steve(at)tomasara.com Guest
Posted: Mon Aug 25, 2008 6:19 am Post subject: Dry Cell Batteries? |
Bob and the group:
I did an aeroelectric search for "Dry Cell" and came up empty. A quick
(too quick, apparently) look at Concord's web-site comparing Dry Cells
to VRLA batteries indicated that for the same Amp-Hr rating, the Dry
Cells are a little heavier and significantly better in cold-cranking amps.
However, since I'm removing the starter as part of my LongEZ rebuild
that doesn't do much for me.
On the other hand, if Dry Cell batteries perform better than VRLA in
terms of durability (specifically shell-life, self-discharge and
tolerance of time spent sitting while discharged) I would be interested.
Any thoughts from the group on the advantages (if any) and disadvantages
(other than the obvious weight/cost. e.g. do they use the same charging
profile?) of a Dry Cell battery on a starterless airplane?
Best regards to all,
Steve Stearns
Boulder/Longmont, Colorado
CSA,EAA,IAC,AOPA,PE,ARRL,BARC (but ignorant none-the-less)
Restoring (since 1/07): N45FC O235 Longeze Cothern/Friling CF1 (~1000 Hrs)
Flying (since 9/86): N43732 A65 Taylorcraft BC12D
nuckolls.bob(at)cox.net Guest
Posted: Mon Aug 25, 2008 7:44 am Post subject: Dry Cell Batteries? |
At 08:14 AM 8/25/2008 -0600, you wrote:
Quote: |
Bob and the group:
(too quick, apparently) look at Concord's web-site comparing Dry Cells to
VRLA batteries indicated that for the same Amp-Hr rating, the Dry Cells
However, since I'm removing the starter as part of my LongEZ rebuild that
On the other hand, if Dry Cell batteries perform better than VRLA in terms
of durability (specifically shell-life, self-discharge and tolerance of
Don't know what's being called a "dry cell". I'm aware
of NO lead-acid technology that does not reside in
one of three categories (1) flooded - like on your
'65 chevy (2) gelled - like those on many wheelchairs
and other 'mess-sensitive' need for deep-cycle
batteries and (3) starved-electrolyte, valve-regulated
lead-acid, recombinant-gas, thin-film, glass-mat, etc. etc.
These are all names for essentially the same technology.
The reason you didn't find "dry cell" mentioned in the website
postings is because there's no such thing. ALL lead-acid
technologies use liquid water and sulfuric acid electrolyte.
The differences are whether the stuff is liquid and
(1) sorta contained but with vented caps, (2) immobililzed
by adding 'jello' or (3) immobilized by the wetting/
capillary action of a finely woven glass 'kleenex'.
Some folks like to call these "dry" . . . you CAN
drive a nail through the side of the battery and it
will not leak . . . but it is by no means dry.
http://www.aeroelectric.com/articles/bat_thd.pdf
http://www.aeroelectric.com/articles/battery.pdf
Battery selection should not take up much of your
time. What's your battery maintenance program?
How much do you plan to depend on a battery?
If you're day-vfr only, buy the cheapest battery
you can find, run it 'til it craps. Engine cranking
is the primary concern and any sealed lead-acid
battery with terminals for fat wires will get your
engine started. CAPACITY is another matter. If you
plan to design and maintain a known level of
battery-only endurance for en route operations
then your first task is an energy analysis of
your battery-only endurance, pick a battery that
meets that requirement at 80% of rated capacity
(don't forget to further de-rate for load!), and
decide what protocols (preventative maintenance)
you'll adopt as owner-operator to make sure that
capacity is available to you at all times.
This exercise can be successfully carried out
with ANY battery brand or technology.
Posted: Tue Aug 26, 2008 4:29 am Post subject: Dry Cell Batteries? |
I'm pretty familiar with VRLA batteries. This looked like something new
but it could be that I got caught by marketing spin (I hate it when that
happens...). I'll do some more homework and will report back if I find
something interesting.
