mprather(at)spro.net Guest
Posted: Wed Jun 11, 2008 8:41 am Post subject: Bridge Diodes use |
I think this is the point that nobody was making.. Vf is not the knee
voltage. Bob White sent me a link to a Fairchild datasheet that showed
the I-V curve for one of their devices. Forward biasing conduction got
going around 0.6V - 0.7V, but at the rated current the voltage drop was up
around 1.0V - 1.1V. Eric, had you mentioned this early in the discussion,
I think we could have avoided a bunch of this churning...
http://www.fairchildsemi.com/ds/1N/1N4007.pdf
I still haven't seen where B&C stated that the voltage drop would be half
by running in parallel.. Certainly the voltage drop is reduced by running
the diode lower on the I-V curve for a given buss current.. But not by
half obviously. Maybe an estimate would be halfway between the published
Vf and the knee voltage.
Matt
Quote: | The Vf of a diode is a strongly influenced by current. A diode can be
0.7
Quote: | Vf at zero Amps, and 1.0 Vf at 10A and 1.2 Vf at 12.5. For this you have
to read the data sheet. What?! Radio Shack doesn't supply one?! Then
just
Eric M. Jones
Posted: Wed Jun 11, 2008 9:20 am Post subject: Re: Bridge Diodes use |
Quote: | I think this is the point that nobody was making.. Vf is not the knee voltage. Bob White sent me a link to a Fairchild datasheet that showed the I-V curve for one of their devices. Forward biasing conduction got going around 0.6V - 0.7V, but at the rated current the voltage drop was up around 1.0V - 1.1V. Eric, had you mentioned this early in the discussion, I think we could have avoided a bunch of this churning...
half obviously. Maybe an estimate would be halfway between the published Vf and the knee voltage.
Regards, Matt |
Matt, et al.
See: http://www.bandc.biz/Diode_Installation.pdf
I don't claim that B & C ever stated that diodes' Vf could be summed like parallel mosfets (etc.). But I saw the 0.6 Vf on their schematic as a very suspicious indicator that somebody thought so, and that this should be attended to.
Yes, Matt, maybe I should have clarified some points earlier. But it was 100 degrees yesterday, fer chis'sakes. Thanks for your sage input. (Ahem...which you should have said earlier....)
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
echristley(at)nc.rr.com Guest
Posted: Wed Jun 11, 2008 9:41 am Post subject: Bridge Diodes use |
Eric M. Jones wrote:
Quote: | The Vf of a diode is a strongly influenced by current. A diode can be 0.7 Vf at zero Amps, and 1.0 Vf at 10A and 1.2 Vf at 12.5. For this you have to read the data sheet. What?! Radio Shack doesn't supply one?! Then just guess and hope you're right. Double up on the life insurance, too.
Wow! Hyperbole and fearmongering. All in the same post.
Are you sure you don't work for those 'news" organizations that tell us
how we're killing all our children with minute traces of pesticides in
our apples? You could have a career there, you know.
You're trying to sell a product with minor improvements in areas that
don't matter. Your diode uses half the power. We get it. The only
time that would possibly mean anything is in a power out situation. In
that situation, it will be removed from the circuit with a switch. The
rest of the time, the RadioShack solution is wasting 12W of heat. That
is 0.016 horsepower [international], which will mean the difference
between hitting the trees versus warbird type climb out (NOT!). If a
system is so loaded that 12W makes a difference during normal operations
the plane won't be flying much anyway. The alternator/generator will be
constantly burning up. You state your solution doesn't weigh as much.
OK. Some guys obsess over every ounce. More power to them. If I
needed 100 of these, it might make a difference. The call out is for
exactly one in most cases. The draft in the closed hangar when I weigh
my plane will have more effect on the finish weight.
The Radio Shack rectifier has been recommended, and presumably used by
builders, for years. It has proven adequate to the tasks asked of it.
It was chosen for its price, availability, and ease of construction. If
it there had been any instance of them causing harm, financial or
physical, someone somewhere would have said something about it. Enough
with the smoke, mirrors and demagogy. You stated the benefits of your
solution. Some see validity to your claims and buy your products, just
like some people swear by mystery chemical fuel additives. Most took a
look and responded with a big "Ho-hum". To suggest at this point that a
Radio Shack rectifier would require someone to need more life insurance
in an attempt to sell more product is at best ridiculous, and at worst
downright scandalous.
Posted: Wed Jun 11, 2008 10:06 am Post subject: Bridge Diodes use |
Quote: |
<emjones(at)charter.net>
snip
Quote: | Yes, Matt, maybe I should have clarified some points earlier. But it was
Glad I can bust your chops a bit.. Stay cool...
