john beirne
Posted: Mon Jul 28, 2008 1:35 pm Post subject: Kitfox III Hardware |
Hi All
As part of the my fox’s up coming annual I am replacing the majority of the hardware to include the wing and stabiliser strut rod ends, and (following a recent post regarding a failure) all the flight control rod ends,
However my problem is as follows, the build book I have gives the part Nos as, for example FRE-50, FRE 49 and so on.
None of the parts supplies companies (Aircraft spruce or LAS in the UK) list these part Nos in their inventory, is this a Denney part no,
Has anyone been down this route before, indeed would the present kitfox company supply hardware kits for older models?
Many thanks
John
lcfitt(at)sbcglobal.net Guest
Posted: Mon Jul 28, 2008 2:42 pm Post subject: Kitfox III Hardware |
John,
I wonder if replacing the rod ends will give you what you are after with
regard to the failure recently mentioned. As I understand it, it was the
stud the rod end was screwed onto that failed. It is my understanding,
further, that the threaded studs used by the early Kitofx kits were actually
allen bolts welded to the ends of the tubes. There was some discussion in
the past as to the possibility that the weld process somehow hardened the
bolt making it subject to work hardening. There have been failures at the
horizontal stabilizer in the past as well - the factory went to 1/4" vs.
3/16" after a couple of failures.
Lowell
pwmac(at)sisna.com Guest
Posted: Mon Jul 28, 2008 3:59 pm Post subject: Kitfox III Hardware |
Sure been there. Just go to Aircraft Spruce and
buy the one that fits. No problem. They are
standard parts. Don't worry about what the build
book says. It did not use industry part numbers
but used inventory numbers They are long gone.
The stuff you buy will be aircraft quality.
Paul
At 03:35 PM 7/28/2008, you wrote:
Quote: |
Hi All
Many thanks
John
http://forums.matronics.com/viewtopic.php?p=195418#195418
Lowell,
You are correct I still have the parts I
dissected. This was a cost cutting idea that was
never blessed by an engineer. Buying an "AN" part
will result in a much stronger solution.
Paul
At 04:37 PM 7/28/2008, you wrote:
John,
what you are after with regard to the failure
the stud the rod end was screwed onto that
failed. It is my understanding, further, that
were actually allen bolts welded to the ends of
the tubes. There was some discussion in the
somehow hardened the bolt making it subject to
factory went to 1/4" vs. 3/16" after a couple of failures.
Lowell
john beirne
Posted: Tue Jul 29, 2008 11:11 am Post subject: Re: Kitfox III Hardware |
Many thanks for the replies guys,
To determine the part no of each rod end would require removal and measuring
Perhaps there s someone who has done this already and still has the part Nos handy?
Many thanks in advance.
John