Steve Stearns
rlborger(at)mac.com Guest
Posted: Tue Aug 26, 2008 5:08 am Post subject: Dry Cell Batteries? |
Steve,
I think you are talking about the Odyssey "Dry Cell" battery series? If so, they technology they use is "absorbed glass mat." The Odyssey folks call them "Dry Cell" because if you were to break open the case, no electrolyte would run out. It is totally contained within the glass mat material.
So, yes, a bit of advertising hype. But it is still an excellent battery. I have an Odyssey 680 in my (under construction) Europa. The battery is 5 years old. I've been using it to test the panel as it was installed. There were periods as long as a year and a half where the battery sat unused. It held a charge for those unused periods. After 5 years of such abuse, it still turns the engine (Rotax 914) over quite briskly. Prior to first flight, I'm troubleshooting a few last gremlins in the instrument panel and it will run the panel all day long. When it's time to replace it, I'll have no hesitation replacing it with another new Odyssey.
Just my two bits.
Bob Borger
http://www.europaowners.org/N914XL
On Tuesday, August 26, 2008, at 07:25AM, "Steve Stearns" <steve(at)tomasara.com> wrote:
Steve Stearns
Posted: Tue Aug 26, 2008 6:36 am Post subject: Dry Cell Batteries? |
At 08:07 AM 8/26/2008 -0500, you wrote:
Quote: |
Steve,
material.
Odyssey.
The Odyssey batteries are a product of the old
Gates-cum-Hawker-cum-EnerSys prismatic cell batteries
built here:
http://www.odysseyfactory.com/about.html
Got to tour this plant a few years ago while on
assignment with Raytheon/H-B. The full line of
their products can be seen at:
http://www.odysseybatteries.com/
Without a doubt, these products are at the leading
edge of battery quality and performance . . . with a price
to match. As I recall, about 700 folks running a highly
automated manufacturing process produces about 60,000
batteries a day!
But it's still an SVLA battery loaded with the same
water-acid mix used by their competitors.
rampil
Posted: Tue Aug 26, 2008 8:03 am Post subject: Re: Dry Cell Batteries? |
You don't have to be an old timer to remember that "dry cells"
are carbon - zinc flashlight batteries.
I love my Odyssey battery but it sounds like one of their marketing
folks stepped out on a limb without engineering support
mikefapex
Posted: Tue Aug 26, 2008 8:17 am Post subject: Re: Dry Cell Batteries? |
A question related to Odessey batteries specifically, how can you determine the number of 'cells' within the battery. I've not been able to find that in their docs.
The reason I ask is that I just got a West Mountain CBA battery tester, and one of the test parameters is the 'number of cells' . Not really sure how to answer that, to build an accurate test.
Any suggestions are appreciated, thanks,
Posted: Tue Aug 26, 2008 8:50 am Post subject: Dry Cell Batteries? |
ALL lead-acid batteries are composed of cells that
develop just over 2 volts per cell at room temperature.
Like the batteries used in our cars since day-one,
a 6v battery is 3 cells; a 12 battery is 6 cells,
etc.
I'm not sure why West Mountain puts that block into
their setup screen . . . the value placed in it has
no effect on how the test is run. It's a constant
current discharge + data acquisition system that will
yield the same plot irrespective of what values go
into the "battery type" and "cells" boxes.
I'm pleased that you've acquired one of these
very useful tools!
( -Thomas Paine 1776- )
Mike,
A single lead-acid cell will produce approximately 2.1 volts. For a 12 volt ( 12.6 volts actually) battery that is 6 cells.
Check out "lead acid battery" in the Wikipedia.
Bob Borger
On Tuesday, August 26, 2008, at 11:17AM, "mikef" <mikefapex(at)gmail.com> wrote:
http://forums.matronics.com/viewtopic.php?p 0678#200678
Posted: Tue Aug 26, 2008 8:51 am Post subject: Dry Cell Batteries? |
Hmmmm . . . I think the witch's brew of gooey stuff
in side was still moist and probably water based. I
also recall how badly they could leak! There was a time
that one battery manufacturer (Eveready I think) offered
to repair or replace any appliance that was trashed due
to leakage of their new and improved cells.
