		vk3eka(at)bigpond.net.au Guest
				 Posted: Fri Oct 24, 2008 2:14 pm    Post subject: Mechanical Fuel Pump |
				Hi Guys,
 I am rebuilding an O-200 for experimental use.
 The engine I have doesn’t have a mechanical fuel pump or the eccentric on the cam to drive one. Do I need a different cam or does the eccentric fit in between the cam end and the vacuum pump drive?
 Any other ideas would be good?
 Cheers
 Peter.
  |  | - The Matronics Continental-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		agustafson(at)chartermi.n Guest
				 Posted: Fri Oct 24, 2008 4:28 pm    Post subject: Mechanical Fuel Pump |
				Peter
  I have the same engine in a Zenith 601 and I just  used 2 Facet fuel pumps, one in each tank. It's a lot cheaper for sure. Do you  even have the boss to mount a pump on. Mine did not.
  Aaron
  [quote]   ---
				 Posted: Fri Oct 24, 2008 4:46 pm    Post subject: Mechanical Fuel Pump |
				Aaron,
 Thanks, I am also building a 601XL. The O-200 does have the place for a mechanical pump but nothing else. I have a copy of WW Corvair/601 book so may go with the double electric pump setup.
 Peter
 From: owner-continental-list-server(at)matronics.com [mailto:owner-continental-list-server(at)matronics.com] On Behalf Of Aaron Gustafson
  Sent: Saturday, 25 October 2008 11:28 AM
  To: continental-list(at)matronics.com
  Subject: Re: Continental-List: Mechanical Fuel Pump
 Peter
 Aaron
