yenduc(at)sbcglobal.net Guest
Posted: Wed May 07, 2008 5:12 pm Post subject: sniffle valve in RV 7A |
from Dave Cudney RV 7A struggler
Quote: | I am getting further along with my project and was just buttoning up
a few odds an ends when I came to the sniffle valve for my IO 369.
On the tail dragger there is not much of a problem routing the drain
line from the sniffle valve --- but on the nose dragger, the nose
gear bracing on the engine mount is in the way. Has any one out
there solved this problem and what did you do?
Thanks in advance
dave
| - The Matronics RV-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Wed May 07, 2008 6:50 pm Post subject: sniffle valve in RV 7A |
In a message dated 05/07/2008 8:14:16 PM Central Daylight Time, yenduc(at)sbcglobal.net writes:
Quote: | Has any one out
Quote: | there solved this problem and what did you do? |
On a recently installed valve on an Aerosport IO-360 with AFP injection mounted to forward sump (-7A), I had more of a problem getting the drain tube away from the Vetterman crossovers. I cut the tube from the sniffle valve fairly short (1"?) and soldered a brass 90 deg. fitting to it. The other end of this fitting (from the aviation plumbing aisle at Lowes) provided for connection for a copper tube the same size as from the sniffle valve (1/8"?) using a brass compresion ferule. I installed the valve, then bent/routed a copper tube from the 90 aft, securing it mid-length to the exhaust hangar cross-piece and extended it aft out the air outlet so that when it drips (which it WILL) the fuel will simply drop to the ground rather than down the nose gear fairing and onto the pant.
Not sure if this will help with your situation, but it may offer some options...
From The PossumWorks in TN
Mark
http://websites.expercraft.com/n51pw/
Wondering what's for Dinner Tonight? Get new twists on family favorites at AOL Food.
_________________ From The PossumWorks... |
Posted: Wed May 07, 2008 9:52 pm Post subject: sniffle valve in RV 7A |
Thanks --- I've got one of those aviation plumbing stores close by -- I'll try your method.
dave
On May 7, 2008, at 7:47 PM, Fiveonepw(at)aol.com (Fiveonepw(at)aol.com) wrote: Quote: | In a message dated 05/07/2008 8:14:16 PM Central Daylight Time, yenduc(at)sbcglobal.net (yenduc(at)sbcglobal.net) writes:
Mark
Quote: |
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
rv9jim(at)juno.com Guest
Posted: Thu May 08, 2008 5:31 am Post subject: sniffle valve in RV 7A |
I guess I am missing something. With fuel injection, you will not have
fuel "dripping" down into the air box. The sniffle valve is necessary
with a carburator style fuel system. With that system you can cause raw
fuel to exceed the ability of the engine to ingest it. Especially if you
have an accelertor pump on the carb. That will possibly let fuel run back
into the air filter box. Am I in error? I have AFP system and it has
the fuel purge system which will take off all fuel pressure in the shut
down phase. During a starting phase the fuel is placed just in front of
the intake valve and "should" all be ingested.
Jim Nelson
IO-360
Posted: Thu May 08, 2008 6:48 am Post subject: sniffle valve in RV 7A |
On an IO 360 with horizontal induction mounted forward of a cold air
sump, small amounts of gas can pool in the sump after shutdown. A
sniffle valve is used to drain these few drops.
On May 8, 2008, at 6:25 AM, James H Nelson wrote:
have
raw
if you
back
shut
front of
Jim Nelson
IO-360
stein(at)steinair.com Guest
Posted: Thu May 08, 2008 8:15 am Post subject: sniffle valve in RV 7A |
Actually you can and will sometimes have fuel drain back down the intake
tubes with an injected system. Prime it for a few seconds too long and
it'll start dribbling, and sometimes on shutdown you can get a wee bit as
well. It's standard practice to at least put a "weep hole" in the FAB or
somewhere at the low point to make sure fuel doesn't pool where you don't
want it.
My 2 cents as usual.
Stein
[quote]--
Posted: Thu May 08, 2008 5:59 pm Post subject: sniffle valve in RV 7A |
The sniffle valve I got from Superior with my engine sucks. Or more
properly does not seal well under suction ( I can detect a slight leak
when I check it by blowing backwards on it). I believe Dan Checkoway
told me he replaced his with a better one but I lost my notes. Anyone
have a sniffle valve source?
dave
intake
and
bit as
FAB or
don't
want it.
Stein
Mark Phillips in TN
Posted: Thu May 08, 2008 6:38 pm Post subject: sniffle valve in RV 7A |
In a message dated 05/08/2008 8:33:29 AM Central Daylight Time, rv9jim(at)juno.com writes:
Quote: | I guess I am missing something. With fuel injection, you will not have
the intake valve and "should" all be ingested. |
Yes, but only while the engine is cranking. When opened, the purge valve routes all fuel back to wherever it is plumbed, and prevents any from entering the engine via the spider when it is open, which is very useful to run cool fuel through the entire system with the boost pump on to help avoid vapor lock if the engine is hot. BUT- any time the boost pump is on (even is mixture control is at idle cut-off), "some" fuel is being discharged from the injectors. If not ingested by the cylinders by cranking the engine, it simply runs down the intake tubes into the "sump" (actually, the manifold under the oil sump) and will accumulate there. Hence the need to drain it via the sniffle valve. Careful control of the boost pump and purge valve will mitigate this drainage, but ultimately some fuel will wind up in the manifold. The AFP system will always "leak" fuel at the injectors if the purge valve is closed and there is fuel pressure, hence the need for the valve. This is one reason the purge valve is necessary, since pulling mixture to ICO will possibly not shut down a running engine as some fuel is still getting through the injectors. Opening the purge valve is the only way to completely shut all fuel flow off to the injectors. (Well, you could always shut off the fuel supply from the tanks or run them dry...)
