rmacpunk(at)netzero.net Guest
Posted: Tue Apr 22, 2008 6:02 am Post subject: Castellated Nuts. |
The plans indicate using locknuts on the control cables attack points but my friend (AI) says must use castellated nuts with cotter pins.
Gig Giacona
Posted: Tue Apr 22, 2008 6:18 am Post subject: Re: Castellated Nuts. |
I, as usual, don't have the plans in front of me but thinking of the cable connections I have done according to the plans.
1. Rudder Horn- castellated nuts with cotter pins.
2. Rudder control at the pedals- castellated nuts with cotter pins.
3. Elevator at the stick- castellated nuts with cotter pins.
4. Elevator horn- castellated nuts with cotter pins.
I do have older plans and kit so they might have changed it.
601XL Under Construction
ashontz
Posted: Tue Apr 22, 2008 6:47 am Post subject: Re: Castellated Nuts. |
I believe the rule is, any bolt that's subject to torsional forces, like a pivot point, should have a castelle nut and cotter pin, not a locknut.
Additionally, any locking nut application (not a cotter pin nut) that's in a high heat area, like the engine compartment, should use a fully metal lock nut, not a nylon insert for the locking effect. Of course, you should never reuse a locknut of either type. You're probably supposed to always use a new cotter pin too whenever a castelle nut is reinstalled.
[quote="rmacpunk(at)netzero.net"]The plans indicate using locknuts on the control cables attack points but my friend (AI) says must use castellated nuts with cotter pins.
Gus(at)flywithgus.com Guest
Posted: Tue Apr 22, 2008 7:36 am Post subject: Castellated Nuts. |
Wrong.
AC43.13-1B 7-64.f You can reuse if minimum prevailing torque is met. For
the smaller diameters we use mostly you can reuse as long as noticeable
drag is felt when engaging the locking area. Also if you can remove a
cotter pin without rendering it unusable then it wasn't installed
properly. AC43.13-1B 7-127
-Gus
ashontz wrote:
Quote: | Of course, you should never reuse a locknut of either type. You're probably supposed to always use a new cotter pin too whenever a castelle nut is reinstalled.
ashontz
Posted: Tue Apr 22, 2008 7:56 am Post subject: Re: Castellated Nuts. |
I said probably. Even so, for 99 cents I'd probably just put a new one in there.
Gus(at)flywithgus.com wrote: | Wrong.
-Gus
daveaustin2(at)primus.ca Guest
Posted: Tue Apr 22, 2008 12:42 pm Post subject: Castellated Nuts. |
Here in Canada a castellated nut and lock pin must be installed at any place
where the nut/bolt combination is not torqued up. That covers pretty well
everything where a bolt is used as a pivot.
Dave Austin 601HDS - 912, Spitfire Mk VIII
Aerolitellc(at)aol.com Guest
Posted: Wed Apr 23, 2008 12:13 am Post subject: Castellated Nuts. |
I would recommend not using castellated nuts for the rudder cables that attach to the foot peddles and whatever Zenith indicates everywhere else. There were a couple of people that have worked the cotter pins out with their shoes catching the pin and Van's aircraft had you change out the castle nuts and replace them with nylon locking nuts. And I found you could have the same problem with the 601.
Quote: | The plans indicate using locknuts on the control cables attack points but my friend (AI) says must use castellated nuts with cotter pins.
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
Posted: Wed Apr 23, 2008 11:15 am Post subject: Castellated Nuts. |
not smart to NOT use castlenuts where there is motion, the motion could back out a noncastle nut. CAstle nuts need to be used where the is motion directly on the nut. such as the stering rods, control horns, etc. with the correct attachements of cotter pins there would not be problems with pins coming undone.
Juan
jmcburney(at)pobox.com Guest
Posted: Wed Apr 23, 2008 11:55 am Post subject: Castellated Nuts. |
Hi, Bob,
Your AI is right. The rule is, if the bolt/nut is in tension (i.e., torqued
tight, no rotation) then locknuts are okay, but when ANY rotation is
present, as with clevis bolts, a castellated nut and cotter pin are
required. Makes sense.
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
SABorns(at)aol.com Guest
Posted: Wed Apr 23, 2008 1:24 pm Post subject: Castellated Nuts. |
43-13 says that castle nut and cotter pins be used whenever the fitting is subject to rotation.
Steven Bornstein
475 E. North Broadway
Columbus, Ohio 43214
614 263-5819
In a message dated 4/23/2008 3:16:17 P.M. Eastern Daylight Time, amyvega2005(at)earthlink.net writes:
[quote]--> Zenith-List message posted by: Juan Vega <amyvega2005(at)earthlink.net>
Juan
Afterfxllc(at)aol.com Guest
Posted: Wed Apr 23, 2008 1:41 pm Post subject: Castellated Nuts. |
I know the regs but in the case of the foot pedal cables you can snag the pin with your shoe or pants and work it loose and when it rotates the pin can fall out allowing the nut to back off. Van's has about the same set up for the rudder cables and after a few pins came out they advised NOT to us castle nuts in that situation.
