icubob(at)newnorth.net Guest
Posted: Tue Jul 08, 2008 4:54 am Post subject: tailwheel leaf spring |
hi all, with all the tailwheel talk lately i want to throw out a question as i am debating this with my project [fisher dakota hawk]............. i read of a ''one tail spring'' installation failure and and a and p suggested replacing the one spring installation ''just before it breaks!'' so one spring sounds risky. i found a ''spring place;; in colorado that will supply untreated material to be formed, then heat treat it for me to leaf spring specs. sooooooooo my question is ''what is the opinion of safety and single spring installations?''
bob noffs
Michel
Posted: Tue Jul 08, 2008 5:23 am Post subject: tailwheel leaf spring |
| Quote: | From: bob noffs [icubob(at)newnorth.net]
installations?''
Well Bob, I am not metalurgist and know virtually nothing about the matter. But I noticed that my single leaf broke exactly in the middle, where the bend is greatest. If you can get someone to make a single leaf spring where that part is stronger/thicker/wider or whatever it takes to take the load, it may be good enough. It's like a mast or a tree; the higher it is, the less load it takes and the thinner it can be.
Just a thought.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
kitfoxpilot(at)msn.com Guest
The problem you could have with a single leaf spring break is the rudder hiting the ground and being damaged! your best bet would be a 3 leaf spring! this is what I put on my Kitfox because of this problem! Go 3 leaf for peace of mind.
Ray
Subject: Kitfox-List: tailwheel leaf spring
Date: Tue C 8 Jul 2008 07:51:07 -0500
hi all C with all the tailwheel talk lately i want to throw out a question as i am debating this with my project [fisher dakota hawk]............. i read of a ''one tail spring'' installation failure and and a and p suggested replacing the one spring installation ''just before it breaks!'' so one spring sounds risky. i found a ''spring place;; in colorado that will supply untreated material to be formed C then heat treat it for me to leaf spring specs. sooooooooo my question is ''what is the opinion of safety and single spring installations?''
bob noffs
target=_blank>http://www.matronics.com/Navigator?Kitfox-List
ttp://forums.matronics.com
=_blank>http://www.matronics.com/contribution
| The i’m Talkaton. Can 30-days of conversation change the world? Find out now. [quote][b]
Posted: Tue Jul 08, 2008 6:01 am Post subject: tailwheel leaf spring |
msm_9949(at)yahoo.com Guest
Posted: Tue Jul 08, 2008 6:38 am Post subject: tailwheel leaf spring |
Bob, As I suggested to Ryan there are alot of safe operational hours in the one leaf if you watch it and treat it right. Eventually tho, I'd want to replace it with at least a 2-leafer. Trick is knowing when. If it breaks while in service, there will be damage. Ask Michel and others.
Marco Menezes N99KX
Model 2 582-90 C-Box
--- On Tue, 7/8/08, bob noffs <icubob(at)newnorth.net> wrote:
| Quote: | From: bob noffs <icubob(at)newnorth.net>
Subject: tailwheel leaf spring
Date: Tuesday, July 8, 2008, 8:51 AM
bob noffs
pwmac(at)sisna.com Guest
Posted: Tue Jul 08, 2008 7:21 am Post subject: tailwheel leaf spring |
I have lots of experience with leaf springs in trucks that are
modified for long travel. Conclusion is that leafs work great if the
deflections are small due to less flex, like the stock cars and
trucks. But, the more the spring flexes the sooner fatigue results in
breakage and/or sag. The solution is to reduce the flex which results
in a very stiff ride. Thus the need for a softer tire to help the situation.
For the Kitfox multiple springs for much less deflection (=stiff) and
the Homebuilder soft tire or an inflatable tire are good ways to go.
Regards, Paul
At 07:20 AM 7/8/2008, you wrote:
| Quote: | > From: bob noffs [icubob(at)newnorth.net]
single spring
> installations?''
thinner it can be.
Just a thought.
Michel Verheughe
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jul 08, 2008 9:08 am Post subject: tailwheel leaf spring |
Just a thought or two and maybe an opinion here. the original springs were
single leaf. My guess is that there are lots of guys still flying with the
single leaf. Yes they can brake, but I doubt they would suddenly break
without some visible evidence of eminent failure. I doubt that most give
that close a preflight and wonder if checking at annual would be sufficient
to prevent breakage.
