kitfoxfugit(at)yahoo.com Guest
Posted: Thu Jun 12, 2008 10:25 pm Post subject: Engine and Performance Survey |
Whurlybird asks:
"What engine do you have mounted in what model Kitfox and how does your performance stack up? Looking for GPH, cruise, climb, overall impression, the sorts of things you would tell your friend if he was talking about buying the same engine."
Following are comments on my experience with the Rotax 912 UL, pros and cons. Hope this helps. Would like to see similar comments from users of other types.
Model IV Speedster came with a Rotax 912 UL, with 500 hrs, has over 900 hrs on it now. It is compact and light, supposedly weighs 132# with exhaust.
It uses motorcycle oil in a dry sump, requiring it to be pulled through a certain way before startup to purge the cylinders and special knowledge and care in changing the oil to get it all out. If overfilled, will puke out the extra. Has an oil filter. It is clean, leaks no oil, consumes no oil, keeps the same level from oil change to oil change. Has coolant, calls for a special waterless kind but I use water and antifreeze. Leaked a little for a while at one time.
It burns 87 Octane car gas. Alcohol is not a problem but it does not like lead, if burning 100LL, needs an additive. Has dual electronic ignition. Spark plugs are readily available and cheap, costing less than 1/10th the cost of aircraft plugs.
It has 2 carbs that must be synchronized but are altitude-compensating and usually shake out carb ice. It beat up one air cleaner against the firewall when they were mounted on the carbs and drew in air warmed by the exhaust. Now has the carb heat box on it with a big air cleaner up front. It has an enrichner "choke" that must be adjusted correctly and used a certain way on most, but not all, cold starts.
It fires up instantly and smoothly, with instant oil pressure, but must be operated above 1800 RPM to avoid damage to the gearbox. This can give thrust on landing without an adjustable prop. It does not overheat (with an Ivoprop). It runs smoothly and quietly, seems to have plenty of torque and power. It has been extremely reliable and comforting over lots of wild country.
Has a wide cruise range. Can putt along at estimated 2 to 2 1/2 GPH, 65 MPH doors open or 75 doors shut. Have not measured it exactly because do not fly it with full fuel when putting around, but can get 5 hours out of 12 gallons with some left. Don't want much fuel in it when folding the wings.
Experimenting with economy cruise, 4000 RPM 90 MPH, have not determined fuel burn. Cruise for going places is 5000 RPM, 117 MPH, up to 5 GPH, about 20 MPG, plan on 300 miles, but can go 400 with a good hour's reserve. If bumpy, have to slow below 113. Plane lacks gas cap fairings and strut fairings, has 6.00 x 6 tires, no wheel pants.
Vapor locked one time I think, would not hot start after awaiting customs clearance after a long flight. Had a broken exhaust once before I got it. Has a weak alternator, need to economize on the electrical load and be sure battery is up to 14 volts before shutdown. Battery needs some charge to excite alternator.
Can be hand propped, but is dangerous as it starts up so fast. Prop must not be turned backwards.
Has instant throttle response, which can be a problem for the inexperienced on takeoff. Has a vernier for small adjustments. With springs, throttle defaults to full power when the linkage breaks, which it did on me once. This is a good thing, unless you are taxiing through a crowd at an airshow. Be sure to have good brakes.
It requires special knowledge to operate and service. The owner/operator must obtain the knowledge. I do not think many A & P's are savvy to it yet. Lockwood has a DVD and classes.
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sun Jun 15, 2008 8:33 pm Post subject: Re: Engine and Performance Survey |
That is definitely a helpful testimonial. I would love to have that for a lot of engines. One more question for you. How much is an overhaul of a 912 supposed to normally cost, assuming no excessive wear or damage?
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Lynn Matteson
Posted: Sun Jun 29, 2008 5:34 am Post subject: Engine and Performance Survey |
I read John Allen's honest evaluation of his Rotax-powered Kitfox a
couple of weeks ago, and thought I'd respond with my experiences with
my Jabiru 2200-powered Kitfox.
I inserted my comments after John's with the heading: LM: blah,
blah, blah.....
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/541 hrs
On Jun 13, 2008, at 2:22 AM, John Allen wrote:
Quote: |
Whurlybird asks:
with exhaust.
LM: Model IV Speedster kit had no engine...chose new Jabiru 2200;
has over 540 hours on it now. Supposedly weighs 132 pounds
complete...and doesn't need radiator, coolant, or associated cooling
hoses.
Quote: | It uses motorcycle oil in a dry sump, requiring it to be pulled
at one time.
LM: Uses aviation oil in a typical aircraft engine wet sump.
Check oil with dipstick just like your car. Has an oil filter and
cooler, very minor leaks, but (mine) uses about 1 oz. per hour. No
coolant...uses air cooling principle, similar to most certified
airplane engines.
