Erich_Weaver(at)URSCorp.c Guest
Posted: Sat Jul 19, 2008 2:48 pm Post subject: S700 switch pin positions |
Found an unused Carling 2-10 switch in my electrical supply box today, so pulled out my now ragged copy of the Aeroelectric Connection and my cheapo RS multimeter to confirm what I had previously posted - that the pin positions were transposed left to right from the diagram in the 'Connection.
They are indeed transposed, assuming a view looking at the back of the switch with the keyway up. The date code on the side of the switch is 0443.
I am sure that the transposition is not just a single switch anomaly, because I had more than one of these on my plane, and I remember making the wiring correction in multiple places - in my case, two p-mag switches and a landing lights/wig-wag switch.
regards,
Erich Weaver
This e-mail and any attachments are confidential. If you receive this message in error or are not the intended recipient, you should not retain, distribute, disclose or use any of this information and you should destroy the e-mail and any attachments or copies. [quote][b]
nuckolls.bob(at)cox.net Guest
Posted: Sat Jul 19, 2008 3:08 pm Post subject: S700 switch pin positions |
At 06:45 PM 7/19/2008 -0400, you wrote:
| Quote: | Found an unused Carling 2-10 switch in my electrical supply box today, so
regards,
Erich Weaver
Excellent hard data! Thank you sir. I've
not heard from Carling yet but it seems likely
that their "odd-man-out" position in the market
place for switches would be a powerful incentive
to swap columns and bring their functionality
into synchronization with the rest of the industry.
I think I'll be revising the switch ratings document
to include a caveat for testing any given switch
to determine it's position in the industry. Carling
is the only company I'm aware of that did not conform
but that doesn't mean there are not others.
It would be really cool if Carling could offer a date
range for the change-over.
( -Thomas Paine 1776- )
icubob(at)newnorth.net Guest
Posted: Mon Jul 21, 2008 3:02 am Post subject: S700 switch pin positions |
i also pulled out a 3 yr old carling 2-10 switch and it matched the diagram
of a switch as it was wired as a master in one of the ''z'' schematics. it
was correct according to the diagram in the schematic. i didnt compare it to
the chapter on switches. i vaguely remember though calling b and c about
this issue several years ago and was told a diagram [dont remember which]
was backwards. i guess i will double check the z drawing and the other
diagram in the book.
bob noffs
Posted: Mon Jul 21, 2008 6:12 am Post subject: S700 switch pin positions |
At 05:58 AM 7/21/2008 -0500, you wrote:
diagram of a switch as it was wired as a master in one of the ''z''
schematics. it was correct according to the diagram in the schematic. i
didnt compare it to the chapter on switches. i vaguely remember though
calling b and c about this issue several years ago and was told a diagram
[dont remember which] was backwards. i guess i will double check the z
drawing and the other diagram in the book.
Very good info sir. Your report combined with notes from
other folks suggests that Carling converted to the industry
wide conventions about 4 years ago. I'm hoping to hear from
somebody at Carling but not holding my breath.
I've put the switch article in my to-do bin and will update
it shortly to reflect this new data.
Thank you all for your help in sorting it out.