The springs should be springs. I wonder for the lighter Kitfoxes if three
springs would be like putting a bar between the tail of the airplane and the
tail wheel giving no spring action at all. The question relating to spring
thickness in the different configurations is a good one. If the three
spring assembly is three 1/4" leafs and the two spring has two 1/4" leafs
and I just measured the spring on my 1992 project and it is 1/4", you can
imagine the ride you would get (or rather the ride the aft structure of the
airplane would get) with a 3/4 inch of spring steel out there (especially if
routinely landing on grass or gravel). Also keep in mind that the average
big Kitfox will "bottom" out empty, weight wise, in the 760 lb range and
grow to over 1000 lbs as a few have done. My first Model IV was 45 lbs at
the tailwheel. I don't think I need a spring that would handle a 100 lb
tailwheel weight. It also came with a single leaf, but I added another due
to conversations on the list just like this one. The second leaf (from the
factory) was a partial leaf similar to what you see on muliple leaf systems
on motor vehicles. Interestingly, I had a bit over 900 hours on the
airplane when I made the emergency landing that destroyed the airplane and
the only airframe components that survived without any damage at all were
the main gear "Hammerhead" and tailwheel assemblies - there was one flat
tire. Not being an engineer, I sometimes wonder about the multiple leafs
with bolt attachments at both ends. I can't imagine they are as flexible as
a system of partial leaf springs.
I recently talked to a friend that wants to buy an ultralight to get in and
out of a pretty remote 300 acres he owns near here north of Placerville. I
Can't remember the type, but he mentioned the lift strut attach point on his
model of choice has a history of failure after so many years or hours of
use. As a solution, they routinely replace the part every two years, as I
recall. He seemed quite comfortable with that plan as, it seems, is the
rest of the fleets pilots. It sort of scares the daylights out of me as a
lift strut failure is a big deal and might just be a life altering
experience where the failure of a tailwheel spring might ruin a day or two.
But that being said, I don't think I would want my airplane beat up on the
ground with too much spring back there. Right now with no empennage on the
airplane the single leaf is too much spring as the caster angle gives the
same result that Steve reports with his three spring set-up.
Here is the opinion part. If the only spring available for replacement is
the three spring unit. I am tempted to use them one at a time and then plan
on replacing them periodically. Or more likely cutting the springs to give
a system like I had, essentially giving a tapering effect to the structure.
How often do we see motor vehicles on the side of the road with broken leaf
springs.
Lowell
Fox5flyer Guest
Posted: Tue Jul 08, 2008 9:33 am Post subject: tailwheel leaf spring |
Good points Lowell. Here's my opinion.
A simple solution for the lighter tail Foxes would be to buy the three leaf
unit and remove the center leaf and go with the main and helper leaves.
There is no way the two mains should be bolted front and back because they
need to move independently on hard landings. By using a main and helper it
would be simple to just cut and taper the helper to terminate a short
distance from the tailwheel bolt thereby giving it room to move
independently of the main. The heavier Foxes would probably be better with
all three leaves, but each should be able to move independently.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 377+ TT
"The aim of an argument or discussion should not be victory, but progress."
- Joseph Joubert
Lynn Matteson
Posted: Tue Jul 08, 2008 11:40 am Post subject: tailwheel leaf spring |
Why not just buy the 3-leaf spring from Kitfox and be done with it?
IF it will work with your model Kitfox, that is.
My original 2-leaf spring (I count all the leaves) broke and the
tailwheel flopped around, slightly damaging the rudder fabric (not
very bad as I haven't fixed it yet from 2 years ago). So I'd have to
say I have a VERY LOW opinion of a single leaf, or even a 2-leaf
installation. I count all the leaves, so the single to me is a single
leaf....a 2 leaf spring is a main leaf (1 leaf bolted on both ends),
and a helper/booster leaf bolted on just the fuselage end....and a 3-
leaf (2 main leaves bolted at both ends, and a helper/booster leaf
If I'm using the wrong terminology, how about John McBean...who sells
the 3-leaf spring that I now use....jumping in here and setting us
all straight?
The main thing to think about when looking at your tailwheel spring
setup is, what happens if the one main leaf breaks? Do you have
another? Where does the tailwheel assembly go when the main spring
breaks? The chances of a 2-MAIN-leaf spring breaking both mains in
the same incident seems to be "not bloody likely."
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
Status: flying w/545 hrs
On Jul 8, 2008, at 8:51 AM, bob noffs wrote:
| Quote: | hi all, with all the tailwheel talk lately i want to throw out a
bob noffs
http://www.matronics.com/Navigator?Kitfox-List_-
forums.matronics.com_-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Lynn Matteson
Posted: Tue Jul 08, 2008 11:48 am Post subject: tailwheel leaf spring |
Good analogy, Michel....now add another mast right next to the
original, throw a rope around the two masts at the top, and you've
just built in a safety factor of 100%. : )
Yeah, I know.....you weight junkies will just have to eat another
less burger.
