rbjjr
Posted: Tue Sep 23, 2008 3:17 pm Post subject: Pulled Rivet Removal Help Sought |
I may have a need to remove some rivets (20-30) and was wondering if anyone can offer advice on how to do so without screwing up the finished structure.
Thanks in advance!
Burke Johnson
CH701
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
NYTerminat(at)aol.com Guest
Posted: Tue Sep 23, 2008 6:22 pm Post subject: Pulled Rivet Removal Help Sought |
Burke,
Take a punch and drive out the stems of the pulled rivets. Then drill off the head of the rivet, you should be able to push the rest of the rivet out of the hole. It goes easy, try it on a practice piece first.
Bob Spudis
N701ZX/ CH701/912S
In a message dated 9/23/2008 7:17:48 P.M. Eastern Daylight Time, burkeandsusan(at)verizon.net writes:
Quote: | I may have a need to remove some rivets (20-30) and was wondering if anyone can offer advice on how to do so without screwing up the finished structure.
Thanks in advance!
Burke Johnson
CH701
Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators.
n85ae
Posted: Wed Sep 24, 2008 6:07 am Post subject: Re: Pulled Rivet Removal Help Sought |
Just hit each rivet head with the drill enough to shear the heads off, the
bodies will pop right out, or can be tapped out with a punch. Don't try to
drill any more than it takes to remove the head. You can also tug the
bodies out with pliers from the back side.
Speaking from experience unskinning an entire wing panel, I can say
with reasonable certainty that you can do a LOT of rivets damage free this way.
Jeff
rbjjr
Posted: Thu Sep 25, 2008 8:19 am Post subject: Re: Pulled Rivet Removal Help Sought |
Thanks for the informative replies!
Wish me luck...
Burke
n85ae
Posted: Thu Sep 25, 2008 11:09 am Post subject: Re: Pulled Rivet Removal Help Sought |
You don't need luck, it's very simple. You just need confidence from doing
a few (hundred).
Jeff
