Electro Cleaning
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List
LHusky
PostPosted: Sun Jun 29, 2008 6:33 pm    Post subject: Electro Cleaning Reply with quote
I am trying the electrolytic rust removal system on a rusted up rear case. It is so rusted, I cannot remove any bolts to get to the oil pump gears. If I do, they will break. This is a bad case to begin with. I made 2 electrodes and connected them with a pair of jumper cables. I then made up 3 gallons of water and baking soda. I put everything in a plastic bucket and hooked up a battery charger to it. I connected the red lead from the battery charger to the 2 electrodes in the water. These 2 electrodes are not touching the part that is being cleaned. I then hooked the negative terminal from the battery charger to the part itself. I then plugged in the charger.  I confirmed that I had a current through the 2 electrodes to the negative post on the part. I had a current! After a few minutes, I had a bubble action starting to come from the part. A few minutes later, I began seeing rust floating on top of the water. It is really starting to bubble and this may work! The web site I was on said that you can not over clean the part and that it will not do anything to the metal, so since this is a bad case, I am going to leave it in all night and see what it looks like in the morning. If this works, I am going to buy a tub to put my whole engine in and get it rust free and hopefully unfrozen, so I can disassemble it. We will see. I will keep you updated on this. I will see if the bolts on this case can be undone after this process. That will tell the tale!
Larry Husky
Madras, Oregon
Gas prices getting you down? Search AOL Autos for fuel-efficient used cars.
- The Matronics CorvairEngines-List Email Forum -
http://www.matronics.com/Navigator?CorvairEngines-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> CorvairEngines-List All times are GMT - 8 Hours
