falcon43
Posted: Tue Sep 30, 2008 9:52 pm Post subject: bending aluminum tubing |
Anyone have advice on bending aluminum tubing for my pitot tube without
kinking. Thanks, Harry Cieslar, Avid Magnum Builder, Goderich Ont
jlfernan
Dick Maddux
Posted: Wed Oct 01, 2008 4:31 am Post subject: bending aluminum tubing |
Harry,
You can use a tubing bender. I have had good success with the spring type you slide over the tubing. You can also fill the tubing tightly with fine sand and bend. The sand supports the wall of the tubing.
Dick Maddux
Pensacola,Fl
Looking for simple solutions to your real-life financial challenges? Check out WalletPop for the latest news and information, tips and calculators.
pwmac(at)sisna.com Guest
Posted: Wed Oct 01, 2008 5:55 am Post subject: bending aluminum tubing |
The least low costs bender will work. If you bought the soft temper 0
tubing you probably do not even need a bender. Just work the tube by
hand. If you have some extra tubing give it a try. For sharp bends
with small radius definitely use a good bender tool.
I have lots of different benders but by hand works most of the time
for the soft Al tube.
Paul
At 11:51 PM 9/30/2008, you wrote:
without kinking. Thanks, Harry Cieslar, Avid Magnum Builder, Goderich Ont
helili(at)chahtatushka.ne Guest
mikeperkins
Posted: Wed Oct 01, 2008 8:34 am Post subject: bending aluminum tubing |
I’ve packed sand into alum tubing for larger diameter tubing. But for smaller diameter tubing, using a brake-line tubing bender at an automotive shop might be better.
Mike Perkins
Guy Buchanan
Posted: Wed Oct 01, 2008 12:32 pm Post subject: bending aluminum tubing |
At 10:51 PM 9/30/2008, you wrote:
| Quote: | Anyone have advice on bending aluminum tubing for my pitot tube
without kinking.
Buy the little hand held lever action tube bender, they're cheap and
worth the aggravation relief. They also work for a variety of tube
sizes. I've seen them at auto part stores, and the ACS part number is
12-01577 or 12-01578, depending on size.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
A glider pilot too. |