Quote: | I love my Odyssey battery but it sounds like one of their marketing
folks stepped out on a limb without engineering support.
It's been my experience that the last folks marketing
wants to hear from are the engineers!
mrspudandcompany(at)veriz Guest
Posted: Tue Aug 26, 2008 8:53 am Post subject: Dry Cell Batteries? |
* AeroElectric-List message posted by: "mikef" <mikefapex(at)gmail.com>
their docs.
Mike,
* Lead acid batteries, such as the odessey, are about 2 V per cell, which
means a 12V battery has 6 cells.
* Roger
mikefapex
Posted: Tue Aug 26, 2008 9:08 am Post subject: Re: Dry Cell Batteries? |
Thanks for the battery cell info, it does help.
I am very glad to have gotten the CBA battery tester and look forward to using it. I'll post feedback as I run some tests.
Sunday I fired up the engine on my new Z19 system and ground ran for a few minutes. All smoke stayed in wires, major circuits worked as expected. Its a beautiful thing.
Thanks again,
Beemer
Joined: 26 Aug 2006 Posts: 87 Location: Middle Georgia
Posted: Wed Aug 27, 2008 3:48 am Post subject: Re: Dry Cell Batteries? |
Is there a source for these batteries in an 8ah rating that does not have the fast-on tabs, such as those used on wheelchairs? The smallest I've found with bolt-on terminals is 17ah.
Thx,
Bradley
_________________ Beemer
KF2 (and now an M3!)
Suzuki G10 three-banger
Middle Georgia |
Posted: Wed Aug 27, 2008 6:04 am Post subject: Dry Cell Batteries? |
Thx,
Bradley
The field of choices drops rapidly when you go below
17 a.h. Few manufacturers of smaller batteries are
interested in the applications that include engine
cranking. Concorde used to have a smaller battery
with machine screw threaded brass terminals but I think
they've discontinued it.
B&C offers a 12 a.h. with fat-wire connections . . .
http://www.bandc.biz/BC103-1.pdf
I believe this is the Odyssey PC545
http://www.odysseybatteries.com/battery/pc545series.htm
which has a 14 a.h. capacity at the 20 hr rate.
There is one smaller. The PC310 has fat-wire terminals
(4mm) and capable of cranking engines.
You can get the technical manual for the PC series
batteries at:
http://aeroelectric.com/Mfgr_Data/Batteries/Enersys_Hawker/Odyssey_PC_Series_TM.pdf
You'll note that the 310 is less than half the battery
than the popular PC625.
What are your requirements for capacity? Have you
done an energy study for battery-only endurance?
The 310 is not cheap and it's fragile compared to it's
larger siblings.
Description: |
Filesize: |
34.58 KB |
Viewed: |
536 Time(s) |
klehman(at)albedo.net Guest
Posted: Wed Aug 27, 2008 6:35 am Post subject: Dry Cell Batteries? |
Search the Dekka line. Same thing as Odysey with bolt on terminials 8 AH.
Ken
Beemer wrote:
Thx,
Bradley
Posted: Wed Aug 27, 2008 11:03 am Post subject: Dry Cell Batteries? |
At 10:35 AM 8/27/2008 -0400, you wrote:
Ken
Do you have a specific part number for Deka? While looking
for them I found this "Power Star" product on Ebay
It's a 9 a.h. device, probably at the 20hour rate. This makes
it a 4.5 a.h. battery for powering an e-bus for 3 hours . . .
i.e, about 1.5A ebus. Size is L = 5.91 x W = 3.39 H = 4.21
A 9 a.h. battery would weigh in at about 7-8 pounds.