Matt-
prtrotter
Posted: Wed Jun 11, 2008 11:58 am Post subject: Bridge Diodes use |
All this banter has been very interesting C but I think some people are missing part of the point here E 6nbsp; The power dissipation is only one issue in diodes and the lessor important issue in my opinion E 6nbsp; It is easy to deal with heat dissipation with the proper heat sink E 6nbsp; What concerns me is the voltage drop across a normal diode E 6nbsp; I don 7t to want to lose 1 E2 volts if the alternative is to lose less by using a Schotky diode that costs only pennies more E 6nbsp; This is especially critical if your alternator fails and you are on battery alone E 6nbsp; This voltage drop could be the difference between keeping things running properly and not E 6nbsp; Yes C you can parallel the diode with a switch as a direct E-bus feed C but I don 7t want that voltage drop in normal operations either E
6nbsp;
Just because something has worked well for years does not mean that newer products that perform better are not available today E 6nbsp; While the FWB is a nice package for mounting and wiring C it is no longer the best product for the application E 6nbsp; If we were to continue to think this way C there would be no innovation and we would all be running steam gauges rather than EFIS systems E 6nbsp; In all these discussions C I have never seen anybody make a statement that a plain diode is the best solution C only that it is adequate E 6nbsp; Adequate in not good enough for me if a better solution is available E 6nbsp; It is somewhat contradictory to install a 21st centrury flight instument system 6nbsp;connected to 6nbsp;a 1950 7s technology power system E
6nbsp;
Paul Trotter
RV-8
Finishing the Wiring
retasker(at)optonline.net Guest
Posted: Wed Jun 11, 2008 1:34 pm Post subject: Bridge Diodes use |
I suspect that it wasn't that at all. I suspect it was just someone
writing the installation document that "understood" that diodes have
about 0.6V drop. It is quite obvious that whomever wrote this didn't
know a whole lot about ratings and power dissipation. They didn't know
that there is no such thing as a "12W" heatsink without knowing a few
more parameters.
On the other hand, kudos for trying to educate users!
Dick Tasker
Posted: Thu Jun 12, 2008 7:12 am Post subject: Bridge Diodes use |
ptrotter(at)optonline.net wrote:
Quote: | Yes, you can parallel the diode with a switch as a direct E-bus feed, but I don't want that voltage drop in normal operations either.
Why? I can understand you being bothered by the idea that something is
just wasting power. Great. Fix that. That's what's beautiful about
getting away from the FAA that would dictate what you can do. But after
swapping out the FWB, don't bother giving a big sigh of relief and
proclaiming that you just saved someone's life. All you did was scratch
and itch, not cure world hunger.
Quote: | Just because something has worked well for years does not mean that newer products that perform better are not available today. While the FWB is a nice package for mounting and wiring, it is no longer the best product for the application. If we were to continue to think this way, there would be no innovation and we would all be running steam gauges rather than EFIS systems. In all these discussions, I have never seen anybody make a statement that a plain diode is the best solution, only that it is adequate. Adequate in not good enough for me if a better solution is available. It is somewhat contradictory to install a 21st centrury flight instument system connected to a 1950's technology power system.
You'll need to define "best". The BEST I know how to do would be to
save up $10K to have someone else paint my airplane. That would be the
BEST. But it ain't gonna happen. I'll be painting it in my garage,
with my $50 Harbor Freight HVLP gun, and with chemicals that are not
guaranteed to kill my family and neighbors. That is adequate.
Sufficient. Gets the job done. Then I'll go flying. (The $50 gun did
an excellent job with the Polyfiber chemicals on my airplanes belly and
control surfaces, BTW. The only problem was the MEK destroyed the can's
seal.)
The requirement for change isn't to prove the old method inadequate.
The requirement is to prove the new method superior. "Superior"
includes not just minor esoteric operating benefits, but acquisition,
build complexity, cost, and whatever else someone might be concerned
about. I say the EFIS is better because it is lighter, more reliable,
easier to build into the plane, easier to source (one piece vs several)
and cheaper. I'll be buying a Dynon very soon now (I've installed their
mounting fixture, but I've been waiting till the last minute to buy the
actual unit). Whether you agree with my analysis or not, I have defined
what I consider to be "better".
OTOH, I see no measurable benefit to the Schottky diode for this
application. The argument is that it conserves power in use, but that
power consumption doesn't rank worthy of merit. I also see having to
purchase from a seperate source being an additional headache. I see the
more complex build requirements being more of a headache. While the
extra expense is marginal, it is also pointless. The Schottky diode
does not meet my criteria for being better. If the Schottky were widely
available in a package like the FWB it might be different, but with the
information I have I declare the FWB is most definitely the best product
If you feel the arguments presented for Schottky diodes make it a better
solution, GREAT!! Go buy you a bagful if it suits you. But realize
that many of us don't see it that way, and declaring that we should
consider doubling our life insurance is fearmongering, disingenuous
bull. There are NO safety issues with the FWB solution.
rhdudley1(at)bellsouth.ne Guest
Posted: Thu Jun 12, 2008 8:31 am Post subject: Bridge Diodes use |
Hear Hear!! Ernest.
