now back to XL building
chris Sinfield
PostPosted: Thu May 15, 2008 11:05 pm    Post subject: now back to XL building Reply with quote
OK
I thought I would ask an XL building Question just to be different.
I have just noticed a difference in the plans and the parts list
I am building the Center Console and side fairings 6-K-2 no 3 is the side fairing at 200 wide and 480 high. In the new Illustrated parts guide page 6-XN-24 Duel stick option it shows a new longer side fairing going up and over the foot channel as well as new parts 6K2-4.
Has there been a change I missed, or is this longer side fairing part of the duel stick plans?? I was going to build a longer side fairing anyway to cover the rudder cables.
So has anyone got a copy of the extended side fairings? what are the extra dimensions length and hight ect??
back into building.
Chris
Jaybannist(at)cs.com
PostPosted: Fri May 16, 2008 5:05 am    Post subject: now back to XL building Reply with quote
Chris,
I chose the dual sticks option for my XL. During a lull in building, I constructed the center console as shown on the original drawings. It has the full side panels that fasten to the floor. When I got my dual sticks kit, I discovered that the side panels would interfere with the rods that go from the sticks to the horn on the torque tube; plus it would make installation of the fuel selector valve and hoses very difficult. I designed and fabbed an new one from .032 6061-T6 (see photo). It has the sides turned down about 2". I may install larger side panels to hide some of the "stuff" underneath; but that is a project for much later. If you need dimensions, let me know.
Jay in Dallas CH 601XL N2630J "lil Bruiser"
"chris Sinfield" <chris_sinfield(at)yahoo.com.au> wrote:
OK
back into building.
Chris
 Filesize:  182.05 KB
 Viewed:  495 Time(s)
malcolmhunt(at)mha1.fsbus
PostPosted: Fri May 16, 2008 12:46 pm    Post subject: now back to XL building Reply with quote
Dear List
It is a shame that Zenith have not updated their drawing list since March
2006. Whilst we may not be able to use the changes it would be nice to
know what they are and possibly the reason for the change.
Malcolm Hunt
CH601XL Plans builder in England
amyvega2005(at)earthlink.
PostPosted: Fri May 16, 2008 5:15 pm    Post subject: now back to XL building Reply with quote
the part you are making is more easthetics than anything, just make a template with cardbaord and make your own. nothing to complicated. as for the gent in U.K. Loosen up, its not a big deal.
Juan
chris Sinfield
PostPosted: Fri May 16, 2008 6:21 pm    Post subject: Re: now back to XL building Reply with quote
I was planning to just extend it as per the parts drawing , but if anyone has the measurements or actual plans drawing it would sure make life easier.
Chris
PostPosted: Sat May 17, 2008 5:44 am    Post subject: now back to XL building Reply with quote
Chris,
I have attached two pdfs that can be put together to form a full size pattern of what I built. For scaling, the "match line" must be exactly 10" long. Let me know if you have questions.
Jay in Dallas
I was planning to just extend it as per the photo , but if anyone has the measurements or drawing it would sure make life easier.
Chris
http://forums.matronics.com/viewtopic.php?p=183505#183505
Console01.pdf
 Filename:  Console01.pdf
 Filesize:  15.25 KB
 Downloaded:  406 Time(s)
Console02.pdf
 Filename:  Console02.pdf
 Filesize:  14.46 KB
