted: Sat Apr 12, 2008 4:17 pm Post subject: Firestar project |
At 08:03 PM 4/12/2008, Bob Noyer wrote:
"second time"?
-Dana
Software isn't released, it's allowed to escape.
russ(at)rkiphoto.com Guest
Posted: Sat Apr 12, 2008 4:18 pm Post subject: Firestar project |
DANA!
Most glad you didn't fold it up on the runway!
Russ
On Apr 12, 2008, at 8:03 PM, Bob Noyer wrote:
second time!
I can safely say that an 80° crosswind at 12G18 (it didn't seem
that bad when I took off) is TOO WINDY. Got down without breaking
-Dana
via bob n
Posted: Sat Apr 12, 2008 7:23 pm Post subject: Firestar project |
I found a Firefly length of 19' 6" on Jack Hart's website. My Firestar is 19' even. Anybody have the length on a Firestar l or Kx? Comments?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
GeoR38
Joined: 25 Jan 2006 Posts: 60 Location: The Villages, fl
Posted: Sun Apr 13, 2008 2:24 pm Post subject: Firestar project |
In a message dated 4/12/2008 11:23:49 P.M. Eastern Daylight Time, williamtsullivan(at)att.net writes:
| Quote: | I found a Firefly length of 19' 6" on Jack Hart's website. My Firestar is 19' even. Anybody have the length on a Firestar l or Kx? Comments?
Bill Sullivan
FS/KX/447
Windsor Locks, Ct.
The Firestar length on my 1985 copywrite KX and KXP overview drawings is:
Overall length from nosecone tip to back of rudder: 20' 3"
Wingspan is 27' 8"
George Randolph Firestar KX driver, 447 Rotax, points
The Villages, Fl
_________________ George Randolph
Firestar driver, The Villages, fl |
Posted: Sun Apr 13, 2008 3:22 pm Post subject: Firestar Project |
Curiouser and curiouser. Thanks, George. I would love to know this history on mine. The closer I look, the stranger it gets. I have the Ducati ignition, and I do have a serial number on the engine. It does look original, but who knows. Once I get it to the airport maybe somebody will know more.
Bill Sullivan
FS/KX?/447
Windsor Locks, Ct.
Dana
Posted: Sun Apr 13, 2008 4:13 pm Post subject: Firestar Project |
At 07:19 PM 4/13/2008, william sullivan wrote:
| Quote: | Curiouser and curiouser. Thanks, George. I would love to know this history
on mine. The closer I look, the stranger it gets...
Nothing you can track back through the previous owner(s)?
-Dana
A seminar on Time Travel will be held two weeks ago.
Posted: Sun Apr 13, 2008 5:03 pm Post subject: Firestar Project |
Dana- I asked about the source, but the guy I bought it from had shared ownership with somebody else. When I asked him, he said the other guy might know and I didn't follow through. I think I'll e-mail him.
Bill Sullivan
FS/KX/447
Dana
Posted: Sun Apr 13, 2008 5:23 pm Post subject: Firestar Project |
At 08:59 PM 4/13/2008, william sullivan wrote:
| Quote: | Dana- I asked about the source, but the guy I bought it from had shared
Hope you have better luck than I had. Actually I know three owners back
for my plane, but the first guy I know (who bought it sometime in the early
90's) doesn't remember the original owner's name, only that he "was an old
guy" and probably dead now. Of course mine is mostly stock so there aren't
many questions. Of the three owners I know, only one ever flew it (and he
only flew it a couple of times), though some of their friends flew it
occasionally.
-Dana
Nowadays only a lawyer can tell legal from illegal, and the lawyers don't
know the difference between right and wrong.
Posted: Mon Apr 14, 2008 1:30 am Post subject: Firestar Project |
An "old guy"? hmmmm, is there any other kind of Kolb owner? -Or
flyer for that matter.
It doesn't look good for the sport when everyone is 60+
It can't solely be a matter of affordability because I see lots of
$6000+ snowmobiles,
4 wheelers, not to mention those ridiculous $$$$$$ boats.
BB
On 13, Apr 2008, at 9:17 PM, Dana Hague wrote:
> mail him.
back for my plane, but the first guy I know (who bought it sometime
in the early 90's) doesn't remember the original owner's name, only
that he "was an old guy" and probably dead now. Of course mine is
mostly stock so there aren't many questions. Of the three owners I
know, only one ever flew it (and he only flew it a couple of
times), though some of their friends flew it occasionally.
-Dana
lawyers don't know the difference between right and wrong.
Dana
Posted: Mon Apr 14, 2008 3:01 am Post subject: Firestar Project |
At 09:40 PM 4/13/2008, robert bean wrote:
| Quote: | An "old guy"? hmmmm, is there any other kind of Kolb owner? -Or
$6000+ snowmobiles,
This comes up regularly on the PPG forums... you'd think that would be a
young person's sport, but the average participant is 40-60. It's because
flying (of any kind) doesn't mix well with a young man's primary interests
(women and beer).
-Dana
Clothes make the man. Naked people have little or no influence on society.
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Mon Apr 14, 2008 4:22 am Post subject: Firestar Project |
Well,
I'm 43 and I'm a flyer, I still like Women and Beer too...
HMMMMM
Do not archive!
Dana Hague <d-m-hague(at)comcast.net> wrote:
[quote]--> Kolb-List message posted by: Dana Hague
$6000+ snowmobiles,
young person's sport, but the average participant is 40-60. It's because [quote][b]
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