Oops, one important problem with your mast/tree analogy...there's
nothing hanging off the very top of the mast/tree. In the airplane
scenario, we've got our asses hanging (sort of) off the end of that
mast/tree.
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
> single spring
> installations?''
Just a thought.
Michel Verheughe
Norway
List">http://www.matronics.com/Navigator?Kitfox-List</a>
forums.matronics.com</a>
www.matronics.com/contribution</a>
</b></font></pre>
N369LM |
Lynn Matteson
Posted: Tue Jul 08, 2008 12:36 pm Post subject: tailwheel leaf spring |
Gotta put in my 2 cents worth on the suggestion of a main and
helper....what happens if the main breaks?
If anybody has seen the 3-leaf (2 mains...1 helper) from John McBean
(www.kitfoxaircraft.com), you'll notice that the upper main leaf
(that's the middle spring) has an enlarged hole in the tailwheel end
of the spring. That is, the hole in this leaf is larger than the bolt
that protrudes through it. With the tailwheel-attaching bolt inserted
through the main leaves and the tailwheel assembly and tightened,
but not to the point of absolutely squeezing the whole assembly
together as one piece...unable to move...the spring assembly will be
able to flex, and the ride will be moderately soft/hard, according to
your definition. But it WILL flex, due to the inner member of this
assembly...the main leaf with the larger hole in it...being able to
"absorb" the differing length of travel of the "small-hole" main
leaf, because the bolt will be able to move within this larger hole.
When I assembled my 3-leaf spring, I greased the leaves, and used a
self-locking nut on the tailwheel end. This assembly loosens after
awhile, and I re-tighten it every few weeks. I plan on using a castle
nut and drilled bolt in exchange for the nylon self-locker and
undrilled bolt. This way I can adjust to some degree the tightness of
the clamping pressure, and maybe not have to retighten every so
often. Maybe an extra drilled hole in the bolt will allow some fine-
tuning of the clamping pressure, or perhaps a thin washer will do the
trick.
Hey, Deke, I landed in your back yard with no problems, didn't I? : )
Lynn Matteson
Kitfox IV Speedster
Jabiru 2200
On Jul 8, 2008, at 1:26 PM, fox5flyer wrote:
<fox5flyer(at)idealwifi.net>
three leaf unit and remove the center leaf and go with the main and
helper leaves. There is no way the two mains should be bolted front
and back because they need to move independently on hard landings.
By using a main and helper it would be simple to just cut and taper
the helper to terminate a short distance from the tailwheel bolt
thereby giving it room to move independently of the main. The
heavier Foxes would probably be better with all three leaves, but
Deke Morisse
Mikado Michigan
progress."
- Joseph Joubert
N369LM |
Michel
Posted: Tue Jul 08, 2008 1:09 pm Post subject: tailwheel leaf spring |
| Quote: | From: Lynn Matteson [lynnmatt(at)jps.net]
mast/tree.
Hey! You don't know where my ass is hanging from in the Norwegian woods, Lynn!
Seriously, I am always amazed to see engineer constructions where weight and strenght are optimized in beams and structures. I only observe that the original Kitfox spring leaf is an evenly thick and wide bent piece of metal. Anyone can then guess where it is most likely to break. Maybe a better design than the even leaf would be better for the strenght/weight ratio.
Michel Verheughe
Norway
Lynn Matteson
Posted: Tue Jul 08, 2008 2:37 pm Post subject: tailwheel leaf spring |
On Jul 8, 2008, at 5:06 PM, Michel Verheughe wrote:
| Quote: | > From: Lynn Matteson [lynnmatt(at)jps.net]
> mast/tree.
woods, Lynn!
You're right, and thank goodness I'm lacking in knowledge in THAT
department, Michel. : )
| Quote: | Seriously, I am always amazed to see engineer constructions where
I forgot all about the single leaf spring...made by Grove, wasn't
it?...and as I recall, they quit making it, right? Now there was a
problem waiting to happen, it seems to me. One break and your butt is
on the ground. Enter the 2-leaf spring....the main breaks, and your
butt is on the ground. Enter the 3-leaf spring...one break and
Viola!, you're still rolling on the tailwheel...in most cases. I'm
not saying that the 3-leaf spring (2 main leaves) is the end-all in
engineering practices, but it beats the other two ideas because it
has redundancy, unless I'm missing something.
Lynn
N369LM |
