EAFerguson(at)aol.com Guest
Posted: Fri Jul 11, 2008 4:16 am Post subject: Prop weights |
In a message dated 7/11/2008 7:17:51 A.M. Eastern Daylight Time, jhausch(at)charter.net writes:
| Quote: | I wonder if the weight difference causes a fwd cg shift which would adversely affect the cruise speed?
The ground adjustable prop only weighs 2 lbs more than the wood prop. The extra weight is in the metal prop hub, so the rotational moment of inertia may be less for the ground adjustable. Unless you're trying to reduce weight like I was for the coast-to-coast record run, the weight difference isn't significant. Naturally you should do a revised W&B if you change.
Earl Ferguson
Get the scoop on last night's hottest shows and the live music scene in your area - Check out TourTracker.com!
| | - The Matronics Lightning-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Lightning-List |
