jeynon2
Joined: 25 Oct 2007 Posts: 24 Location: Southern Illinois
Posted: Wed Jun 25, 2008 8:39 am Post subject: Elevator Trim |
I have recently received the new trim system for my Lightning to replace the bungee trim, but I am confused about how to balance the elevator. Is the balance bungee still used?
John Eynon
Lightning kit #53
| - The Matronics Lightning-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
info(at)flylightning.net Guest
Posted: Wed Jun 25, 2008 9:15 am Post subject: Elevator Trim |
The bungee system is eliminated completely.
Nick
EAFerguson(at)aol.com Guest
Posted: Wed Jun 25, 2008 3:50 pm Post subject: Elevator Trim |
In a message dated 6/25/2008 12:43:14 P.M. Eastern Daylight Time, jeynon2(at)verizon.net writes:
Quote: | I have recently received the new trim system for my Lightning to replace the bungee trim, but I am confused about how to balance the elevator. Is the balance bungee still used?
I recently added the new trim tab system and it's a tremendous improvement, but pitch control forces were a little heavy.
So - I just added a single 1/2" bungee loop using the old connection on the elevator pushrod. Flew for the first time today for ~ 1.0 with some touch & goes. I need less up trim on TO and landing. About 2 spaces down on the indicator for TO.
Before I added the bungee, full up trim left me with noticeable up stick force on final. Now that is gone. I don't even feed in full up on the trim tab.
One flight, 3 landings; not a significant data base, but tentative results are favorable. Your experience may be different. I have no way of measuring the applied bungee force.
Do be careful and make your first trials on a long, wide runway. Don't ask me to define long and wide, but if you're flying out of 1000' unpaved, I suggest you go somewhere else before connecting the bungee for the first time. My home field is 5700' by 100'
Has anybody else tried this?
Earl Ferguson
N17EF
Atlanta
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
pequeajim
Joined: 03 Sep 2006 Posts: 708 Location: New Holland, PA
Posted: Wed Jun 25, 2008 5:03 pm Post subject: Elevator Trim |
Earl, I replaced the stock bungee with the new trim tab. While I have not flown it yet, I did have a question about what to leave in place with the old system. Perhaps Nick or Buz could answer this one. I believe we took everything out, but of course the bungee attachments are still on the pushrod.
Jim!
From: owner-lightning-list-server(at)matronics.com [mailto:owner-lightning-list-server(at)matronics.com] On Behalf Of EAFerguson(at)aol.com
Sent: Wednesday, June 25, 2008 7:47 PM
To: lightning-list(at)matronics.com
Subject: Re: Elevator Trim
Quote: |
I have recently received the new trim system for my Lightning to replace the bungee trim, but I am confused about how to balance the elevator. Is the balance bungee still used? |
Earl Ferguson
N17EF
Atlanta
Quote: | http://www.matronics.com/Navigator?Lightning-List | 0123456789
jeynon2
Posted: Thu Jun 26, 2008 6:41 am Post subject: Re: Elevator Trim |
I expect that the weight of the unbalanced elevator would be equivalent to nose down trim requiring a certain amount of nose up trim to compensate. The weight of the elevator pushing down is always the same while the aerodynamic forces acting on the elevator and its trim tab increase with speed, so at higher speeds less compensation is needed. In either case I would think the additional trim requirements would add to drag.
I like Earl's approach of keeping enough "up bungee" to balance the elevator, but worry that that might retain some of the issues addressed with the new system.
When it comes to flight test time, I am fortunate to have a quiet 8000' by 150' runway available.
John Eynon
Lightning kit #53
[quote="EAFerguson(at)aol.com"]In a message dated 6/25/2008 12:43:14 P.M. Eastern Daylight Time, jeynon2(at)verizon.net writes:
Earl Ferguson
N17EF
Atlanta
N1BZRich(at)aol.com Guest
Posted: Thu Jun 26, 2008 2:38 pm Post subject: Elevator Trim |
The new trim system is designed to completely replace all bungees. Also, the new trim tab was sized (after many test flights) so as to completely trim off all pressures during all phases of "cruise" flight. However, when you lower the flaps, you are now flying a different wing - a different airplane. The trim tab size will trim off most of the nose down pressures when using up to 30 degrees of flaps and when at 65 to 70 mph on final and when close to gross weight. If the aircraft is lighter (more forward CG), or if you are slower, or if you have more than 30 degrees of flaps you will not have quite enough up trim. But again, this was done intentionally and designed that way. It is no problem to fly it as set up at any allowable weight and CG. The reason it is set up that was is if you trimmed off all pressures and have to make a last minute go around, you are going to have to really push forward on the stick to keep the airplane from really wanting to climb away from you and possibly stall. It can be a hand full on a last minute go around with all pressures trimmed off. With the relatively slow trim motor it is going to take some time to trim off these pressures during the go around and you could have your hands full. Adding a bungee back into the system will acerbate the problem with a last minute go around (making the airplane want to climb even more at slow speeds) in addition to causing the aircraft to feel as if it is neutrally or slightly unstable in pitch during normal cruise operations. That is exactly why the bungee system was done away with. The new system makes the airplane easier to fly, especially on long flights and it is certainly easier to maintain. The slightly heavy elevator feel on final with flaps down is only a slight out of trim condition, certainly well within the design limits of the airplane.
So bottom line, now you know why the system is designed like it is. With the many test hours that Nick and I have flown it on both the prototype and the new 2008 demonstrator, we have tested about all the conditions and found that the current set up is the best for all possible in-flight situations. If you don't believe me, just read the upcoming September issue of KitPlanes magazine and see what a PHD in aeronautical engineering that used to teach at the Navy test pilot school at PAX River had to say about the new trim system. But forget what he says in the article about "killing snakes" - heck, he was a Navy pilot that flew heavies.
Blue Skies,
Buz
PS: I am writing this because I know just how busy Nick is at the moment. When you read the July newsletter due out in a day or so, you will kind of get a feeling just why and how busy he is.
jeynon2
Posted: Thu Jun 26, 2008 3:19 pm Post subject: Re: Elevator Trim |
Thanks for your response Earl, and your explanation Buz. I'll strip her bare and go from there. It's all theory until she flies.
John Eynon
Lightning kit #53
Posted: Thu Jun 26, 2008 3:33 pm Post subject: Elevator Trim |
In a message dated 6/26/2008 7:22:41 P.M. Eastern Daylight Time, jeynon2(at)verizon.net writes:
Quote: | It's all theory until she flies.
Hey John, I like your analogy. And you are exactly right. That is the neat thing about EAB aircraft - you are the builder and you can build them the way you want. All of them are different in some way, so as you said, its all theory until yours flies. When you get a chance, send me some updates and photos on your build and I will get it in a future newsletter. You never know, something you write might just be the spark that ignites someone's fuse and gets them started building their Lightning. Then "kaboom", someone else has set their hair on fire and is now building their own airplane. That's what happened to my hair - several airplanes ago.
Blue skies,
buz