Quote: | It burns 87 Octane car gas. Alcohol is not a problem but it does
LM: Requires 100LL for the first 50 hrs., then 93 octane if
desired. Jabiru does not recommend using an additive for 100LL....who
knows why? Dual electronic ignition, using common automotive spark
plugs...NGK D9EA. I have had problems with my distributor rotors
failing, but by following their instructions of gluing to rotors on
(huh?), I've had no recurrence of this problem. Dist caps and rotors
are common automotive units, but the shafts lay horizontally, and
this might be why Jabiru suggests gluing rotors onto the shafts. I
thought this was ridiculous, so the first time I felt it necessary to
change rotors and caps, I used my years of automotive knowledge and
ignored their advice....WRONG! Follow their advice and put your ego
on hold, Lynn.
Quote: | It has 2 carbs that must be synchronized but are altitude-
LM: Has one Bing carb, altitude compensating, carb heat box with
air cleaner. This carb is similar to the one used by Rotax, but size
may be different. The Jabiru likes to have a nice smooth tube
bringing air to the carb, with at least a 4" straight section just
before carb to prevent turbulence within the carb.
Quote: | It fires up instantly and smoothly, with instant oil pressure, but
LM: Starts instantly, instant oil pressure, and it is suggested
to run at 1200 rpm initially. Landing can be done at 900-950
rpm...suggested idle speed. No choice yet (that I'm aware of) on
propellor choice. Must use wood so far as I know...(adjustable prop
by Sensenich is in the testing phase)
I think that Rotax had the edge on torque and power, due to their
gearbox and high-revving engine, and use of 3-bladed props. But I
like the Jabiru philosophy of low rpm, direct-drive, simple
mechanics, like most certified airplane engines.
Quote: | Has a wide cruise range. Can putt along at estimated 2 to 2 1/2
LM: I can cruise from 90-105mph, using 3.8-4.1 gallons per hour,
based on how I fly my plane. I once flew a couple of back-to-back 513-
mile tanks, and have never put in more than 23 gallons after doing
so. It can climb from 1200 fpm, down to 3-400 fpm, depending on
conditions. Leaving Cochise Co. airport in Arizona (4186' elev.) with
full tanks (27 gallons) , it took me 10 minutes to climb an
additional 4500 feet, on a hot day with high (don't recall) density
altitude.
Quote: | Experimenting with economy cruise, 4000 RPM 90 MPH, have not
LM: Have not experimented with economy fuel burn...too
boring. : ) I cruise at Jabiru's suggested 2750-2950 rpm
(redline=3300 rpm) 90-105mph...on last year's California trip, speed
was 98.4mph average, coming and going (6161 statute miles total) (at)
3.93gallons/hour average. Fuel burn on entire trip was 246.03
gallons, costing $1004.23....ain't gonna happen that cheap any time
soon! ($4.08/gallon avg. across the country)
Oh, I almost forgot...last year I flew as slow as the slowest C150
on a trip east, and averaged 3.69 gal./hr. Another average shows 3.42/
hr, but I can't recall the flying conditions, or how long the trip was.
Quote: | Vapor locked one time I think, would not hot start after awaiting
LM: I had one embarrassing incident at Oshkosh last year where
the engine did not start after taxiing for almost a mile, shutting it
down, and forgetting to shut off main fuel supply and engine flooded.
Too much cranking before realizing it was flooded caused battery to
go dead. Charging battery fixed it. My engine outputs 10 amps, so I
keep use of battery-powered devices to below 10 amps...later engines
have higher output from alternator.
Quote: | Can be hand propped, but is dangerous as it starts up so fast.
LM: Jabirus cannot be hand propped (unless after-market ignition
system is installed), but prop can be turned in either direction
without consequence.
brakes.
LM: My Jabiru also has instant throttle response, but the
instructions call for a slow push on throttle for best result. I
tweaked my carb to get instant response. Similar Bing carb, so spring
defaults to full throttle...spring can be removed, but this is not
good if you are flying and linkage breaks and you want to get home.
Better to have throttle go wide open and control speed with mag switch.
Quote: | It requires special knowledge to operate and service. The owner/
LM: No particular special knowledge required for the Jabiru. No
special precautions about rotating prop, no special precautions about
checking oil, no special coolants required...pretty much standard
engine knowledge will get you through.
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Fox5flyer Guest
Posted: Sun Jun 29, 2008 2:49 pm Post subject: Engine and Performance Survey |
DM: Great-pure fact-report guys. Excellent. I'll add mine because there are quite a few Subaru powered Foxes on this list and someone might be interested.
First, it's a 100hp EA81 normally aspirated Subaru with NSI conversion mounted on a S5 Kitfox. The Dyno graph that came with it indicated 112hp, but I have no idea which is correct. The manager of NSI is no longer around and the company was reclaimed by the owner (Maxwell) who stopped production of the EA81 package preferring to only produce the larger, higher hp, and heavier Soobs like the EJ22, 25, etc. which sort of makes me an orphan for factory support. However, most of the engine parts are standard off the shelf. For a reduction unit it uses a very robust NSI produced gear drive using a sprag clutch that works very well. However, it also is no longer factory supported and getting parts for it will be a much bigger challenge, especially as time goes on. All ancillary parts like motor mount, radiator, etc were very well made.
see below...
