Viper_on_line
Joined: 27 Apr 2008 Posts: 3 Location: Maitland Australia
lrm(at)skyhawg.com Guest
Posted: Wed Sep 10, 2008 6:33 am Post subject: Shoulder Harness attachment |
Yep, mine is a four point. I used a piece of aluminum flat stock, 3" X 1/8" I think. Run it all the way across the front of the baggage shelf. Then take another piece of the same and "T" it from the front center to the rear and bend it 90 degrees up for an inch or two. Of course you do this underneath the baggage shelf. Rivet or bolt it in several places. Then bolt your belts down. I feel a lot better with my setup than the original design of 3 points. You can get your aluminum flat stock at Lowe's or Home Depot. I always thought that their aluminum was cheap stuff. But one time when I was in the store I had them call the supplier and check, it is 6063 T5. It's good all around aluminum with plenty of strength for general use.
Take care, Larry N1345L
Viper_on_line wrote: [quote] Quote: | --> Zenith701801-List message posted by: "Viper_on_line" <randnc(at)bigpond.com> (randnc(at)bigpond.com)
I am used to a bit of security when I sit in a plane and am going to install a harness. Has anyone out there installed a 4 point harness rather than the Zenith lap and sash belt in their 701 or 801?
Now I am actually at that stage I find myself designing a roll cage suitable for a racing car rather than an attachment that would suit the 701.
Where do you secure the shoulder straps without over engineering the baggage shelf?
701 scratch builder
one day it will fly
[url=http://forums.matronics.com/viewtopic.php?p 3531#203531]http://forums.matronics.com/viewtopic.php?p 3531#203531[/url]
Checked by AVG - http://www.avg.com
| [b]
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
lgold(at)quantum-associat Guest
Posted: Wed Sep 10, 2008 12:32 pm Post subject: Shoulder Harness attachment |
Scratch,
The only change I made to my harness design to strengthen it was to add
plates inside/under the center seat belt attachment points to which I
attached 1/8" stainless cables to the opposite corners of the bottom of the
fus about 2' behind the seats. I have seen a situation where a very sudden
stop caused the center part of the seat to buckle, so I knew it needed to be
reinforced. My 701 kit was from 2004. I think that a rear plate for the
center seat belt attachment point now comes with the newer kits, but still
feel that this assembly needs to be anchored to the corner of fus to help
prevent it from buckling.
Les
701-N67MG
[quote] --
n85ae
Posted: Thu Sep 11, 2008 11:54 am Post subject: Re: Shoulder Harness attachment |
Something to think about, because Zenith sure did not do their engineering
calculation with regard to the seatbelts.
I calculated the stock 801 seat belt tabs at 200lb.s at 10G's in shear, if
indeed the rivets don't pull out before that. So I replaced them with 4130
steel the same thickness which I bolted with AN3's to the fueslage longerons. I also added structure to the center console.
Crash impacts can go up to 40/50G's and be survivable, so I'm not sure
what they were thinking when the designed the stock ones. But they were
not designed to handle more than the bare minimum.
I suppose if I crash that hard I might not survive anyway, but I sure don't
want to leave on account the seat belt tabs sheared.
Jeff
Viper_on_line
cal.riggs
Posted: Mon Sep 15, 2008 9:44 am Post subject: Re: Shoulder Harness attachment |
Slamming the engineering is rather arrogant unless you are a structural engineer and even then there are better ways to discuss the strength of a system. Since CH has experience in structural engineering, I'd be more likely to ask the question to him rather than making negative comments as to competency on the list.
I've attached a photo of the field tested seat belt attachment. The collision with the terrain resulted in crumpled distortion of the fuselage NOT the bolt pulling through the attachment. I'm more likely to assume that the structural engineer has calculated considerations of the strength of the fuselage and its characteristics under heavy loads. This crumpling seems to have some good features in that the pilot receives less bodily damage due to an immovable seat belt system.
Cal
n85ae wrote: | Something to think about, because Zenith sure did not do their engineering
Jeff |
Description: |
Crumpled seat belt attach point. |
Filesize: |
41.13 KB |
Viewed: |
537 Time(s) |
Description: |
Crumple at seat belt attach point. |
Filesize: |
41.13 KB |
Viewed: |
564 Time(s) |
n85ae
Posted: Mon Sep 15, 2008 11:23 am Post subject: Re: Shoulder Harness attachment |
Cal -
Glad you qualified that with "unless you are", because I hate being called
arrogant.
Jeff
Quote: | Slamming the engineering is rather arrogant unless you are a structural engineer and even then there are better ways to discuss the strength of a system. Since CH has experience in structural engineering, I'd be more likely to ask the question to him rather than making negative comments as to competency on the list.