Steven Bornstein
614 263-5819
Juan
Gig Giacona
Posted: Wed Apr 23, 2008 2:02 pm Post subject: Re: Castellated Nuts. |
It seems to me that we can be pretty sure a non-torqued locknut is going to come off sooner or later and is only slightly less likely to back off than a castle nut without the pin.
So while I understand the foot hanging on it and pulling the pin is bad there should be a better way to deal with the problem than using a nut that is very likely to fall off.
How about some type of cap for the castle nut that protects the pin?
Thruster87
Posted: Wed Apr 23, 2008 2:10 pm Post subject: Re: Castellated Nuts. |
You can roll the split pin ends back into itself thus NO ENDS sticking out to catch anything. That's what we do on our A/C and you also don't cut your hands working around them Cheers
Posted: Wed Apr 23, 2008 2:18 pm Post subject: Castellated Nuts. |
A rudder pedal castle nut could be secured with something unorthodox like a
split ring that wouldn't catch on a pants leg.
-- Craig
gfmjr_20(at)HOTMAIL.COM Guest
Posted: Wed Apr 23, 2008 2:35 pm Post subject: Castellated Nuts. |
There are AN safety clips that look like safety pins used to secure casle nuts when the nuts are to be periodically removed. I have them on my Kiyfox on the wing attach bolts which can be removed so that the wings swing back for transportation.
George May
601XL 912s
[quote] From: craig(at)craigandjean.com
Subject: RE: Re: Castellated Nuts.
Date: Wed, 23 Apr 2008 16:15:13 -0600
--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com>
-- Craig
Posted: Wed Apr 23, 2008 3:02 pm Post subject: Castellated Nuts. |
Guys you don't use a castle nut on your seat belt attach or the canopy bolt or a number of other places that you don't tighten the nut I would agree that there might be hundreds of ways to address this issue but to say the nut will fall off eventually is a bit of a stretch. I liked the idea of looping the pin but a safety type pin would seem a bit better. Or I guess you could simply spot weld the nut on. That last one was a joke.
paulrod36(at)msn.com Guest
Posted: Wed Apr 23, 2008 3:11 pm Post subject: Castellated Nuts. |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> That won't happen if you "navy" the cotter pins. You bend the legs all the way around until they meet the loop in the head of the cotter pin, then cut off the excess, and bend them down tight. (My old A&P showed me that one.) The most prehensile toes, shod or not, can't snag what isn't snaggable.
Paul Rodriguez
Posted: Wed Apr 23, 2008 3:32 pm Post subject: Castellated Nuts. |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Of course, you could also insert the bolt from inside, so the castellated nut is under the footbar, thereby unreachable by foot,
Paul Rodriguez Original Message -----
[quote] From: Gig Giacona (wr.giacona(at)suddenlink.net)
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Sent: Wednesday, April 23, 2008 5:02 PM
Subject: Re: Castellated Nuts.
--> Zenith-List message posted by: "Gig Giacona" <wr.giacona(at)suddenlink.net (wr.giacona(at)suddenlink.net)>
W.R. "Gig" Giacona
http://forums.matronics.com/viewtopic.php?p=178767#178767
http://www.matron=======================
bsp; via the Web title=http://forums.matronics.com/ href="http://forums.matronics.com">http://forums.matronics.com
_-========================nbsp; generous bsp; title=http://www.matronics.com/contribution href="http://www.matronics.com/contribution">http://www.matronics.com/c=================
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Wed Apr 23, 2008 3:53 pm Post subject: Re: Castellated Nuts. |
Of course on a rod end the nut clamps the ball of the connecting rod tight. The only motion is between the ball and the socket. The front of the steering rod (at least on my plans) uses a rod end.
As a point of interest for those that will only use a nylock nut once, I made a homemade hole cutter.. This tools used a 3/16 bolt with a locknut as the pivot for the center of the hole. This was one of those 1/2 height nuts, not even full thread. I cut every lightening hole on the airframe with that tool using the same nut and bolt. The nut faced aggressive turning motion with every one of the holes that I cut, including all the rib lightening holes. The nut never backed off. It must have been on and off a hundred times.
Anyway I'm comfortable using them twice, as (like Gus mentioned) they haven't been over torqued.
Dan
Quote: |
"amyvega2005(at)earthlink."]not smart to NOT use castlenuts where there is motion, the motion could back out a noncastle nut. CAstle nuts need to be used where the is motion directly on the nut. such as the stering rods, control horns, etc. with the correct attachements of cotter pins there would not be problems with pins coming undone.
Juan
_________________ Scratch building XL with Corvair Engine |
msherman95632(at)yahoo.co Guest
Posted: Wed Apr 23, 2008 4:03 pm Post subject: Castellated Nuts. |
Gig.
I would have to disagree that a non-torqued lock nut is only slightly less likely to back off. Your kidding, right. That is the hole point of having a lock nut, so they don't back off.
I would think the manufacture of the nuts would do vibration tests that lasted thousands of hours with loose nuts to prove the design.
You could always use a bushing, such as on the rudder, then the bolt is torqued against the bushing allowing you to use a lock nut.
Mark S.
701/912ULS