On a carbureted engine, pumping the throttle will definately shoot raw gas into the intake and if the engine is not cranking, this fuel would fall back into the air box, potentially creating a fire hazard. I never pump the throttle on my carbureted engine unless it is cranking for this very reason.
Are you currently running your AFP equipped engine? If so, what is your start procedure, cold & hot?
Mark
Mark Phillips in TN
Posted: Thu May 08, 2008 7:19 pm Post subject: sniffle valve in RV 7A |
In a message dated 05/08/2008 9:01:55 PM Central Daylight Time, yenduc(at)sbcglobal.net writes:
when I check it by blowing backwards on it). |
I performed the same test on the valve I received in Vans FWF kit and it did the same as you describe. Concerned about this, I contacted tech support and was informed this was normal and the tiny amount of leakage would have no discernable effect. Consider the total amount of air consumed by the engine against the amount of air leaking past the valve. The engine (Aerosport IO-360) performed quite nicely with this valve installed both while engine running and while draining...
Mark
Don
Posted: Fri May 09, 2008 1:45 pm Post subject: Re: sniffle valve in RV 7A |
[quote="yenduc(at)sbcglobal.net"]The sniffle valve I got from Superior with my engine sucks. Or more
dave
We make manifold drains (sniffel valves). You can attach a #4 hose to this part to route the fuel away from the exhaust and out the cowling. In a tight installation where the part cannot hang straight down, you can install a 90 degree pipe fitting to the sump and run a hose back to the manifold drain. As long as the little check ball can fall open when the engine is off it will work.
The P/N is 1090138 $17.00.
Don at Airflow Performance.
Paul Valovich
Posted: Sat May 10, 2008 7:50 am Post subject: sniffle valve in RV 7A |
I purchased a new IO-360 from Aerosport. It had provisions for a sniffle valve, so I installed it. Pretty much a no-brainer installation, although I haven’t reached the first engine start page yet.
Am I missing something? What’s the downside of having a sniffle valve?
My plane will be based at Inyokern in the middle of the Mojave Desert. Summer heat will be an issue. Seemed to me, anything that helped prevent vapor lock problems was ok.
Paul Valovich
RV-8A N192NM LuJaRo
Wiring 99% done – canopy is next
mr.sun
Posted: Sat May 10, 2008 8:24 am Post subject: sniffle valve in RV 7A |
I installed a sniffle valve on my 4 year old RV-7 after speaking to the Aerosport folks. I've been having hot start- flooding issues IO-360 w/forward facing induction. The problem is gone now and it starts every time. However, I can't say whether the solution was the new battery I installed, the valve or my improved starting technique. Unfortunately, I couldn't get the valve installed in the rear of the sump so a little gas sits there after a hot shut-down. I know this because I can lift the tail and see a bit of fuel drip out from the sniffle valve. There are two spots to install the valve on my engine but the rear spot isn't usable due to exhaust components, etc. Just some info.
Do not Archive
On Sat, May 10, 2008 at 8:46 AM, Valovich, Paul <pvalovich(at)dcscorp.com (pvalovich(at)dcscorp.com)> wrote:
I purchased a new IO-360 from Aerosport. It had provisions for a sniffle valve, so I installed it. Pretty much a no-brainer installation, although I haven't reached the first engine start page yet.
Am I missing something? What's the downside of having a sniffle valve?
Paul Valovich
RV-8A N192NM LuJaRo
Quote: |
t="_blank">http://www.matronics.com/Navigator?RV-List
tp://forums.matronics.com
_________________ Greg RV-7 |
Mark Phillips in TN
Posted: Sat May 10, 2008 7:37 pm Post subject: sniffle valve in RV 7A |
In a message dated 05/10/2008 10:52:54 AM Central Daylight Time, pvalovich(at)dcscorp.com writes:
Quote: | Seemed to me, anything that helped prevent vapor lock problems was ok. |
I really don't believe the sniffle valve has anything to do with vapor lock- it is only to allow raw fuel that can accumulate in the intake manifold between the fuel servo and the intake tubes to drain. By design in an injected engine, there SHOULD be no fuel in this area- fuel should only enter the intake airstream at the injector and pass immediately to the cylinder. In the AFP system I am familiar with, if the fuel system is pressurized by the boost pump and the engine is not cranking, some fuel will discharge from the injector nozzles and run down the intake tubes into the manifold. This is the reason for the sniffle valve- to allow this fuel to drain from this area where it is not meant to be. Is it "bad" to have some fuel pooling here? I don't know, but I doubt normal engine running airflow would cause much to be ingested into the engine. It would likely remove itself after "some" period of time by simple evaporation into the airstream.
Some might look at the sniffle valve as a band-aid for less-than-ideal understanding & operation of the injection system, but in my experience if you leave the boost pump running for more than 5 or 10 seconds when the engine is not running or cranking (purge valve closed) there WILL be fuel running out the sniffle valve and deposited wherever gravity dictates.
The AFP system is an excellent fuel delivery system in wide use, but just like that stick poking up between your legs, if not used as it was intended to be used, it can cause you some measure of grief.
It appears Don checks this list occasionally, so if I am in error, PLEASE correct & elaborate.
Mark
