herbgh(at)nctc.com Guest
Posted: Fri Oct 03, 2008 11:38 am Post subject: How to adjust the pitch on my IVO prop? |
At 12:09 PM 10/3/08 -0700, you wrote:
How do I adjust the pitch on my 3 blade Ivo prop? Do I loosen the center nut and turn the center shaft right for more and left for less pitch?
Is there a certain torque setting for the nut? What size socket is needed?
Grant,
See: http://www.ivoprop.com/
Jack B. Hart FF004
Winchester, IN
grantr
Posted: Fri Oct 03, 2008 11:46 am Post subject: Re: How to adjust the pitch on my IVO prop? |
Thanks Herb.
Jack I did look at Ivo's website before posting however it did not tell how to adjust the prop. It explained how it works but not how to do it.
Posted: Fri Oct 03, 2008 12:05 pm Post subject: How to adjust the pitch on my IVO prop? |
Grant
I have an N3 Pup but meant to say "on my Firefly" .. Herb
At 02:46 PM 10/3/2008, you wrote:
Thanks Herb.
http://forums.matronics.com/viewtopic.php?p 7297#207297
_-
Steven Green
Posted: Fri Oct 03, 2008 6:32 pm Post subject: How to adjust the pitch on my IVO prop? |
Grant,
The way I remember the direction to turn the center shaft is relating it to
a vernier throttle, common on Cessna. Turning it to the right produces more
RPM.
Steven
| Quote: | How do I adjust the pitch on my 3 blade Ivo prop? Do I loosen the center
Grant
_________________ Steven Green |
Posted: Sat Oct 04, 2008 8:01 am Post subject: How to adjust the pitch on my IVO prop? |
At 12:46 PM 10/3/08 -0700, you wrote:
Grant,
The ivo site lists an email address:
ivoprop(at)pacbell.net
Jack B. Hart FF004
Winchester, IN
grantr
KolbFlyerJim(at)aol.com Guest
Posted: Mon Oct 06, 2008 5:46 pm Post subject: How to adjust the pitch on my IVO prop? |
Hi Grant.
Jim Here.
facing the prop turning the adjuster to the left increases the pitch, If I remember correctly the jam nut is 1 5/16 or 1 1/2 it's been a while since I have adjusted mine.
JIm VanGarsse Sr
UltraStar 503 DCSI.
N2613M
New MapQuest Local shows what's happening at your destination. Dining, Movies, Events, News & more. Try it out!
