FUEL SYSTEM QUESTION
GLJSOJ1
PostPosted: Sat Apr 26, 2008 5:25 pm    Post subject: FUEL SYSTEM QUESTION Reply with quote
Hi All
I am just finishing up my 601XL with a O-200 engine from a Cessna 150. This engine does not have a mechanical fuel pump, so I have installed two electric fuel pumps, with separate electrical lines. Here's my nagging problem. If I lose the electrics in the plane I will have no fuel pressure. How would some of you handle this possible problem? When I have the engine overhauled in a few years I plan to put a mechanical pump on it, but till then?
601XL N676L FLYING PHASE I
CHESAPEAKE VA
purplemoon99(at)bellsouth
PostPosted: Sat Apr 26, 2008 5:49 pm    Post subject: FUEL SYSTEM QUESTION Reply with quote
Back-up batt.,with it's own switch and circuit.. Joe N101HD 601XL/RAM
Jeyoung65(at)aol.com
PostPosted: Sat Apr 26, 2008 5:50 pm    Post subject: FUEL SYSTEM QUESTION Reply with quote
You could add another battery and allow the aircraft elect. system to only charge the battery and have only the fuel pumps connected to this battery with a special switch when you lost aircraft elect power. This would be over design!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! If you are worried about this you may just installed a three way switch for each pump (ON to aircraft system) (On to battery) and OFF. Jerry of GA DO NOT ARCHIVE
In a message dated 4/26/2008 9:30:47 P.M. Eastern Daylight Time, gljno10(at)HOTMAIL.COM writes:
--> Zenith-List message posted by: "GLJSOJ1" <gljno10(at)hotmail.com>
Hi All
601XL N676L  reserved
ALMOST DONE
CHESAPEAKE VA
http://forums.matronics.com/viewtopic.php?p=179494#179494
Need a new ride? Check out the largest site for U.S. used car listings at AOL Autos.
gfmjr_20(at)HOTMAIL.COM
PostPosted: Sat Apr 26, 2008 5:52 pm    Post subject: FUEL SYSTEM QUESTION Reply with quote
I'd insure one pump is feed directly from your battery(fused appropriately), while the other can run off of your electrical distribution buss. Typically loosing electrics implies loss of alternator. The battery will usually last about 1/2 hour with essentials. That should be enough to get you safey on the ground using the pump directly feeding off the battery.
George May
601XL 912s
Subject: FUEL SYSTEM QUESTION
Date: Sat, 26 Apr 2008 18:25:56 -0700
Hi All
ALMOST DONE
CHESAPEAKE VA
Express yourself wherever you are. Mobilize! [quote][b]
Terry Phillips
PostPosted: Sat Apr 26, 2008 8:04 pm    Post subject: FUEL SYSTEM QUESTION Reply with quote
I would suggest that you adopt the philosophy advocated by Electric Bob of
the Aeroelectric Connection. IIRC, Bob's basic premise is that you should
wire your airplane so that the failure of the alternator will not result in
a life threatening situation. Consider his schematic Z-xx.
http://www.aeroelectric.com/Reference_Docs/Misc_PDF/Zxx.pdf
Notice that there is an endurance bus. The endurance bus should only power
electrical loads that are necessary for survival. In Z-xx, the endurance
bus powers the GPS, transponder, NAV/COM, turn coordinator, intercom, and
the fuel boost pumps. During normal operation, the endurance bus is powered
by the alternator through a diode. In the event of an alternator failure,
the pilot manually throws a switch to power the endurance bus from the
battery. The diode blocks the power from flowing backwards to the main
power bus.
The idea is that you size your battery to provide however many minutes you
believe you will need to land in the event of an alternator failure. Let's
say the total load on the endurance bus is 15 amps. If you install, e.g.,
an Odyssey 925 battery, the advertised capacity is 50 minutes with a 25 amp
load. Since your endurance bus only draws 15 amps, you should be able to
fly for ~83 minutes while you look for a place to land. Hopefully, with
your GPS you would not have too much trouble flying to a suitable airport
in 83 minutes. If you decide that you don't need your NAV/COM or turn
coordinator while you are en route to the airport, you could switch those
off until you get close to the airport and, thereby, increase your endurance.
Finally, you say your are doing, the two fuel boost pumps on separate
circuits and fuses so that a short in one pump's power circuit would not
disable the other pump.