Cal
n85ae
Posted: Mon Sep 15, 2008 11:28 am Post subject: Re: Shoulder Harness attachment |
Meaning, yes I am an engineer.
Jeff
cal.riggs
Posted: Tue Sep 16, 2008 5:08 pm Post subject: Re: Shoulder Harness attachment |
Jeff,
I figured you were... an engineer. What branch? AE?
I thought that showing the photo of the deformation of the fuselage at the shoulder harness attachment would show that maybe a calculation of shear force on an anchored piece of aluminum may not be an accurate representation of the complete picture. Being that I'm not a structural engineer (or even a mechanical engineer), I got the impression that your calculation only included the aluminum attachment piece, the bolt, and 200 lbs at 10Gs shear. If you, in fact, included force absorption due to the deformation of the fuselage structure, then I'd say we may have to consider replacing our stock seat belt tabs. However, I can't seem to get past the evidence that in an actual crash, the tab was stronger than the fuselage. At what point, with the inclusion of structural deformation, does the scenario of tab, bolt, 200lbs body take over?
Cal
n85ae
Posted: Wed Sep 17, 2008 5:41 am Post subject: Re: Shoulder Harness attachment |
Cal -
I would think your common sense would be telling you that, having your
seatbelt attached to something that might break is a bad thing. If you
really think it is plenty strong, then you're more than welcome to to build
it per the plans.
Jeff
randy(at)rjhebertassoc.co Guest
Posted: Wed Sep 17, 2008 7:04 am Post subject: Shoulder Harness attachment |
Cal and Jeff
I too am a structural engineer.
In buildings and general structures.
In my experience when my client perceives that something is inadequate,
no matter how hard I try to convince them that I am correct, in their
minds it is inadequate.
Perception plays a big part in this discussion.
Jeff can probably relate to this.
Although I am not an Aeronautical Engineer, Structural Engineering
relates to calculation of loadings and stress analysis in any structure.
Loads in these aircraft are of a small magnitude thus aluminum
structures.
Jeff the high G loading are probably out of the design criteria of these
aircraft.
It is like designing a building here in S Louisiana for a 150mph wind
when the statistical wind speeds are 110 mph. (90mph thanks to Gustav)
The problem I see here is that more is not always better. Increasing a
parts strength can move a failure regime to another part causing other
types of failures to occur.
Thanks to both of you guys for bringing this issue up however, because I
will now look more closely at this area when I get to it.
Randall J Hebert
Randall J Hebert & Associates, Inc
Consulting Engineers
Ph 337-261-1976 Fx 337-261-1977
Cal -
rvickski(at)yahoo.com Guest
Posted: Wed Sep 17, 2008 10:31 am Post subject: Shoulder Harness attachment |
Gents, I am not an engineer but have a fair understanding of physics and many other things. This pertains to the 701, as I have no experience with the 801. The 701 was designed for the standard pilot, 5'6" 165 lbs or something close to that. Being 6'2" and 220 lbs puts me somewhat outside the design parameters of the restraint system ( a 150 mph breeze on a structure with 110 mph hurricane ties). With this in mind I am abandoning the three point harness in favor of a four point, my idea is to install a .025 hat section in the roof of the baggage area from front to rear intersecting at the center of the rear wing attach top channel, incorporating shear doublers at the harness attach point, this should address upper torso restraint adequately in conjunction with the existing upper harness mount. To a degree this will lessen the load on the three existing load points, however the weak link is still the tunnel. Zac addresses this with a doubler design for
the tunnel. While this may be perfectly adequate I think it can be improved upon by an .040 attach point riveted to the top of the gear channel and tying into the existing tunnel restraint attach with a 3/16 cable. The outer lap belt restraint point can be doubled to the cabin side wall. I am hesitant to attach anything to the gear structure in the event it shears and departs, so the size and number of rivets need to be minimum for the gear channel modification I propose. I envision this type of failure mode (gear departing) to place the gear channel rivet heads in bearing stress while a frontal impact would place these same rivets in shear. By rough estimation not including the harness it would add less than 2 pounds.
Indeed more may not be better and may indeed move a failure regime to another part causing other types of failure but in the event these proposed modifications ever come into play, failure of some sort, has already occurred. The last thing I want to do is to design in a fatal flaw or perish because of an inadequately sized restraint system.
All responses welcome.
Roy Szarafinski
701 plans
roysgarage.com
n85ae
Posted: Wed Sep 17, 2008 11:03 am Post subject: Re: Shoulder Harness attachment |
It looks weak to me, so I'm making it stronger.
Jeff