Sent: Sunday, June 29, 2008 8:32:06 AM
Subject: Re: Engine and Performance Survey
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
blah, blah.....
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Quote: | --> Kitfox-List message posted by: John Allen <kitfoxfugit(at)yahoo.com (kitfoxfugit(at)yahoo.com)>
Whurlybird asks:
with exhaust.
hoses.
DM: The NSI package is, compared to Jab and 912, heavy as are most Subarus. Mine, with motor mount, hoses, radiator, and everything it takes to make it run was 232 pounds. I know this because I weighed it myself on a large platform scale. This requires balance considerations and I chose to mount a 28amp AGM battery in the back and use a large Maule Tundra tailwheel with 2" extended spring. No further weight was needed in the tail. It's very difficult to build a light Kitfox using any Subaru, yet it's an option that can be considered.
at one time.
airplane engines.
DM: Uses any normal automotive oil. I use Castrol GTX 20w50 and a NAPA filter and it needs no oil cooler for cooling. No engine leaks after 377+ hours, however it uses about a pint over 20 hours. Requires normal automotive coolant for aluminum engines. Changing oil is very simple.
on hold, Lynn.
DM: Will burn pretty much any gas, but the compression is bumped up a bit so I use premium. I don't know if alcohol is being used in my area, but if it is I've seen no performance or economy differences. It uses dual electronic ignitions by Electromotive, but they go through coil joiners to a single standard spark plug per cylinder. One of my coil joiners went bad where I would get a miss, but the airplane was still flyable and it was a simple replacement.
DM: The NSI Soob has one Ellison throttle body fuel injector that requires a fuel pump for takeoff, but not cruise. Very simple and works well and on the plus side you can talk on the phone to the guy who builds it. Has carb heat, but never needed it. Also has the capability to lean just like an O200 so one can set it up for good economy. It can be a bit of a problem starting in cold weather (below 30f) due to a very light flywheel and the type of ignition modules it uses. IMO this is it's weakest trait. Different ignition modules would probably cure the problem.
DM: Starts right up in decent weather, but not cold--see above. Idles at 2000rpm to minimize tortional pulses from the prop, but can be idled down briefly to 1400 for landing. Takeoff rpm is about 5400. Again, this is a heavy package with the S5 already being much heavier than the IV, but the higher wing loading gives a slightly smoother ride in the bumps.
altitude.
DM: Can cruise from 75 to 110mph. Economy cruise where I primary keep it is about 105mph at 3.8gph. I don't know how fast it will go because I've never attempted it, but it will easily cruise 115, but at the expense of higher fuel burn. Climbout is anywhere between 750 on a hot day to 1200 on a cool day with good conditions. These numbers change with weight, obviously. but my numbers are with full tanks and just me at 175lbs and nearly sea level. I've never cruised any higher than 7.5, but never needed to either. Endurance would be about the same as the Jab or 912.
DM: I always economy cruise because I'm cheap. Generally at about 3900rpm, 22"mp, and about 105mph or a little faster with 3.8 to 4gph fuel burn. Part of the good cruise speed is due to the NSI electric pitch prop (more below) and lots of fairings including wheel pants. My strip is grass and relatively short, but there are no problems with either takeoff or landing performance.
DM: As with most engines, the Soob can also have vapor lock problems if left in hot sun with hot engine and attempting to start after about 30 minutes of heat soak. It always starts though, just not very quick. I usually try to point it into the breeze and open the oil inspection door open. It needs a good quality fuel valve because the fuel needs to be shut down to kill the engine and left off until restart, per manufacturer's instructions. Good 50amp Nippon Denso alternator.
DM: Due to the sprag clutch in the prop, it cannot be hand propped. It will just freewheel spin. The prop is an electrically cockpit adjustable (CAP) and works great. I pitch for max performance takeoff and after 500 feet I add pitch for cruise climb and when reaching altitude add more pitch for cruise then set up throttle, mixture, and pitch for best mp and cruise economy. The prop adds some complexity, but well worth it and once it's gotten used to becomes second nature. Again, the prop is no longer factory supported so some day I may have a problem finding parts.
brakes.
DM: My throttle response is good throughout its range and I operate it much like the Jabiru mainly to be easy on the engine.
Overall, it's a good package and gives good service. Subarus are known for their rugged reliability which is a plus, but each different engine builder sets them up differently so it's difficult to compare. Stratus has a good rep.
However, I probably wouldn't do it again, even if NSI was still supporting it. I would probably go with the ubiquitous and simple O200, or possibly a 912S if I could find one for the right price. I would definitely go for the extra bucks and get a cockpit adjustable prop.
If money is a big issue, the Subaru can be a good choice, but lacks the "big factory" type support. Many people convert their own.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 377+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