I'm a long way from doing that wiring myself, but Electric Bob's approach
makes good sense to me. My Jabiru engine has a mechanical pump, but I am
still putting a boost pump (and gascolator) in each wing.
Terry
At 06:25 PM 4/26/2008 -0700, you wrote:
Hi All
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; working on the wings
http://www.mykitlog.com/N47TP/
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
kmccune
PostPosted: Sun Apr 27, 2008 3:48 am    Post subject: Re: FUEL SYSTEM QUESTION Reply with quote
Don't forget to give yourself a way to know that the alternator has quit, otherwise the battery may not be of any use. Voltmeter, idiot light ect...
R.W. Emerson (1803-1882)
Dorothy McCune
m.l.marcotte(at)sympatico
PostPosted: Sun Apr 27, 2008 6:30 am    Post subject: FUEL SYSTEM QUESTION Reply with quote
I would install a small alternator like this one
http://www.aircraftspruce.com/catalog/eppages/sdaltreg.php (only 4 pounds)
where the vacuum pump normally goes and connect it to a completely separate
electrical system for the second fuel pump and for a few critical electrical
flight instruments that would replace the normally vacuum-driven
instruments. I would install the minimum size battery that this alternator
will accept. You might want to add a tie-breaker that could connect your
two electrical systems together in case one of your alternators fails in
flight but keep in mind that the new alternator provides only 8 amps. This
is also a very nice back-up system for glass panels and with this
installation you would never need to install the mechanical pump.
steerr(at)bellsouth.net
PostPosted: Sun Apr 27, 2008 8:06 am    Post subject: FUEL SYSTEM QUESTION Reply with quote
What George suggests can be done indirectly, with the endurance buss
normally fed through a diode bridge that derives it's feed from the
output side of the battery contactor, but with an switch-controlled
alternate feed directly from the battery (i.e., the input side of the
battery contactor). One fuel pump is then fed from the endurance buss.
See Figure Z1 of the Aeroeletric Connection publication, which uses a
fuselink for protecting the wire.
Bill
601HD Stratus N109BS
George May
601XL 912s
Gig Giacona
PostPosted: Sun Apr 27, 2008 10:49 am    Post subject: Re: FUEL SYSTEM QUESTION Reply with quote
Since I'm going to be flying a Corvair that not only has two electrical fuel pumps but also needs electrics to power the ignition system I've looked at this issue quite a bit.
The Aeroelectric manual has a pretty simple 2 battery design that charges both batteries but separates them electrically.
It isn't an over design at all. The manual's out at the airport so I can't go over the details but it really isn't that big a deal.
W.R. "Gig" Giacona
601XL Under Construction
rtdin
PostPosted: Sun Apr 27, 2008 11:25 am    Post subject: FUEL SYSTEM QUESTION Reply with quote
Your O-200 has no fuel pump mounted now, but I know that it has a pad to install one. You are planning to install one eventually. My humble recommendation is to invest $300 (or less) and put one on now. Avoid the extra batteries & switches.
Bob
(http://autos.aol.com/used?NCID=aolcmp00300000002851) [quote][b]
floyd wilkes
PostPosted: Sun Apr 27, 2008 3:13 pm    Post subject: Re: FUEL SYSTEM QUESTION Reply with quote
Adding a fuel pump may not be so easy.
My O-200 also came off of a C-150. I overhauled the engine and wanted to add a fuel pump.
The cam installed would not support a fuel pump. It took a different cam/gear part number. The only one I could find was approx $1300!
That was just the cam. Then I would have needed the pump at another $400. A total of $1700.
Thinking long and hard-not really. I chose go with two $35 electric pumps.
Bottom line, you need to check the cam part number to see if it will support the fuel pump.
Floyd
Floyd Wilkes
dougsnash
PostPosted: Mon Apr 28, 2008 6:55 am    Post subject: FUEL SYSTEM QUESTION Reply with quote
How about an old style Wobble Pump like what was used
on aerobatic aircraft? It's a small hand pump that
would likely only need a couple of strokes every
thirty seconds or so to keep the float bowls full.
It's a non-electric alternative. This eliminates the
added complexity of an essential buss.
I think they are available for Aircraft Spruce but
don't have a specific link for them.
Doug MacDonald
CH-701 Scatch Builder
NW Ontario, Canada
(Also have AcrosportII plans)
battery(fused
your electrical
implies loss of
1/2 hour with
on the ground using
> George May
> 601XL 912s
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
