carlossa52(at)gmail.com Guest
Posted: Tue Jul 15, 2008 6:51 pm Post subject: do not assume |
So, you already know the bottom line to this note.
Now please bear with me while I vent a little - and share a lesson.
Eons ago, when I started building, I obsessed about getting a true straight edge (check archives, around late XXth century).
I eventually settled on (1) accepting that the edge of a sheet 4x8 or 4x12 is straight and (2) an 8' melamine shelf as a "ruler".
I also (3) assumed that an aluminum sheet, as delivered by the mill/dealer, is rectangular.
Weeks ago I cut the (outboard wing) skins from 4x12 sheets, using the assumptions above.
I have drilled the (HD) outboard nose skin and the top skin. All nice and clecoed.
Today, when I positioned the bottom skin in place, I noticed something was off. About 5 mm off.
As if the rear z was offset to one side by 5 mm. Pardon y French, but (at)#%!
So, I disassembled the whole thing, and, to verify if the top and bottom skins were (are) square, I placed them one of top of the other.
Well, they disagree. By about 5 mm.
I either made a mistake when cutting one of them or assumption (3) above isn't true.
Of course, it's now impossible to verify which one is true.
(In a few days I might admit it was my mistake, but for now I have to blame somebody/thing else.)
So there goes a hundred bucks (or so, we'll see when I buy another sheet) out the window and, more important, umpteen hours (technical term for several evenings) polishing the darn thing.
Does anybody know where I can get a precision, real large, square?
Carlos
CH601-HD, plans (as in "plans to finish someday")
One step for man, two steps backwards.
ch701builder
Joined: 07 Feb 2006 Posts: 119 Location: N38.9947,W105.1305,ALT. 9,100'
Posted: Tue Jul 15, 2008 7:42 pm Post subject: do not assume |
Hey Carlos,
One way to see it your corner is square is to do the 3-4-5 triangle measurement on the corner. That should get you a square corner to start with and go from there.
(3'side -- 4'side -- 5'diagonal) or any multiples of this,
such as 300mm--400mm--500mm, or double the distances 600mm--800mm--1000mm
Using these numbers should get you back to a square corner.
Good luck,
Keith
ch701 -- scratch
N 38.9947
W 105.1305
Alt. 9,100
jaybannist(at)cs.com Guest
Posted: Wed Jul 16, 2008 4:04 am Post subject: do not assume |
Carlos,
Try the hardware store. Look for a "drywall square".
Jay in Dallas
Al Hays
Carlos,
As an alternative to the excellent 3-4-5 triangle measurement Keith
suggests, I use a drywall square. It's like a 4 foot version of the
thing I've seen used at drafting tables before CAD came along. I
also use a carpenter's square for smaller items. I'd be lost at a
drafting table and don't know squat about CAD, but I trust the
drywall and framing squares. If you find a used drywall square, just
be sure it hasn't been bent or gotten loose from rough treatment.
Home Depot or Lowe's are convenient places to get new ones at
reasonable cost.
Al
CH701 & 601XL, N701GH & N5892H reserved
On Jul 15, 2008, at 10:46 PM, Carlos Sa wrote:
Quote: | Does anybody know where I can get a precision, real large, square?
Carlos
rsteele(at)rjsit.com Guest
Posted: Wed Jul 16, 2008 7:52 am Post subject: do not assume |
And don't assume any square you buy will be square, most aren't. In
particular framing squares usually need to be adjusted. You do this by
peening the corner to
open or close the square a bit. Peen the outside to close, the inside
to open.
I've found drywall squares to be better, but check them regularly.
If it makes you feel any better, I'm now fitting my first rear wing
skins. The pre-punched holes, done by a cnc machine, are off by 4mm
from rr1 to rr9. This, I
can tell you is a real pain in the neck.
And while we are on the subject, don't trust tape measures either. If
you use more
than one they should be checked against each other over whatever the
maximum length
you are using. I've found most I've used to be in agreement, but I've
seen at least
one that was off an inch in 25ft.
Ron
Posted: Wed Jul 16, 2008 9:07 am Post subject: do not assume |
Thanks to all that replied.
I too found that tape measures aren't to be blindly trusted.
Actually, this goes for any measuring tool bought at a hardware store, whether they have an aerospace department or not.
Carlos
2008/7/16 <rsteele(at)rjsit.com (rsteele(at)rjsit.com)>:
[quote] --> Zenith-List message posted by: <rsteele(at)rjsit.com (rsteele(at)rjsit.com)>
to open.
you use more
maximum length
seen at least
Ron
bryanmmartin
Posted: Wed Jul 16, 2008 2:34 pm Post subject: do not assume |
If you want to know if a sheet of metal really is rectangular, measure
the distance from diagonally opposite corners. If both diagonal
measurements are exactly the same, you have a rectangle. The same
method can be used to verify that the rectangle you have marked up for
cutting actually is rectangular before you cut it.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
raymondj(at)frontiernet.n Guest
Posted: Wed Jul 16, 2008 3:25 pm Post subject: do not assume |
This method will work IF you verify that parallel sided are the same length.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
Ron Lendon
Posted: Wed Jul 16, 2008 8:12 pm Post subject: Re: do not assume |
Carlos,
The diagonal measure is the quickest and most accurate to find out if it's square.
I have been using a full sheet of metal as a straight edge for making cuts, using the factory edge. Just set two sheets up, one is the part the top piece is the cut guide.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
Darryl Legg
Joined: 08 Nov 2007 Posts: 18 Location: Darwin, Australia
Posted: Thu Jul 17, 2008 5:13 am Post subject: Re: do not assume |
Hi Carlos,
I use a large ceconite square generally used by glaziers. It is 6ft long by 3ft on the 90 deg angle. Very handy. Your local glaziers should be able to point you in the right direction to purchase one.
Darryl.
do not archive.