There is an old expression: "Perfection is the enemy of good enough". Though
one man's perfection is another's absurd extravagance.
Richard Dudley
RV-6A flying with Z-11
nuckolls.bob(at)cox.net Guest
Posted: Thu Jun 12, 2008 3:18 pm Post subject: Bridge Diodes use |
At 06:28 PM 6/10/2008 +0200, you wrote:
Quote: | > >On B & C Diode Installation sheet they state that "Heatsink must
> dissipate 0.6 X Amps = Watts. Example For 20 Amp Essential Bus, 0.6 X 20
> = 12 Watt Heatsink".
In my experience, I have never come across a 12W heatsink. Nor a 1W or
1000W heatsink.
A heatsink is chosen appropriate to the temperature rise above ambient the
casing of the device can tolerate, or what the spec-sheet says. A single
machined-bolt head can dissipate 12W without any additional cooling,
however only when it reaches 200 degrees C (thumbsuck). If you can only
tolerate a 1degC increase in temperature, the heatsink required to
dissipate 12W will be the size of a large desk.
So, a specsheet specifies the heatsinking requirements in [degrees above
ambient]/[Watt], or specifies the maximum allowable temperature. So
consider an ambient of 23degC, a maximum of 100degC, and we have
calculated that the device will need to dissipate 10W. That gives us a
requirement for a 7.7deg/Watt heatsink, which can be ordered accordingly.
I understand the calculations relating to dissipation of heat, and IIRC a
Schottky diode, with a forward bias voltage of 0.2V rather than the
0.6~0.7V of a regular diode, dissipates 1/3 the energy for a given
current. However, there are always other considerations that have not been
touched in this discussion (such as thermal robustness, vibration
tolerance, ease of mounting), some of which are the same for both Schottky
diodes and for normal ones, and others which will draw very clear lines in
the sand precluding one or both from certain applications.
Very good! You have nailed the physics of heat-sink
sizing. Any size heatsink will dissipate the energies of
ANY size heat source . . . the question to be asked and
answered is "hot hot does it get" over and above ambient
while being stoked at that energy level -AND- environmental
temperature.
B&C's advice was ill worded but I don't work for them
any more. At the same time, I was hoping someone
to rise to the task of illuminating the physics of
the matter. As I write these words, there's a Schottky
device in the chamber getting it's thermal portrait
taken on the same heatsink that gave us a portrait of
a common power rectifier earlier this week. I'll have
comparable DATA to share in the not too distant future.
My hat's off to you sir.
( -Thomas Paine 1776- )
Posted: Thu Jun 12, 2008 3:25 pm Post subject: Bridge Diodes use |
At 06:05 PM 6/10/2008 -0600, you wrote:
Quote: |
Eric,
Am loath to get between you and Bob when discussing electrons but don't
understand what you said about bridge diode heat dissipation. If one
diode is running 20 amps with a forward voltage of 0.6 then it generates
0.6 x 20 = 12 watts of heat.
If two diodes in parallel are carrying the same 20 amps then the current
is split between the two diodes, with each having more or less half the
load with a total of 20 amps between them. So each diode is generating
about half of 12 watts with a total generation of still only 12 watts not 24.
What am I missing?
You'll never be 'stuck' between us my friend.
Your question is very much on point because until
a posting pointed out a little detail about
"thermal resistance" ratings of heat dissipation
systems, there was no way that anyone should be
expected understand what was correct and/or incorrect
about any of the advice.
Know that a Bob's Shop Notes is being crafted with
real data that will make the physics clear and give
you the tools with which to make a design decision
about your system. There is nothing inherently evil
or good about either device. Both technologies
have and are producing satisfactory performance when
used in a manner that does not violate their
performance envelopes.
The smoke and mirrors will be dealt with.
Posted: Thu Jun 12, 2008 3:54 pm Post subject: Bridge Diodes use |
One final thought about this.. If we keep our E-buses on a diet, the Vf
will be lower, and the heat loss through whatever diode you choose will be
less. These obese E-buses are killing us!! Hah.
Matt-
> half
> running
> Regards, Matt
Matt, et al.
attended to.
Eric M. Jones
113 Brentwood Drive
(508) 764-2072
http://forums.matronics.com/viewtopic.php?p=187390#187390
