orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Aug 05, 2008 5:45 pm Post subject: Plasma III to ACS switch wiring diagram |
Does anyone have a detailed wiring diagram of the way you wire up the ignition switch (I have the ACS master switch) to work with a single Plasma III? My left Mag is an impulse and the right will be the Plasma III.
I am trying to polish up the wiring diagrams so I can get serious at pulling wires and this is one of the last little things I need to hash out.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
bcondrey
Posted: Wed Aug 06, 2008 5:55 am Post subject: Plasma III to ACS switch wiring diagram |
Gary,
The LSE wires in just like a mag - you use pins 1 & 9 on the LSE output
connector instead of the P lead from the mag. When configured that way
you don't use any sort of switch for LSE power.
You will see references to the "keyswitch option" in LSE's documentation
but all of them support it, it's just a matter of whether the wire is
installed in the connector. You can add it yourself if it's not there.
Wiring from either the mag or LSE is single conductor shielded. There
is a "GND" terminal where the shields connect and "L" and "R" where the
center wire from the respective ignition goes. There will be 2
terminals labeled "GND" and you want the center one (not the one
adjacent to the "R" terminal). The paper document that came with the
switch may be the only place where the actual terminal labels exist.
Contact me offline and I can send you a file with the info. It's in a
large (file size) document so I won't post it here.
orchidman
Posted: Wed Aug 06, 2008 7:11 am Post subject: Re: Plasma III to ACS switch wiring diagram |
Thanks Bob. I am trying to get a handle on this. I ordered the Plasma at Osh and have downloaded the manual. They say that it should ship in about 3 weeks. If I can't get the wiring straight in my mind tonight I may give you a call.
RV10 - # 40674
(N2GB Flying) |
bcondrey
Posted: Wed Aug 06, 2008 7:20 am Post subject: Plasma III to ACS switch wiring diagram |
No problem! Hardest part about the install is install of the crank
sensor and magnets in the ring gear assembly. Easy solution is to send
the assembly to Klaus and he will install the magnets for about $50.
