pwmac(at)sisna.com Guest
Posted: Sun Sep 07, 2008 7:16 am Post subject: Control column pivot(Not happy with myself) |
For that kind of hole get a reamer with a pilot. Spend teh $$ and
avoid ruining the part. Never push a reamer.
Standard practice.
If you don't want to spring for the trick reamer use a drill bit with
a hand chuck from an old drill and slowly work up to the correct size
using hand force only. Use drills from a set of number sizes since
they offer smaller difference from size to size. I only found one or
two that had metal to be removed all the rest has just paint.
Sigh, I have a sign on my tool box left over from construction that
says "PULL THE REAMER"
Some of the holes on the KF need a long extension to avoid
interference. I have 3 of them that will extend a reamer about 3'.
This allows better alignment in some cases. Won't take the place of a
pilot reamer, but it does get those hard to reach holes.
BTW, My M-4 did not need a pilot reamer.
Paul
At 07:02 PM 9/6/2008, you wrote:
The problem with pulling it through is that it's on the closed end
of the mount. The tight space and the powder-coat inside the hole
made it impossible for me to pull the reamer through.
(http://imageshack.us)
Jorge Fernandez
Supersport
Just starting!
http://forums.matronics.com/viewtopic.php?p 2980#202980
Donroutledge(at)aol.com Guest
Posted: Sun Sep 07, 2008 8:02 am Post subject: Control column pivot(Not happy with myself) |
Not too savvy. How do you pull a reamer? I just can't picture it in my mind. Thanks, Don
In a message dated 9/7/2008 10:17:15 A.M. Central Daylight Time, pwmac(at)sisna.com writes:
| Quote: | --> Kitfox-List message posted by: paul wilson <pwmac(at)sisna.com>
Standard practice.
Paul
| Quote: | --> Kitfox-List message posted by: "jlfernan" <jlfernan(at)bellsouth.net>
Jorge Fernandez
Supersport
Just starting!
http://forums.matronics.com/viewtopic.php?p=202980#he es y --> - MATRONICS WEB FORUMS nbsp; - List Contribution Web Site ; =========================
Psssst...Have you heard the news? There's a new fashion blog, plus the latest fall trends and hair styles at StyleList.com.
jlfernan
Posted: Sun Sep 07, 2008 8:34 am Post subject: Re: Control column pivot(Not happy with myself) |
| Quote: | | Not too savvy. How do you pull a reamer? I just can't picture it in my mind. Thanks, Don |
Put it backwards through the hole then fit it into your hand drill.
After some some advice I received offline, I assembled the right mount with the control column. Once the nut and bolt were tightened everything squared up and everything was solid, no problem here. I'm still going to get a new right pivot.
_________________ Jorge Fernandez
Supersport
Fuselage/Forward Controls
http://websites.expercraft.com/jlfernan/ |
