Shai.Brenner(at)stryker.c Guest
Posted: Mon Oct 13, 2008 9:37 pm Post subject: Rotax 912 ULS wiring for RPM Gauge |
Rotax engine arrived with the following wire harnesses:
Two alternators wires (yellow) and two wires (magneto)
I have a "Micro 1000" gauge purchased from Zenith.
1) How can I wire this gauge?
2) Any recommendation for a larger size suitable gauge?
3) Engine oil and head temperature senders units have a "mushroom shape" what is a recommended connector?
Shai
CH 601 HDS
| - The Matronics Zenith601-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
K Dilks
Posted: Mon Oct 13, 2008 10:19 pm Post subject: Re: Rotax 912 ULS wiring for RPM Gauge |
The 2 yellow wires with female spade connector goes to the voltage regulator.
The two wires from the ignition modules go to the mag switches for grounding.
The Tacho wire have a plug connector end and the opposite is included with the engine in the same box as the starte solenoid.
No polarity for the tach drive as its just a A/C pulse, but I dont know about that particular gauge.
Hope this helps
kevin
_________________ Back home ................. |
Posted: Mon Oct 13, 2008 10:24 pm Post subject: Rotax 912 ULS wiring for RPM Gauge |
For the oil and head temp senders – either by luck or design a female spade “fast-on” connector works. Two pictures (from a Jabiru installation manual) attached.
-- Craig
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Brenner, Shai
Sent: Monday, October 13, 2008 11:32 PM
Subject: Rotax 912 ULS wiring for RPM Gauge
Shai
CH 601 HDS Quote: | [/b][/b][/b][/b]http://www.matronics.com/Navigator?Zenith601-List[/b][/b]http://forums.matronics.com[/b][/b]http://www.matronics.com/contribution[/b] |
Description: |
Filesize: |
69.37 KB |
Viewed: |
619 Time(s) |
Description: |
Filesize: |
43.02 KB |
Viewed: |
627 Time(s) |
K Dilks
Posted: Mon Oct 13, 2008 10:36 pm Post subject: Re: Rotax 912 ULS wiring for RPM Gauge |
Sound like you need the installation manual.
Go to http://www.rotax-aircraft-engines.com and down load the relevant document.
Pay attention to the oil circuit priming section
Yes spade connector is the correct type for the temp sensors......forgot to put that in last time.
Kev