Description: |
Filesize: |
78.79 KB |
Viewed: |
531 Time(s) |
Posted: Wed Aug 27, 2008 1:11 pm Post subject: Dry Cell Batteries? |
Mine are ETX9 Dekka Power Sports batteries. As mentioned before one will
start my subaru fine but they normally auto parallel for cranking on my
bird as per Z-14. The cables bolt onto the top or the side of the
battery which is convenient. Next size up is the ETX12 at about the same
price. Made in USA.
Ken
Robert L. Nuckolls, III wrote:
> Ken
*Truncated!*
*This message exceeded the Maximum Message Size set in Account Settings,
so we have only downloaded the first few lines from the mail server.*
Beemer
Posted: Mon Oct 20, 2008 5:11 am Post subject: Re: Dry Cell Batteries? |
Thx,
Bradley
<snip>
larger siblings.
After much discussion, we think this is how my electrically-dependent engine breaks out...
Quote: |
Current draw on 4 cylinder EFI engines:
Pump at 40 psi- 5-8 amps
Injectors at 5000 rpm- 3-4 amps
Ignition at 5000 rpm- 2.5-4 amps (depends on coil charge time)
ECU- .15- .6 amps depending on ECU
My total current draw in flight at 4500 rpm with 2 pumps on (one LP
Facet, one HP Bosch 048), transponder, comm, gps, injectors, coils,
ECU and scavenge pump is 18 amps. |
We seem to think that the 17ah PC680 clone would give just about 15 minutes of realistic run time, given some age on the battery. I guess I might have to carry the weight of another battery around to be safe.
Bradley
Middle Georgia |
Sam
Posted: Mon Oct 20, 2008 5:11 pm Post subject: Dry Cell Batteries? |
Bradley,
I am installing a similar system and I think those numbers seem a little high. I know the Walbro pump I'm going to use
is listed at 4 amps. What injectors and coils are you using?, Again, to my uneducated mind those numbers seem high.
I have a similar setup and I think I'm looking at around 12.5 amps.
RWS EC3 controller
Walbro pump
Delco LS-1 coils
Transponder, GPS, COM, etc.
Two contactors
I have the LS-1 coils only using 1/2 amp.
Sam
Murphysboro, IL
www.samhoskins.blogspot.com
On Mon, Oct 20, 2008 at 8:11 AM, Beemer <bmwebb(at)cox.net (bmwebb(at)cox.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Beemer" <bmwebb(at)cox.net (bmwebb(at)cox.net)>
> Thx,
> Bradley
> larger siblings.
> Bob . . .
Bradley
Beemer
Middle Georgia
[url=http://forums.matronics.com/viewtopic.php?p 9455#209455]http://forums.matronics.com/viewtopic.php?p 9455#209455[/url]
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
Posted: Mon Oct 20, 2008 6:40 pm Post subject: Dry Cell Batteries? |
> larger siblings.
> Bob . . .
According to the performance curves at:
http://tinyurl.com/5p6d4w
a 17A load on a 100% battery will give you just
under 30 minutes of run time down to about 10V. So
a battery due for replacement would be suited
for about 20 minutes of operation.
Consider running both batteries of a 2-battery
architecture in parallel. Losses in any given battery is an
I(squared)*R function. By cutting the current per
battery by about 1/2, the energy lost in each battery
drops to 1/4th the original amount. Doing 1/4
per battery in two batteries gets you 1/2 the
lost watts. Two 17 a.h. batteries gives you
34 a.h. of total capacity. An 18A load on this
combo goes to a 60+ minutes of duration.
A savings of 5 or so pounds can be realized by
going to a single 28 a.h. battery.
http://tinyurl.com/6eu2p8
The internal impedance of this battery seems
better than two 17 a.h. in parallel. It gives
you the same 60+ minutes at less weight
and total capacity.
Of course, with a single battery or treating
two batteries as one battery dictates an
aggressive capacity tracking protocol. If
ever there was an power plant begging for
a second, small alternator, it's this one.
