lwhitlow
Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
Posted: Sun Jun 08, 2008 1:27 pm Post subject: Nose Wheel Bearings Questions |
All
I've been working on the nose gear and pulled the Matco Wheel out for a test fit (kit is from Nov 2005)
The included bearings have the name Azusua on them and are stamped made in China.
Any issues with these wheels / bearings that anyone would care to comment on?? And while we're at it, What grease should I pack them with and how often should I repack them?
Thanks in Advance
Larry
601XL
Posted: Sun Jun 08, 2008 3:24 pm Post subject: Nose Wheel Bearings Questions |
Larry,
I've never heard or read anything that cast doubt on Azusua Bearing
quality. I thought the bearings would be sealed each side and not
require any grease.
If you need to inspect these every year (without seals), it's probably a
good idea to repack them at annual inspection with any good white
lithium grease.
lwhitlow wrote:
Quote: |
All
Thanks in Advance
Larry
601XL
http://forums.matronics.com/viewtopic.php?p=186858#186858
Aerolitellc(at)aol.com Guest
Posted: Mon Jun 09, 2008 12:13 am Post subject: Nose Wheel Bearings Questions |
Ours fell apart after about 10 hours (couldn't find any of the bearings) if it is the same one piece bearing. If you have the small axle I would call zenith and upgrade to the bearings that comes with the new kits. They use thicker axles and better bearings and I think the axle is only like 8 bucks.
Jeff
Thanks in Advance
Larry
601XL
Get trade secrets for amazing burgers. Watch "Cooking with Tyler Florence" on AOL Food.
jmcburney(at)pobox.com Guest
Posted: Mon Jun 09, 2008 6:46 am Post subject: Nose Wheel Bearings Questions |
Hi, Larry (McFarland) and List,
I've always used wheel bearing grease to pack this type of bearing, mostly
on automotive front wheel bearings. They definitely get more use than
airplane wheels. Seems to me that white lithium might break down sooner.
What say you?
Blue skies and tailwinds
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
Posted: Mon Jun 09, 2008 7:35 am Post subject: Nose Wheel Bearings Questions |
Hi Jim,
Lithium is additive to lubricating grease to raise temperature tolerance
and maintain viscosity. It doesn't absorb water and is non corrosive
unlike
some general products sold as wheel and bearing grease. I don't think
the stuff breaks down if you clean and repack with any regularity.
I check mine at annual inspection, but my bearings are sealed both
sides, so I will be replacing the bearings within a 5 year period.
Larry McFarland at www.macsmachine.com
What say you?
Jim
CH-801
DeltaHawk diesel
Augusta GA
90% done, 90% left
ronlee
Posted: Mon Jun 09, 2008 10:20 am Post subject: Re: Nose Wheel Bearings Questions |
I think you are looking at a sealed ball bearing as that is what my 701 has and not a tapered bearing the would need to be preloaded. If you preloaded the sealed ball bearings (pinch the bearings together) they will fail soon. When all is in place you should have some end play to each side on the wheel. If you don't and it is preloaded as you would a tapered roller bearing it will certainly fail soon. Do not preload the mains either, give them a bit of space. A little space will allow the brake pads to be pushed back from the rotars a bit which will ease the friction on the pads and allow a more free wheeling on take off, thats good! Alot of this was gone through some time ago. I'm sure it is in the archives somewhere.
Ron Lee
_________________ Ron Lee
Tucson, Arizona |
graeme(at)coletoolcentre. Guest
Posted: Mon Jun 09, 2008 1:33 pm Post subject: Nose Wheel Bearings Questions |
Straight sealed bearings will fail with side load.
I modified my wheels by making a spacer to keep the inner part of the
bearing in the correct position. this would also spread the side load over
both bearings,
With out a spacer the correct tension is guess work.
Graemecns
freonmen(at)verizon.net Guest
Posted: Tue Jun 10, 2008 5:17 pm Post subject: Nose Wheel Bearings Questions |
Hay U all,I just went through this bearing problem on my 601,I had the 5/8 roller bearing,I replaced it with a 5/8 tapered, much less friction. Qestion call Pat 941 270 7802
Posted: Wed Jun 11, 2008 5:42 am Post subject: Nose Wheel Bearings Questions |
Hi Pat,
Do you have a number for that tapered roller bearing?
pat & lyn wrote:
Quote: | Hay U all,I just went through this bearing problem on my 601,I had
