raymondj(at)frontiernet.n Guest
Posted: Fri Oct 24, 2008 2:22 pm Post subject: Off Topic: Winter Hanger "Warm Box" |
For warming boxes I have used 2" foam glued together with RTV. Light, easy
to construct, and well insulated.
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
burbby
Posted: Fri Oct 24, 2008 10:18 pm Post subject: Off Topic: Winter Hanger "Warm Box" |
I went to the local hardware store and purchased a thermostat and it truns on and off a 500 watt heat lamp in my small well house. it keeps it around 45 degrees F . The well house is well insulated and it works very good. I live in Tx so my temps are warmer than yours but gives you a idea anyway.
Gary
--- On Fri, 10/24/08, DaveG601XL <david.m.gallagher(at)ge.com> wrote:
Quote: | From: DaveG601XL <david.m.gallagher(at)ge.com>
Subject: Off Topic: Winter Hanger "Warm Box"
Date: Friday, October 24, 2008, 6:30 AM
I am about to go through my first winter in a hanger. I have some chemicals
like cleaners, polishing compounds, etc. that have the recommendation to not let
freeze. I would rather keep these at the hanger instead of trying to remember
to haul them back and forth from home. I remember hearing or reading a
recommendation a while back about building a box and putting a light bulb inside
it. The idea is that the bulb would provide just enough heat to keep things
from freezing, but not too much to cause a fire hazard.
I am on southern Ohio where we usually do get too terribly cold, as compared to
you Wisconsin guys, but do see plenty of days below freezing. I was thinking of
a plywood box lined with aluminum foil and a 75 or 100 watt bulb. Any helpful
hints or suggestions on box construction, insulation and safety concerns?
David Gallagher
601 XL/Jabiru 3300
First flight 7/24/08
Phase I flight test complete 10/16/08
http://forums.matronics.com/viewtopic.php?p 10073#210073
