		larry(at)ncproto.com Guest
				 Posted: Mon Feb 27, 2006 12:47 pm    Post subject: GNS-530 vrs. MX-20 |
				Hello All,
 I'm new to this list and have what I hope is an
 interesting question:  I have been planning on
 installing a Garmin GNS-530 for quite some time, and
 before I make the final commitment I want to address one
 final option; installing instead an MX-20 with all the
 appropriate additions to render the same functions as
 the 530.
 I am building a tandem 2-place (Harmon Rocket) with the
 primary mission statement of fun cross-country work.  I
 want to minimize pilot workload and maximize safety and
 fun.  I desire to have weather and may install traffic
 at a later time.
 The reason for this query is that I have heard the 530
 has barely enough computing power to handle weather and
 that the MX-20 does this much better and with a better
 display.  The MX-20 is also a better platform to make
 changes to later on.  So my questions are:
 1) any suggestions on the best equipment to integrate
 with the MX-20 to allow its function to match that of
 the 530 ??
 2) any input on which of these options offers the best
 performance ??
 3) any input on which of these options offers the most
 flexibility ??
 4) any input on which of these options offers the
 easiest use ??
 Thanks a ton in advance !!!!
 Larry E. James
 Bellevue,  WA  Harmon Rocket II
  |  | - The Matronics Avionics-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Tim(at)MyRV10.com Guest
				 Posted: Mon Feb 27, 2006 1:48 pm    Post subject: GNS-530 vrs. MX-20 |
				You're not making an apples to apples comparison.  The
 MX-20 is just a MFD....takes input from various items
 and displays it.   The GNS-530 is a NAV/COM/GPS.
 If you have an MX-20, you could integrate something
 like a GNS-480 and have quite a good interoperation
 going.  You could integrate the 530 to the MX-20
 as well.  You could save money and use a GNS430.
 They're all very different and very different in cost.
 The MX-20 is going to be the nicest thing to display
 weather/traffic/terrain on and will blow the built
 in screens away for all the Nav/Com/GPS units.
 For some reason, at all the shows, you always see the
 MX-20 and GNS480 together.  You then see the Avidyne
 EX500 paired to the GNS430 or 530.  I am not sure, but
 I think that those pairs are because there are a few
 minor things that won't work with 100% functionality
 if you try to mix a MX-20 with a 430, for instance.
 Nothing too drastic though.
 Of course, if you're going to be spending the kind of
 money you're talking about when getting a 530 and MX-20
 and integrating Garmin's pricey WX receivers and such,
 you may consider looking at the Chelton screens.  If you
 go that route, the interfaces will cost less, and you can
 get most of what you need out of just a cheap SL-30 and
 SL-40 combo.
 If your goal is to save money, and not have an IFR plane,
 you may consider just a handheld 396 to display traffic
 and weather on.  Of course, if you also get a GNS430/530/480
 plus a CDI, you then could have a nice IFR panel too.
 It's a very excruciating  process to pick the equipment,
 isn't it?
 Larry E. James wrote:
  Hello All,
  the 530.
  at a later time.
  the 530 ??
  performance ??
  flexibility ??
  easiest use ??
