Deems Davis
Posted: Thu Mar 02, 2006 3:20 pm Post subject: I'm stumped - Again! |
OK, I told you its not a rare event !
William, rick, anybody, How did you get the 5 AN470 4-5 rivets that
attach the F-1039D Rudder pedal brace to the stiffener and the firewall
recess???? (sec 27-6) My 3x rivet gun won't fit inside of the recess.The
gusset and diagonal stiffener prohibit getting a back rivet set on them
from the aft side, I'm about ready to use some CS 4-4's and be done with
it. :'(
(Honest, I read the plans this time and I'm still stumped)
Deems Davis # 406
Fuse
http://deemsrv10.com/
ron.mcgann(at)baesystems. Guest
Posted: Thu Mar 02, 2006 3:49 pm Post subject: I'm stumped - Again! |
Hi Deems,
I thought I was going to have problems there also, but I managed to shoot them with the flush set. I have the Avery 3x gun, it does not need to fit into the recess. You will need a bucking partner tho', so you can ensure the flush set does not bounce around.
cheers,
Ron
still riveting side skins
Rick S.
Posted: Thu Mar 02, 2006 4:38 pm Post subject: I'm stumped - Again! |
Deems,
Try the C-frame tool with the rivet gun attachment, you are talking about the row of rivets above the recess and below the rudder pedal brace right?
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Rick S.
Posted: Thu Mar 02, 2006 4:44 pm Post subject: I'm stumped - Again! |
FWIW I used the C-frame for the entire firewall short of the ones I could squeeze. Mine came with a set that hold the die, I supported the firewall with foam blocks and essentially back riveted the whole thing with the C-frame.
Rick S.
40185
RV-10
40185 |
Deems Davis
Posted: Thu Mar 02, 2006 5:40 pm Post subject: I'm stumped - Again! |
That worked, I used the swivel head flush set, with my wife bucking and
worked out fine, the one at the very top required finishing with the
double offset back rivet set, as the flush set got close enough to set
it, but not enough to flatten it appropriately.
THANKS
Deems Davis # 406
Fuse
McGANN, Ron wrote:
[quote] Hi Deems,
cheers,
Ron
wcurtis(at)core.com Guest
[quote]OK, I told you its not a rare event ! >William, rick, anybody, How did you get the 5 AN470 4-5 rivets >that attach the F-1039D Rudder pedal brace to the stiffener and >the firewall recess???? (sec 27-6) We all get stumped from time to time. I used the Cleveland extra long 12 inch back rivet set on these AN426AD4-5 rivets. You can use this if you do not have the brake (F-6122-1 tri-gear or other) bracket installed. http://wcurtis.nerv10.com/08fuselage/fuselage03u.html William Curtis http://nerv10.com/
